Show your Millers Falls tools!
crguy
SW Washington
That explains the screw hole in the rear ! I have never seen one with it & this one has been A.W.O.L for at least 60 years. Was it Std. on the No. 2’s? Thank you for the info, guess I need to get busy looking!
Steve
Look on Ebay, or Google them, and you will see they came with a side handle.
RicksCAVE
Hi. New to forum. Can anyone help with more info. It's a Miller Falls No. 618A level, It feels too heavy to be aluminum, but is not magnetic.
nz44tool
New Britain CT
I just acquired this 1/4" ratchet. My meager search skills are coming up empty. Can't find it mentioned anywhere.
I suppose the "MF" could be something other than Millers Falls, but what?
It's U.S.A. obviously, but the "1693+" doesn't get me anywhere.
Anyone?
Probably Millers Falls
Still have not found them in a catalog
MAD
Western MA
Anyone?
It is absolutely without a doubt Millers Falls. Somewhere I posted a picture of a new in-package spark plug socket that I had, but it must have been on another forum. I still have the socket and a few others, but I'm not sure if I saved the package when I opened it.
Both Millers falls and Pendleton Tool ( Proto P&C, etc...) were owned by Ingersoll-Rand at the same time, so that is why it looks like a Challenger...
A friend stopped by yesterday and delivered a late Christmas present:
Millers Falls 1164 one-inch cold chisel
She said it was the only "locally made" item she was able to find when she went "back home" over the Christmas holiday. She grew up in Orange.
driftpin
I've owned this probably 53 years and it just helped me to find my survey points after a city subcontractor pulled out my survey stakes and threw them In my bushes.
I went to the city engineering office and told them I wanted registered pins to reestablish my survey points and multiple copies of a sealed survey. I also sent a copy of my request to my district commissioner who happens to be a PE, she is a female and has helped me with other issues dealing with the city in the past.
The city 'made me whole' and complied with my requests.
Eric Brown
Working on a Millers-Falls 731 brace. The chuck spindle is held on with a screw on top, Under that is suppose to be a "D" washer. It was missing. Found one on another brace. It measures 5/8" OD, for a 7/16" shaft with a flat. Thickness is .045", steel. I have not been able to locate a replacement yet. McMasters has 3/8" and then jumps to 1/2". I asked them and they said sorry, they couldn't help. Did not see anything on E-Bay either. Asked several of the washer suppliers and they want $1200 just for the tooling. Anybody know where I might buy some of these? One option is to buy the 3/8" ($10 each!) and then file it out to 7/16". Don't want to scrap a brace just for this washer.
Here is what it looks like"
Eric Brown
Millers Falls 77A I finished restoring.
This was my first eggbeater drill I've tried restoring.
I liked it so much that I went out and bought 2 other egg beater style drill to restore.
Before
After
Very nicely done. Good job.
bonneyman
Desert SW
Here's a pair of MF drivers I found - a 6" and an 8". Before and after cleaning. Not the most comfortable handle shape but the shanks are beefy and the tips are nice and wide. Paid a $1 a piece.
MisterEd
Florida
Millers Falls Auger Handle and Bit.
Marked “00” following “Millers Falls”. Also, pre-1931 relocation to “Greenfield”. Mostly matches dimensions for their “No. 2”. Handle is 17 Inches wide. Bit is 19 Inches long and 2 Inches in diameter. Nuts in Handle appear to be original. The nut in the Bit . . . maybe? Bit is unmarked.
MisterEd
Florida
That's really quite the find there.
The Handle alone would have been interesting!
Found what appears to be the same Handle as "PRATT’S PATENT AUGER HANDLE, Nos. 1 & 2.", but the only Pratt Patent I could locate was for Miller's Ratcheting Handle.
Millers Falls Co.: Catalogue No. 24, Millers Falls Co., 1894
tombell572
Sea Cliff, NY & Portland, OR
I have a Millers Falls Star power hacksaw as pictured in the catalog cut shown on the vintage Machinery site. I have the mechanical details worked out but I'm trying to determine the original factory color. It has a few coats of paint and is now what I would call Kelly green. I've tried chipping through the paint layers but can't identify anything meaningful. If anyone has one or has seen one that you believe to have original paint or if you're a M/F tool guru, please let me know.
Tom B.
