Press block for use with shop press?
quilty
Where can I source a nice & flat, square block for safely & accurately pressing items with the shop press?
I'm not talking about the press plates that rest on the bolster of the press.
LopezBart
Lopez Island, WA
If you want something hardened and ground, a 3"x3"x1" jeweler's block would likely work, and they're available inexpensively.
Q
quilty
Something like this?
whateg01
doo dah, kansas, usa
My grizzly came with a couple pieces of 2"*2.5" steel long enough to span the bed but both were flame cut and arrived that way. I squared them up on the mill and made them the same size. Also removed the powder coating in the process so they no longer slide around. So nice to work with now! I've been grabbing little pieces of steel here and there to use on the press. Pipe. Tubing. Bearing races.
Doesn't sound like you need something to go across the bed. Just a small block to set something on or to put between the ram and the work. Check with fabricators for drops of 1/2 or 3/4, etc.
LopezBart
Lopez Island, WA
I don't think hardened steel is a good idea for a press. Definitely not hardened through to the highest hardness. You don't want to create shrapnel.
I've used bearing races and similar things w/o issues. A jeweler's block is not going to be very hard; likely around 50 Rockwell C; that's about what is desirable for an axe. They're plenty tough for use in a press.
BurtEggley
drop by a metals supplier near you. They usually have scrap pieces of steel and aluminum they sell by the pound. I keep old bearings, bearing races, gears, pieces of oak etc, that I can use on things. Also a good set of arbor plates is a must.
cannuck
Rural SK
I have a selection of many pieces of 1" plate and lighter scraps as well as sets of 1" V blocks to span the table beams of my 20 T presses, as well as some specific VW plates to fit various stuff. I have a big chunk of 2" HR plate for my 100T and will make some V blocks this summer. The V blocks are all heavy/deep enough to lay on their sides and make a square hole for things round to be pressed on or off of shafts.
Steve_P
You don't need flat ground RC 50 steel for this task. It's a press. Everything isn't parallel to .001". I know this is GJ and go ahead with whatever you want, but I've just been using steel bar scraps for 30 years.
gahrajmahal
Cincinnati, Ohio
That’s an interesting setup. It looks like it can roll back and forth on the large I beam pressing anywhere along its length. Or, is it a standard H style frame? How is it used?
