My install of my Cheap 2 Post lift. Is it worth it? Maybe.
RichHawk
Hi Richard S. here in Kansas City. Long time lurker, but this is my first post.
I bought a brand new two post, 9000 lb rated lift from American Automotive Equipment
http://www.americanautomotiveequipment.com/2-Post-Lifts-p/tp9a-d.htm
The below is my experience installing it in my home garage. No Agendas, I don’t want to start a flame war about which lift is best , because mine is certainly not the highest quality. But conversely, I can’t speak for the quality of the more expensive lifts, as I haven’t installed one of those ever, and haven’t used one professionally for more than 15 years now.
What I do want you to know is just what you get for your $1500 shipped to your door.
I read and read and read everything I could on two posts lifts, but never found any definitive information about the good or bad of the $1500 lifts. Yes lots of Armchair quarterbacking and lots of “Bend Pak is awesome” threads. But nothing that said “the $1500 lift killed my brother when it folded like a toothpick with only 3000# on it.” So I took my chances at half the price of a known good lift, and ordered it one fine Monday three weeks ago.
Yes, Yes, we all saw the lift loaded to fail point on youtube. And By the way, that lift looks similar but not exactly like mine. Though I don’t ever intend to lift anything more than my 4500 lb truck, so I think I'm safe.
I bought the TP9A lift. It is marketed by United Products, so says the Install and operation manual that American Automotive Emailed me. A paper copy of an Install manual shipped with the lift. It has the same pictures, but the text is very poorly translated into English.
No big deal, the Emailed manual if completely legible. Obviously American Automotive spent the time to re-write it. Without the American Automotive version the install would have been much tougher.
I just got my lift installed an operational this weekend. It probably took me 20 hours of total time to get it all done. This was my first lift install. Yesterday I used my Full size pickup as the guinea pig vehicle to be lifted up. I figured if I did something wrong I wouldn’t feel too bad about dropping the $500 pickup compared to the Porsche or BMW. I’m much happier now that I’ve successfully lifted a car and nothing broke, and nothing leaked. But it wasn’t without drama.
During the install there were at least three times where I just about gave up and decided to call up American Automotive, complain and return the thing. In retrospect, I would happily pay $500 more for a BendPak lift. Unfortunately the cheapest BendPak I found anywhere was still more than $1000 more expensive than the one I bought, and once I figured that extra $1000, plus eating the shipping both ways, it would have been more than twice the cost of the TP9A that I bought. So I soldiered on.
All of my issues were build quality issues. The install was pretty straight forward, hampered again and again by shoddy assembly and nonexistent quality control.
Here's my list of gripes in order that found them:
1) Paint up and down the edges of the long blue rails was sawn off, I suspect from a steel band that wrapped around the whole assembly at one time. no big deal, but easily avoided with just a little care
2) Of the 6 pulleys that guide the equalizer cables in the lift system, 3 of them would not rotate as installed. In all 3 instances the blue paint applied to the whole assembly was also applied to the pulley shafts, increasing the diameter enough that the pulley became an interference fit between the pulley bushing and shaft. One was so bad that in order to even get it to slide on, the manufacturer ground away at the pulley bushing just to be able to force the pulley on the shaft. I used emery cloth to sand away the paint to get the pulleys to turn.
3) Two of the main balance pulleys (One of them is the one with the ground down bushing) do not rotate straight. The bore of the bushing is not perpendicular to the center line of the pulley. so they wobble 1/8 to 3/16 an inch. One of them ALMOST touches the plate metal that it runs parallel to.
4) NOTHING was greased. every pulley, every bore, was dry dry dry. I used up half a tube of grease lubing up the slide rails where the main carriage bushings slide up and down.
5) When I stood the columns up the power unit side base plate was not flat. I laid it back down and measured versus a straightedge. Lengthwise it was curved 1/4 inch up from center on both the left and right side. I had to shim more than expected to get the column to stand level.
6) Once standing up, I couldn't get the power side carriage to move at all. It was stuck at the bottom. The other side I could lift by doing a dead lift squat. The power side, would not budge. I finally used my 2 ton engine hoist to raise the carriage, and then lower it again, where it promptly got stuck again. I checked for beam straightness, and beam damage, or twisting. and finally found the cause. Inside the beam, where the carriage bushings slide, there was a glob of the blue paint they used that was sticking out more than 1/8 of an inch. This glob would wedge the carriage bushings so that the whole carriage wouldn't move. I filed the glob of paint level with the rest of the paint, and the carriage slid easier.
I then lubed up the slide areas of the rail where the carriage bushings will ride, and the carriages moved much more smoothly.
7) The Hydraulic hose that connects the power side beam to the other beam was 2 inches longer than needed. This extra length meant that the hose would likely rub on the tension balancing cables. My solution was to move the power side beam back two inches, keeping the hose straight. Doing this ALMOST made the equalizer tension cables too short. Additionally moving the colums apart that two inches made the floor cover of the hose and cables shorter than ideal. In retrospect I should have had the hose modified. But REALLY? 2 inches? Where is the quality control?
8) The top cover plates / pulley assemblies are made to sit on top of the beam, and bolts from the side secure it to the beam. The top main plate is horizontal, and has two vertical plates welded perpendicular with threaded holes for the bolts to secure it to the beam. The problem? The vertical plates are too close together, and are 1/4 inch from the side walls of the beam. When tightening the bolts down they pull the top of the beam inward by 1/4 if an inch, visibly deforming the beam, and preventing the carriage from achieving full height by pinching the carriage. My solution was to make some 1/4 inch thick shim plates between the beam and the top plate vertical part. (see picture)
9) The bolts provided to attach the motor /power unit to the beam were horrible quality. I used them anyway, and stripped the threads from the bolt with nothing but a 14mm box wrench and mediocre force. I replaced all four bots and nuts with quality hardware.
10) The grease zerk for the chain pulley on top of one of the hydraulic ram fell out while I was routing the equalizing tension cables. I then noticed that that whole pulley assembly was on backwards. The zerk would have been pointing at the closed back of the rail, and completely inaccessible. I disassembled the chain system, and flipped the pulley head around, and screwed the Zerk back in place.
11) Finally it moves under power.!! Oh, but it won't come down. Check the safeties are disengaged, push harder on the hydraulic release lever, nothing. No release of hydraulic pressure. Read the manual for the 14th time. Study the Hydraulic diagram in the manual, and start playing. It turns out there is an adjustment to how fast the hydraulic fluid can release, so that you don't have a 9000lb truck fall 79 inches in 1 second. This Throttling adjuster was screwed in 100%. it was bottomed out, preventing any flow. I backed it out almost all the way in order to get the carriages to come down on their own. Adding the aprox 200 lbs of lift arms helped the carriages to come down quicker than snails pace. I fine tuned this adjustment with my truck to get the proper rate of decent when loaded. Good thing for this picture. As there is no mention anywhere else on the functions of the Hydraulics.
12) I go to bleed the air out of the system as the manual suggests. "slowly loosen the bleed screws located at the top of each cylinder to bleed trapped air" Uh... I don't have any bleed screws. There is a pre-drilled half depth hole where I suspect the bleed screws are SUPPOSED to be installed. But they were never finished drilled, nor tapped. (hands in the air with disgust for the twelfth time). I called American Automotive about this yesterday, but have gotten no response to my voice mail in the last 48 hours. I really don't want to be drilling into hydraulic cylinders. I don’t know what the trapped air will do bad, other than promote rust from within. But it seems to be able to lift my truck with no issues, and no jerkiness.
13) Is it unlucky that I had 13 different issues? The floor plate does not have any margin of height to account for not perfectly level floors. In order to maintain level lifting, I raised one beam up 3/8 of an inch overall to account for the slope of my floor. This 3/8 inch higher beam meant that the floor plate(supposed to be sitting on the floor) now instead rests squarely on the hose and the Tension cables. GRRRR…. Solution will be to build a spacer and bolt the floor plate to the spacer raising the one side up 3/8 of an inch.
jethro29
central delaware
and after all this,your actually going to stand and work under that p.o.s?a lift is one place where there is no room for compromise.good luck and god bless.
saabman
Sebago Lake, Maine
Also it looks like you are lifting your truck with flat pad elevators. For safety sake, get some U risers. These insure that the truck does not slide sideways off the lift.
Shadowdog500
Down the shore
Hopefully we don't hear from your brother!
After reading what you had to do to make your lift work, I don't know if you should be standing under it.
Chris
hevnbnd
Arkansas
You have a porshe and a bmw and won't spend a little bit more on a quality lift.... I got a rotary 2 post with inbay controls and love it!!! I think I spent around 2200 but I would have to look up my receipt.
jeffk14
GA
Y'all sure are giving the guy a hard time. I mean, that ain't no Mohawk or nuthin' but it seems at least a bit better than that MaxJax thing that so many folks on here like. If it's anchored well, I'd work under it. Probably wouldn't want to be under there with anything heavier than a 1/2-ton truck on it though.
jhelrey
MN
Very good write up! I don't have a lift yet and no clue on what I will buy!
ket-tek
I installed a maxjax for a friend and didn't experience any build quality issues. It went together smooth. Not sure were the comparison between these two comes into play here?
I do wonder about it being anchored up against the wall. Those holes are drilled at the edge of the slab, not recommended by any manufacture I've seen.
jeffk14
GA
The MaxJax is another example of a relatively light-duty lift and is generally well received here. That is all.
ket-tek
There should be bleeders, as the air will go to the highest point in the system and should ideally be bled out.
And yes, DO NOT try to drill/tap those holes in the assembled cylinders, you may render the lift useless if shavings get inside and score the ram or tear the seals.
Do the end plates unbolt of the end of the cylinder? If so, just remove them and install brake bleeders in the plates and reassemble.
R
RichHawk
Yes, And I can Spell Porsche too!
I wrote this as much as a data point for others as anything else. I could not find any unbiased data points on the cheap lifts out there, so I created one for others to use. Do I feel it is unsafe? Not in the least. It's anchored well and the safeties are integral and well made. All the build quality issues were inconvenient, and pissed me off. But none of them were safety related.
If left unaddressed could they have been potential safety issues? Sure Possibly. The worst in my mind could have been getting the carriages stuck at the top because of the improperly built top caps.
It is what it is. It's not the best lift out there, but it's what I chose, and is a lot more secure than a scissor lift.
Thanks for the thought about the anchors close to the stub wall. They are 3 to 5 inches away from the edge and I will regularly check for loosening anchor bolts. Heck I'm now more strongly considering tying the top of the wall side beam to the wall just to reduce the tension stress on those outside bolts.
Richard
R
RichHawk
I don't know what end plates you are talking about, I'm not a hydraulic expert by any stretch. Attached are a couple pics of the top of the cylinders.
does the top part un-thread from the bottom part? is that how I'm supposed to bleed the air out? by loosening the "cap" slightly? If so, then that hole you are looking at probably is for the special wrench, not the half done bleed valve Like I assumed.
Richard
R
RichHawk
Pic of the cylinder top and no bleed valve in sight
Wackerjr
I just called bend pack on this specific issue.... NO less than 5-6 inches from the wall they said for the same reason.
340six
I agree good writeup what brand did you get?
I am kinda funny and would worry about it when i use so I want to stay away.
I would rather buy generic rice crispy and save pennies for a nicer lift
R
RichHawk
The "brand" of my lift is a bit of a mystery. I quizzed American Automotive but as you can imagine they don't want to give that information up for fear of loosing a sale. American Automotive directly stocks parts and covers the warranty out of Texas. Their Documentation says the lift is by United Products. But the printed manual that shipped from overseas with the lift says Qingdao Jinhua on the picture of the front cover. Model TPF1132-1
http://jinhua.en.alibaba.com/ from the web.
And if you wanna see scary, go look at the high rise scissor lifts these guys make.
Richard
Ign
Butte Peak ND
I say props for posting and being honest about your issues. Sounds like it will work for you and you have the mechanical ability to work it out.
All my issues w my BendPak were minor and I will say your info makes them seem even more minor now.
Dewaynep
I don't think that half drilled hole in the end of the cylinder is for a bleed screw. That is there so you can use a spanner to unscrew the cylinder end plate.
brownbagg
its looks like a copy of mine bendpak xl9. they could pass for twins. dont know why it took you 20 hrs to install. I install mine in less than two hours
R
RichHawk
Really? Two hours? Are you sure you are counting everything? Because I think I spent two hours figuring out exactly how level the floor wasn't so I could pre-build the plate to raise one side 3/8 of an inch.
And I know I spent at least two hours unpacking the lift parts laying them out and inspecting them. It's not like you can just unbolt a 700 lb rail and hold it up with your hands to get the bolts out, you have to support it with something else. I had a 2 ton engine hoist, and two floor jacks, and working carefully by myself just unpacking the parts and standing the rails up took some time.
Then there was the probable hour or two I spent diagnosing and correcting the carriage that was stuck on the glob of paint. It all adds up.
2 hour expectation for setup of any lift in your own garage is misleading. I bet two professionals with a crane attached to the truck would have trouble hitting two hours with everything perfect. If you are doing it all yourself with the only special tool being a borrowed monster hammer drill, expect it to take a full weekend.
Richard
R
RichHawk
This is intriguing. Lets do side by side comparisons. I'll take photos and measurements of mine, you take photos of yours, and we compare. I suspect that they are not the same. Just by sheer good reputation the BendPak has, I have trouble seeing how they came out of the same factory. But hey, maybe Bend Pak has a Quality guy in China that rejects the bad ones, that then get sold as the cheap ones elsewhere like American Automotive.
From what I've read, Bend Pak cares a whole lot more about at least the key components like Hydraulics and power units, and therefore I suspect use higher quality parts inside, even if they do use the same steel.
Let's start another thread though, compare BendPak xl9 to my cheap lift, and just link it here.
Let me know that you are in, and we'll make up a list of things to compare, and put side by side photos of everything.
Richard
rickycobra
I think that is because most of us are all hobbyist so we don't need a industrial strength lift(Although it's not far off and it is made by Dannmar) and the portability is also a factor for a lot of people who share there home with a lot of people.
Dragster Racer
Morrison, IL
2 hour install for the same lift I have trouble believing. It took my two hours to get upright and square. Another hour for drilling and anchoring and probably more. Run electic....hydraulic....cables and adjust. I couldn't do it in even twice two hours. No way for me.
Most of the things that he had trouble with seem like nusance items to be. Does it indicate something sinister about the quality overall? Maybe..Maybe not. like was said, if it is anchored well, and the gauge of steel and design are what you would expect, I don't have a problem with it. One area I like to be sure of is the catches. i don't want one of those slipping, or even one not disengaging when lowering. I had a low air pressure situation I was unaware of until I saw that one side didn't disengage. That made me pucker for a moment! I would say you did well and have a good value for a lift that is used at home. Enjoy it. anyone that says that you don't get quality if you don't spend the money is overlooking a lot of things.
Kev442
Wi
+1
Exactly. The bleeder would not be in the end cap, the seal is right under there.
Car54
Tampa, FL
I found the shopping for a 2post was pretty classic. Cheap new lift vs. higher end used lift.
I went with the latter and couldn't be happier.
Thanks for posting your story.
LWW
SF Bay
Excellent write up. Appreciate your honesty. Although I did the install of my MaxJax (twice) given my impatience, I will be paying a professional to do the install on my next lifts. They will either be Danmar parking lifts or high end used parking lifts. Regardless, I'll spend the extra several hundred to have them installed by a pro.
Sebringer
Anyone shopping similar 9k baseplate lifts as this should consider the DirectLift. It is really a Forward lift re-branded which technically makes it ALI certified without paying extra for the gold sticker. I've been shopping lifts for months now and that was a little tidbit I stumbled on. I'm going the 4-Post route personally and found Quality Lift(Challenger) and BendPak to be the best for what I'm looking for.
walrus
Maine
I installed above ground lifts and below ground lifts professionally many years ago. Been along time since I've done one but can't imagine doing an above ground in 2 hrs. On the other hand I can't remember them taking much more than half a day even with a lousy drill. We used to put them together in place, square, level,drill, check level again, torque bolts.
brownbagg
mine came of the truck already together, just slap the pump on hook hoses drilled and plug in
OneTon
SoFLA
...mine is certainly not the highest quality.
So I took my chances.
...so I think I'm safe.
...the power unit side base plate was not flat.
Hmm...never had any of this running through my mind while installing the BendPak. :confused: You really do get what you pay for when it comes to lifts. :thumbup:
R
RichHawk
Having gone through the pain of the cheap lift, I couldn't agree more.
After having the lift in and operational for a couple weeks now I have a few design limitations to add to the build quality issues in the first post.
1) How high do you have to lift the vehicle to engage the first safety catch?
Some lifts, yes even some of the cheap ones, have a full length safety catch mechanism built inside the lift such that it engages from very close to the bottom all the way to full stroke in small increments of travel.
Mine? Not so much. For cost savings the safety catch is built into the rail, and the holes it engages are in the carriage. This design means that the first safety catch isn't until about 3 ft in the air. Plus it is coarse. About every 4-6 inches.
So what? Well I already found that I like lifting the sports cars up about 2 ft so I can work under the hood without bending over so much. But no safety catch is engaged at this point, leaving the Hydraulics to hold the car up. I decided to continue changing out a valve cover gasket. I'm certainly not climbing under it at this point, and it worked well enough for the couple hours I had the car in the air.
But doing so showed another corner cutting cost saving limitation.
2)Cheap hydraulic seals and cylinders. One of the Hydraulic cylinder seals couldn't hold the fluid back from the two hours that the hydraulics were supporting a Miata. A couple oz of fluid wept by the seal, and when I raised the car up to full height, those couple of ounces of fluid shot out of the vent hole across the garage floor.
Finally just today I get a hold of American Automotive, and complain about the (lack of) quality control. They do what they can. Since they don't make the lift, that means they can ship me parts. They have promised to ship me a new cylinder, and two new pulleys. Which of course I get to install.. on my brand new lift.
Their customer service is all they have to stand on since their overseas manufacturer (Qingdao Jinhua http://jinhua.en.alibaba.com) obviously has very little actual quality control implemented. Period. Unfortunately, i would rate their customer service as a C+. It hasn't made me feel any better, but they have promised to make me happy. Though what I believe that means is they promise to throw as many parts as they have to to get me satiated.
Richard
R
RichHawk
I'm still waiting for someone with a BandPak to offer to do a side by side comparison of a bunch of the dimensions. I think it would help improve the knowledge base and understanding.
Even if BendPaks low cost lift is made in the same factory as my American Automotove(Qingdao Jinhua) lift, I can imagine the quality control bit, plus the much better hydraulics alone would make it worth the extra money.
Richard
R
RichHawk
Here are the specs for my lift (XPR-10AC)
http://www.bendpak.com/XPR_10AC.pdf
Note:
We have entered the world of Armchair comparisons. Unless you see pictures of me holding a set of digital calipers on something, don't trust what you read for the dimensions from a spec sheet. I busted American Automotive three different times for "incorrect" dimensions on their spec sheets. and not just simple ones, but things like sizes of Hydraulic cylinders.
BUT as a an armchair comparison, that BendPak is not the same hardware as my cheap lift.
They both live in the same specs world of height and weight. and are both blue and yellow. But that's probably about it.
Mine doesn't have asymmetrical columns.
Mine doesn't have safety catches every 3 inches (I guess I should go measure that if we are going to get any more specific on it)
Mine isn't an over head model, and wouldn't have the padded overhead safety shutoff bar even if it was.
Thier baseplate is a larger footprint
My arms are telescoping 3 piece like theirs, but are shaped a bit different. (If the pictures can be trusted...)
They both have the drop end arms for low clearance vehicles.
(Though side note, to keep the metal part of my arms from hitting my rockers, I have to use a 2x4 under the pad, because the pad is dropped so far relative to the arm itself. but it's better than having to pre-jack the vehicle up to get the arms underneath)
They both use sliding plastic bearings for the column to carriage load support.
Their lift hardware looks all different. But the Blue and Yellow colors are EXACTLY the same shade as my colors.
I need more information on the Bendpak's Dual direct drive Hydraulics. What is it, and how does it work? My two cylinders are linked via a hose, and that one hose send pressure to both cylinders simultaneously.
It's possible the main steel part comes from the same place in China. we should look at the design of the equalizer cables and Hydraulics.
Richard
LSVLance
Peoria, AZ
Wow, I shopped AAE pretty hard when I was looking for my lift and I almost went with one of theirs. So glad I didn't after reading this thread. I went with a Greg Smith lift (Atlas) and apples to apples with the one from AAE I paid about $300 more for it. Sounds like money well spent.
It took me (a total lift install noobie) about a day and a half to get mine installed and running. I figure if I ever did another one, I could do it in about half of that time using the knowledge I now have. I had zero quality control issues on my lift, but the installation directions did leave something to be desired. Most of my troubles came from trying to get the carriages up and down while routing hoses, cables and such...them suckers are heavy. Next time around, hooking up the hydraulics and electricity would be FIRST on the list...not last.
Regarding the safety catches, I don't think mine start until the arms are about 3' up or so.
I hear ya on the release valve adjustment too...my instructions included how to adjust it, but mine still comes down VERY slowly with little to none weight on it.
Hopefully things smooth out for you soon and you can start enjoying the lift instead of fretting over it. You are gonna love having it. Hell, I used mine as a paint rack yesterday, hung a bunch of small parts I was painting up on the raised arms...worked perfectly.
BTW...I'm near KC too...up North. What part of the City are you from?
R
RichHawk
I do already love having it. it's sooo nice.
Coming down slow got a lot better once the "self bleeding" hydraulics worked most of the air out. Don't ask me to explain. AAE didn't do a good job of explaining it to me either. But they did say there was no need to bleed air out of it, even though that's what the manual says.
I'm down south in Olathe.
Richard
ronstory
Portland, OR
Richard--
I know the thread is stale, but this was a great first post. Thank-you and I'll be looking to spend a bit more money on my lift.
Ign
Butte Peak ND
So revisiting this...the link you provided lists a price of $1169.00. I realize you said shipped so did the $1500 include shipping?
They also provide a model without the "-d" on the link for $1595.00. I can't determine the difference?
http://www.americanautomotiveequipment.com/AmericanProducts-Model-TP9A-p/tp9a.htm
I love how they say you get a 220V power unit included for "free." LOL, come buy our new car and we'll throw in the fuel tank and pump for free.
Now............regarding comparisions.............I've got the BP XPR10XC. It's a clear floor and it's extra drive thru width (which might affect the beef of the arms??) but I'll get you pics w calipers all day long if you let me know what you want. Not trying to prove mine is better, just like finding when manufacturers maybe do use the same production plant, or when extra $$ really is well-spent if significant differences exist.
