Best Lubricant for Kennedy Friction Slides
MrPink
Bridgeport,MI
Ok so i have a 40+yr old Kennedy tool box that i will be removing the drawers on to clean it up and lube the slides, what is the best way to lube the friction slides? And what brand of lubricant do you recommend?
PCustoms
VT
Does Kennedy need a unique lubricant?
There's also a thread about matco too...
AEAdam
SE PA
Maybe. Are those ball bearing slides in those threads, or friction slides like Kennedy?
Buckgnarly
VT
He's talking friction slides, not ball bearing or rollers.
More old history
tool_scrounge
Southern California
Kennedy used to recommend plain old boring paraffin wax. The canning kind. Don't use beeswax.
+1 on this . It works amazing well. Just clean off all the old lubricant before applying the wax. Just take a block of wax and rub it on all the slide , drawer and toolbox slide surfaces.
AEAdam
SE PA
I feel like you should separate lubricity from corrosion prevention. I’ve tried a couple things on mine. Not sure which is best. I used candle wax on one of them (52611). Wd40 on a few and the wd40 dry film lube with teflon on others.
in my case, the finish wears and I get rust
Schurkey
Anything that traps and holds dust/dirt/garf/garfelderfarb especially via static electricity is a non-starter. Wax sounds good to me. MAYBE there's some mild issue with dirt embedding in the wax, but that's still better than an oily mess with an attraction to whatever **** is floating around in the air.
alinc100
Dearborn,MI
Ohio Andy
Columbus, Ohio
I have no good answers, but someone mention paraffin. I am reminded of a bicycle spray chain lube that I think when the fluid evaporated off left it a waxy film on them. Have not seen or used it in years but it might be worth looking at
Firebrick43
West central Indiana
Years ago when I had a Kennedy taco cart that I rolled around the plant I used synthetic grease. It worked as well as lithium white grease but didn’t get hard after a while as white grease did.
I think it was SCH 100 but that was just because we had it. Super lube would work as well and a lot easier to obtain.
tool_scrounge
Southern California
I have no good answers, but subscribe mention paraffin. I am reminded of a bicycle spray chain lube that I think when the fluid evaporated off left it a waxy film on them. Have not seen or used it in years but it might be worth looking at
White Lightning Clean Ride Self-Cleaning Wax Bicycle Chain Lubricant​
works quite well on roller slides. I like paraffin better for friction slides
