Between 485 & 705 SQ/FT Denver MCM garage expansion
kmcteer
Beautiful E12! I lowered my 1976 530i and it resulted in a pretty wollowey drive. I replaced shocks with Bilstein B8s and springs with H&R Sports. I think it had a roll center issue in the front, probably needed a spindle raise. You may want to consider that if you are lowering it!
Great progress!
-Kelly
K
kwyjibo
Ok, once again I have a lot of catching up to do.
First, and most importantly, the upholstery work started a while back on projectconda. We weren't happy with the fit of some interior pieces I picked up so those will need to be made on site. So far the trim around the windshield frame, targa bar and the pieces in front of and behind the doors are complete. A neat detail of the targa bar cover are the hand-cut ventilation holes. It's not installed yet as they work on the seatbelts, but I temporarily popped it in for a photo.
Here's the charcoal carpet being fitted in the rear seat area
I'm not going to reinstall the (useless?) rear seats so the carpet will completely cover the "seating area" - like in the lightweight Carrera RS. At some point in the near future I'll make a storage compartment for the space, Porsche calls this a rear-seat delete.
I'm hoping that projectconda will be back in my garage soon because the rearseat covering and carpet are all that is left for the shop to do.
Second, I sold the E30 to a friend! We owned it for about 10 years but it's been getting little use in the last few years. Over 230k miles and it was still running strong. Here are a couple photos sent over by the happy buyer
The nice spring weather (at least in the morning) brought out a large crowd for the annual VWs on the Green show. I have a long history with VWs but I've been ignoring them lately. This show reignited my interest.
And of course I've been driving every chance I get. Since selling the Carrera last fall, the E9 has become the primary fun car, but I've been thinking about selling it also. It is strange to think that I've owned the e9 for almost 20 years, the Carrera for 15 and the E30 for 10 and they could all be gone within the same year.
As i was contemplating the E9's future and enjoying my coffee, a few guys from our local Porsche group rolled up.
The odds are always good that you'll run into people you know driving the local hills on a beautiful morning
K
kwyjibo
Great progress!
-Kelly
sorry about the delayed response
Thanks for the reply. B8s have basically disappeared as have many E12 parts. I've been discussing coilovers with a friend whose shop, VSR, sells a rather expensive but apparently excellent set.
kmcteer
That would be the way to go, could raise the spindle as much as your wheels allow. I'm struggling through the modern problem of vintage sports car handling. My 911SC has been restored with stock suspension, but is not exactly sporty by todays standards. How far does one go trying to make an old heap handle...
-Kelly
gearhead1960
-Kelly
...as far as you want to spend. I would start with either Koni or Bilstein shock and spring kit. I would also plan on lowering the ride a little. Don't make wholesale changes at once unless it's a tried and true kit from a well regarded supplier or manufacturer. It will never be cheap (relatively), but the enjoyment you get out of it is the true value to the mod.
Nolift911
Lansdowne, VA
-Kelly
Elephant Racing is your huckleberry -
kmcteer
I assume you have seen this post on bimmer forums (https://www.bimmerforums.com/forum/...ce-suspension-options&p=30094167#post30094167).
"Thanks. As a bit of an update for anyone that may search for something in the future, I think I have figured out what setup I will be going with on the car. For springs i'll be going with the B&G Lowering Springs for the E12 chassis (Part # 08.1.021). Mainly choosing them over the H&R option because 1) They are easier to source here in the US (harder to get the E12 H&R's because they are only listed in the German catalog, and not the US catalog) and 2) Because they are progressive rate. Since this is a street car and not a race car, I am somewhat concerned with ride quality.
For the shocks and strut inserts, the selection at this point in time (August 2018) for performance LOWERED strut inserts and rear shocks for the E12 is VERY limited. For the rear, the only option I could find is the Bilstein B8 Sport Shocks (Part # 24-008198). They are listed for the Bavaria/B3/E12. For the front, Bilstein discontinued the B8 Sport Insert that they used to make that was specific for the E12 application(Part # 34-193020). However, I did find another option. Bilstein makes a B8 Sport insert for the front of the E28 (Part # 34-181546), and according to a quick call over to Ireland Engineering, the E28 insert will fit into the E12 strut housing with a small spacer at the bottom under the insert (E28 insert is slightly shorter than the E12, but same diameter). Using the E28 inserts, would have to use the E28 upper strut mounts...which is a different bolt pattern than the E12, BUT...Ireland Engineering also makes a cool Fixed Front Camber Plate that has the E28 bolt pattern on the bottom, and the E12 pattern up top. Allows you to bolt up the E28 Upper Mounts into an E12, AND add 3/4 degree of negative camber.
So, looks like i'll be going that route. If any of you E28 folks have any other suggestions for lowered strut inserts, please feel free to post it. Would love to hear about other options. Will update this post whenever I get the parts together..."
K
kwyjibo
always fun to catch up with friends at last weekend's Fuelfed in nearby Boulder
I stopped by the upholsterer earlier in the week and he was working on the rear seat area
Back panel:
side panels being test fit:
He is making these panels, using the warped originals as patterns. I bought the same pieces from a well-known supplier in Europe when I thought that I was going to diy the interior, but the upholster talked me out of using them.
the front area was done when i visited the shop
mid week i got this photo:
And then on Friday:
K
kwyjibo
I stopped by the upholsterer's shop today - ProjectConda is ready to come back home!!!
The glass installer came by on Monday and was done very quickly. I really appreciate that they let him use their space because I'm sure that some of the problems he had with the rear glass install were a direct result of working in my cramped garage space. They were still working on getting a few details right but told me that it would be ready to go by tomorrow morning.
Fingers crossed that my next post will have photos from my garage.
K
kwyjibo
Very exciting. Will you be able to drive it this summer?
I hope so. My plan is to install the engine and get a test drive in before summer is over and work on accessory items, like door glass, windshield wipers, etc. over the winter. But of course, one thing that has been made very clear over the past few years on this project is that even straight forward goals can hit time-consuming diversions and end up taking much longer than first planned... but that won't happen this time!
To follow up on my previous post: ProjectConda made it back to the garage
I immediately went for the serotonin hit and test fit the seats (they'll need a little work to bolt in)
And put in the luggage straps that have been sitting on a shelf for the past few years. You can see the "RS-style" rear seatless carpeting that I had installed. Normally there are lower seat pads and folding back rests. I plan on making a lockable storage console in place of seats.
I'm waiting on a couple parts that I forgot about to begin installing the motor and transmission, in the meantime I'm working on the fuel system
K
kwyjibo
a quick weekend update -
I finished installing the dash components (minus the radio which I don't have)
Access to the fasteners for the glove box door was a total pain. As was the last nut holding the knee pad under the headlight/ignition switch area.
Last step on the dash was making sure that the lines of the aluminum trim were aligned
The seats are finally in - at least for now. I'll need to remove them later once I decide out how to mount the seatbelts. I went with these replica Recaros by Vintage Seats because the real ones have fiberglass shells that are now over half a century old.
And now for the whiny part.
USPS has lost my order of, among other things, engine fasteners.
Also, I'm getting way too much practice with these things
K
kwyjibo
I had some friends over this morning to hang out in the garage, eat donuts and talk cars.
First I moved the BMWs over to a neighbor's driveway
then the cars slowly took over the street
and to prove that it wasn't just Porsches
groovy baby!
and of course Kimo kept a close eye on everyone
Big thanks to @RocketJohn for the photos
K
kwyjibo
quick ProjectConda update - I hope to be bolting in the engine soon
but I forgot about how unfinished the car was when I sent it off to the upholsterer. I rushed to get it rolling out of the garage on it's own wheels so now I'm going back to install a few things and recheck everything else
My friend's Alfa SS is just too pretty to not share again.
He stopped by on a shakedown run as he's busy getting it ready for this year's Colorado Grand. I thought I should do my part by making some decals for him to give out during the tour.
IMG_0258 copy.jpgThis image originated from a joke made by @RocketJohn about how our friend and his father (both not small people) look driving in such a small car
Last weekend was the annual Italian car show, Automezzi. Lots of nice cars but one really stood out to me:
Back in the early 80s one of the first models I made was of the Lancia Stratos.
Sidenote - I spent all my paper route money on model kits. I thought that I had saved the instruction booklets but recently only found these.
The Tyrrell P34 six wheeled car was the first "real" kit I bought. Strangely I didn't connect the dots until I saw this photo a few years ago from a sale of Jody Scheckter's cars that he drove my favorite childhood cars (although to be fair, the Wolf WR1 was the only one where I used his livery)
gearhead1960
Back when I thought it was possible to be rich like Elon, the Stratos was going to be in my stable of cars I would have. My recollection is that it shares the same V6 as the Ferrari Dino. Alas, I never got close to Elon…
K
kwyjibo
@gearhead1960 Yes, the Stratos used the Ferrari V6. I definitely would get a Stratos if I had the means
I had an interesting week. I have some friends that were coming out this direction from the East Coast for the BMW Classic Car Club tour and agreed to take delivery and store some cars. The official tour starts in Salt Lake City, but they wanted to add a few extra driving days and start from Denver. The delivery started off well, with some interesting cars in the trailer. The E9 on the upper deck previously belonged to a friend and I haven't seen it since moving from New England
But, I'll spare everyone the later, more painful, details which included delivery of a wrong car. Here's a view of the street in front of my house. Special thanks to local friends and neighbors for letting me store some cars around town.
The morning of their departure, I went to pick up one of the tour-ists who came in the night before. Since he also owned an E9, I thought it was only appropriate to pick him up in mine. I noticed that I stopped almost perfectly centered on the lobby and took a quick photoIMG_0304 copy.jpg
I invited some local friends over the morning of their departure from Denver for a quick hello/good-bye. In honor of the guests, they came in their BMWs
and then there's always that one friend
