I have a very old Singer hand vacuum that was rejuvenated approximately 55-years ago…at that time I wired it with a 25ft two conductor (no ground) ‘appliance cord’ that was gray with fine ribs. There are no markings but I removed the plug and stripped the two conductors, they strip as 16 gauge.
The cord currently, when stressed, shows lines, but doesn’t crack, the inside conductors seem to be in pretty good condition.
The problem I am running across is the outside diameter of the cable…what I currently have is a 1/4” outside diameter, I want the same as the vacuum has a spring strain relief that I wish to keep in use, it is limiting me to the 1/4” OD cord.
Can anybody tell me what I should be looking-for? Is this a fools errand?? is the cord i want a relic of the past???
Any information or source would be appreciated…thank you.
