3d Printing Offshoot Thread: WHEELCHAIRS FOR TODDLERS
mike93lx
Richmond, VA
If starting from scratch, what is the recommended printer?
People are most likely to suggest what they have... So a Bambu P1S or even better, a P2s. Either with an AMS
They simply work out of the box, no fiddling. General guidance is that if you want a printer and not a project, get a Bambu.
If you want to swing harder, a H2S or H2D
mike93lx
Richmond, VA
Me neither. Just put together the next batch, now with velcro too. 1000 units. sadly the cost went up slightly. instead of 25 they will be 30 this round.
Thanks for adding the velcro.
Even at 30, this is a ton cheaper than what people have been doing.
Cruzan80
Denver, CO
I don't know if I got a bad batch of PETG, or what. The wheelchair prints keep having issues for me (I generally run PLA and ABS without any issues). X1E's, filament was dried over 24 hrs then directly into the AMS with Dessicant (and I am in CO, so not usually an issue). Getting bad surfaces, walls not appearing at all (just infill), etc. Honestly, printing worse than 75% of various types I have tried before.
Creality Purple PETG (Bambu refill style). Anyone else have experience with this stuff?
mike93lx
Richmond, VA
What Petg setting are you using in bambu studio?
I've run generic Petg, bambu Petg and bambu Petg HF and all have run well, especially dry
Cruzan80
Denver, CO
Interesting. If you are just seeing infill, it feels Mos likely that something is wrong in the files. Did you try fresh downloads?
Not yet. One worked, but it ran out and I pulled it before I noticed. Then two with bad wall issues, and the last one has surface issues. Can take pics tomorrow, and will try redownloading.
mike93lx
Richmond, VA
I love the color and shine on the wheels. What filament is that?
Sunlu tpu silk in teal. It's a bit firm for this application and I think silk is the cause. Its OK for the tires but it is unusable for the straps
SUNLU TPU-Silk 3D Printer Filament, 98A TPU Filament 1.75mm, Glossy Silk Surface 3D Filament, Flexible 3D Printing Filament, Dimensional Accuracy +/- 0.03mm, 1kg(2.2lbs) Spool, Light Blue https://www.amazon.com/dp/B0DFC3DN1M?tag=atomicindus08-20
mike93lx
Richmond, VA
That's beautiful!
I'm hoping to get one started once our house returns to normal - I've lost my office/print room for a bit.
Thanks. The materials are all from @jeepxj and the design is all Make Good.
I made my own spreadsheet to keep the build organized and to plan out timing/materials. If you want it, let me know when you are ready to go.
ptt49er
Rock Hill, SC
I've been following along as you and Jeepxj have discussed these over the past several months, you guys are awesome.
Thanks for the offer on the spreadsheet! I'll very likely hit you up when I get started!
