Old Man Roger
Palm Coast Florida
Well, this didn't happen today, but last weekend I finally fixed a long-standing problem with my Skandic 900 ACE. It would occasionally rev up without me touching the throttle. This happened both at idle and while riding. And when this happened the speedo would go crazy, like reading 112 mph while sitting still, and then coming right back down to zero. And at high speed or load the speedo would start bouncing up and down and the engine would bog down, as if the ECM was trying to adjust mixture based on speed. Over the course of a year the problem got progressively worse, none of my buddies had helpful advice, none of the local shops had experienced the problem, and my casual troubleshooting didn't help matters. Frankly the only people who believed me when I described the problems were the ones who had stood next to my idling machine and observed the speedo when it acted up - which it didn't always do.
Finally I got serious and tracked the issue down to the speed sensor, which is located in the gearbox cover. Of course Skidoo won't sell you the speed sensor by itself - much to my disbelief I had to order a whole new gearbox cover for $200.
Here's the new cover next to the old one.
Here's the outside of the two covers. The speed sensor is glued into a channel, then covered with an aluminum strip. On the old cover, you can see a dent right where the punch is pointing. I believe the wiring was probably damaged there; I've no idea how that dent got there.
The inside of the gear case - you can see the four little magnets on the drive shaft that actuate the speed sensor in the cover.
The only tricky part was removing the shift fork from the old cover and transferring it to the new cover. Two roll pins hold the fork onto the shaft that passes through the cover:
Getting the fork out was easy enough, but I needed four hands to install it in the new cover; one to hold the shift fork steady, one to hold the roll pin in place, one to hold the punch, and one for the hammer. Despite my best efforts I couldn't get a pin started. It didn't help that I don't have any starter punches, and my pin punch wasn't quite the right size.
Finally I had a little inspiration: I carefully taped the roll pin onto the punch. That made it a three-handed job and after a few tries I was able to coax my left hand into doing two of those jobs at once.
Off to the woods for a test run, and to replenish the cabin with firewood. Such a relief to have everything working right again!
Oh, and I'm looking for ideas on what to do with the old cover. Best idea so far is to turn it into a lamp. :)
Never seen one before, but that looks like one tank of a sled.
Beerhippie
Far NE Oregon
FFS! Between the time I took that picture and the time I got out there with the forklift, someone had run over ANOTHER ONE!
It's full daylight and a little early in the day to be impaired....
Anyhow, they're gone now. If I can get the no parking marks off, I'll lay out one more set of parking spots there. The bollards were originally there to keep people from blocking the truck lane going back to the loading dock. We built a new access road a couple of years ago, so delivery trucks no longer go in or out through the parking lot.
kaymccampbell
Upstate New York
How about pulling the old speed sensor out and repairing it? That way when you run over your next stick or whatever, you'll have your replacement ready.
Beerhippie
Far NE Oregon
I got the power windows of the Brick working again! I took everything apart and tested everything and determined there was nothing wrong. Put it back together and tried the windows: Nope. Took everything apart again, re-tested: still nothing wrong. Try the windows again...
THEY WORK!
I hate power windows.
Now I have to stuff all this ****
back into the tiny space where it lives.
Motorman55
South Jersey
Did a trial fit of all the copper and brass weathervane parts to the 2 pc black steel rod and adjustable ridge vent mount. Everything is ready to go. Stainless screws, drill and bit, screw drivers, level, clear silicone caulk, grease, ladder.
Only problem I forsee is that I might have to cut down the length of the lower 3/4 steel rod. I'll have to install the whole weathervane, come down from the roof and look at it from the ground perspective. If its too tall, I'll have to go back up, take it all back down and shorten the 3/4' rod effectively lowering the whole weathervane.1775344510763.jpeg1775344320157.jpeg
rktinc
Midwest/USA
Waxed my new (to me) work sedan, washed and gassed up my wife's SUV monstrosity, and started/jumped a few vehicles in another storage site prior to moving them to my newly completed room. The "Car Salon" (as I have been amusingly referring to it over the last few years). I can finally starting to fill it with my modest collection of junkers. Now on to the front and final portion of the remodel.
bugnut
Central Ohio
Happy Easter everyone! Eat some chocolate!
Friday, spent a few more minutes (more like hours) researching tax stuff, did not understand nor could the interwebs help, so a call to a professional and turning the taxes over to them. Load off my plate.
Saturday out to the shop, again pleasant weather door open move things outside. Started rearrangement and culling. Made piles, cleaned up were a mouse had take residence for a while. All better returned things going back in neatly arranged. Felt much better, like a therapy session.
:eyecrazy: :rant::twisted::twak::tantrum2::soapbox: Don't get me started...
Sidebar on taxes--1st time I didn't have all the information till April 1. Then couple new forms required, not familiar or comfortable trying to do so pros gonna help 1st time ever.
As for paying taxes, I'm in a small camp, don't mind paying more than last year as usually income has to go up.
rollinlower
Rogersville TN
Happy Easter ya'll, not much work done this weekend, went to a buddies homesteader flea market, got asked to help build a "tree house" house next weekend - volunteered to dj and volunteered the oldest male child for a couple hours grunt work, came home made a carb cleaner stud and now waiting to see if mike finnegan is putting out a video this week while drinking my second coffee of the morning lol
Fordguy1964
Houston County, Alabama
Been down but not completely out. I injured my right elbow at work getting down from a scissor lift. Didn't see that the steps were bent and the bottom step was bent under slightly. Foot missed the bottom step and I slammed my elbow into the railing trying to grab the railing and stabilize myself. Being right handed this had not been helping my projects. I go in for an MRI next week. They tried to pull some fluid out last week but it has gotten too a point where it is not getting any better.
In the meantime I finished up with my body work and paint spraying on my Sports Coupe. It is amazing how much more difficult things are when you're using your non dominant hand.
The wet sanding and buffing will take forever with one hand.
Fordguy1964
Got this ready to go on the rollback at the "beginning " of the week according to the tow truck driver, maybe now I'll actually be able to clean up my garage taking the total amount of vehicle projects down to 3 wooohoooo
That looks like a nice project. If you're getting rid of one that nice I'd like to see the ones that made the cut. What was your criteria for getting rid of this one?
rollinlower
Rogersville TN
It's a buddy of mines I just put a new wiring harness in it, 3d printing a gauge pod for a iPad mini, built a main wiring panel (so he can't hook up the battery backwards again). The other projects consist of a twin turbo xtreme blazer, a streetable Dakota, and a 01 ram lol
Kent_B
MI
Well, yesterday actually. I bit the bullet and moved the snowblower to storage for the off-season. I discovered that the battery on the lawn tractor is dead. I'll probably put a charger on it later today.
Later, my daughter's partner and I put a trailer hitch on my car. Just bolt-on but some quality shop time. She doesn't come from a wrenching background but is enthusiastic and not afraid of new things. I'm not sure that project counts for anything because no additional trips to the parts store were needed and nobody bled on it.
66HertzClone
Long Valley, NJ
THEY WORK!
Just how many of those Scotchlok things are nestled in that mess?
Today I turned the leather washer inside out and it works fine until I can find a replacement of sorts.
That often works for a while - how long depends on the old wear and what it was oiled with. longest life on pump cup leather is with neatfoot oil ( not the synth/blend stuff most are pushing these days...)
If no one has a replacement, you can make these easily enough too. Google "making a leather pump cup for a lantern" and making a forming setup can be done with many materials. I even used the pump itself to make an oddball size once.
esben57
Sheffield. England
Thanks Outlaw. Have a couple of ideas and there are some washers on line that look suitable. Needs to be 3/16" ish or 4 - 5mm thickness.
Beerhippie
Far NE Oregon
A metric **** ton. I'm not even sure what the hell they're for. They don't appear to be splices, but the wires in them are stripped. They micht be for test points? Looks like they'd take a male spade lug.
But the fuse block is back in and it ain't coming out again without a damned good reason.
Not only do the power windows now work, they go up and down much faster than they used to. I was careful to put some pressure on every plug that was attached to the fuse block, so maybe one was making poor contact.
Now I'm going to run down to a local gas station and check out a Subie engine that's sitting abandoned in a shipping crate out back. Here's hoping....
Old Man Roger
Palm Coast Florida
Battery tenders are cheaper than batteries. :thumbup:
SMOKEYBEAR
Confirmed trim relay part numbers on the Mercury. The up relay got stuck open yesterday on the water pulling up to the ramp. Disconnected the battery to keep the electric trim motor from running. Maybe a random anomaly, but it would have been larger problem in a different location. I'm going to replace both the up an down relays.
The trim relays issues had me looking over the outboard and found some play in the steering. The tilt tube nuts had backed off, more that 1/4" play each direction. Re-torqued the nuts and adjusted the end stop bushing and it ready to go again. I'll add them to the list of things I check.
Relays and spark plugs are on the way.
Beerhippie
Far NE Oregon
I checked out the free engine. It's an EJ25, but it's the older DOHC, while mine is SOHC--rumored to be much more reliable.
All I really wanted was the alternator, if it would fit my engine.
Not one, but two alternators! I'm fairly sure these will fit my engine, too!
That's the stock alternator for a '99 Impreza EJ25.
I can't seem to find the difference between the AA 450 and the AA 520, but both appear to be 90A and are listed for the Impreza/Forester '99-05.
Just wish I had some way to bench-test them. Bearings feel good, but that's about as far as I can go. Auto parts stores are closed, of course.
Now to see if I can swap out an alt without removing the entire exhaust system and heat shield.
GreenIron
A bit north of the GOA
In the garage shop today, I set up a table for the wife to fry shrimp, catfish and french fries. :)
When frying foods, we usually cook outdoors or in the shop, as to not smell up the house. (y)
Light rain has been falling all morning so it's a good place to cook and hang out, sipping a couple cold brew with my son. :D
micromind
Fernley, Nevada, about 30 miles east of Reno.
Been down but not completely out. I injured my right elbow at work getting down from a scissor lift. Didn't see that the steps were bent and the bottom step was bent under slightly. Foot missed the bottom step and I slammed my elbow into the railing trying to crab the railing and stabilize myself.
What?? A scissor lift with bent steps??? I've spent millions of hours on them and I've never seen bent steps........lol.
The first thing that needs to be done to every new lift is find something solid at about step height and ram it a few times......then the lift is ready for use.
bmwrd0
Beaver Fever Oregon
Spent time tracking down each and every reason that the spindle on my WWII era Logan/Wards lathe wouldn't turn correctly, and so far I have found a slight burr in the bull gear woodruff keyway, a dust shield that had a dimple in the face that pushed the the clearance out of spec, and so on. Trying to put together an 80 year old machine tool that was probably disassemble with brute force is... an experience, to say the least.
Beerhippie
Far NE Oregon
@Beerhippie: You might check one of the Subaru specific forums. I don't know the difference between those alternators but I bet somebody does.
I got the idea from The Samba Vanagon forum.
That's the alternator from a WRX installed on an EJ25 from an Impreza RS--110 Amp vs 90 Amp. The extra headroom is comforting. No modifications needed.
I'll make the home-run wire to the battery for the sense after lunch. I need to get a fuse holder first. The alternator is currently outputting 14.7V, measured at the battery.
I now have two spares--one needing a rebuild--plus the one that's in the mail, which I'll be returning.
Snip's
MY 2009 JCW MINI Cooper rear (Boot?) badge was showing some sun damage to the red inlay paint...
Used some dental floss to saw through the adhesive tape to remove the badge
Had a bottle of Tamiya Italian Red lacquer I used for some inlay paint work...
I just realized all the black inlay paint is missing from John Cooper...
I'll need to get a bottle of black lacquer, before I can reinstall it...
