signcrafter
- Joined
- May 9, 2012
- Messages
- 12,508
Getting ready to start running electrical to shop equipment and wondering if MWBC are allowed or are a bad idea? In one area I have a tire machine(9 amps), balancer(can't check right now but think it's around the same 9 amps), and parts washer(11.9) amps, and then a couple outlets for 5" hand grinder and anything else I might need. I'm just a home shop guy so will never be using them all at the same time. Only time would be using the grinder to clean a rim while the tire machine is spinning. So thinking two 20 amp circuits would be good for this area. Everything is in a row along the wall and sub panel is roughly 30' from the first machine and I will be running conduit and THHN to this area. Is running a MWBC a bad idea to share the neutral? It's not much in cost savings but trying to plan out my conduit runs and wire fill. I have just started the planning so nothing set in stone, but if I figure it out and there is room in the conduit I might be able to run another circuit for something like compressor that is close. Compressor is 240 with F.L.A, of 15 amps so I have had it hooked up with 12 gauge wire and 30 amp breaker, but if I ran it in same conduit then I believe that would be 4 power carrying conductors and need to derate. Starting to get over my head but if I understand the derating thing it says #12 at 90 degrees is 30 amps and for 4-6 conductors, think this is only counting power carrying conductors and not neutrals and grounds? If so then 80% derate would still allow 24 amps?
Sorry for all the rambling but tried to get all the details out. Actual questions are below,
Is a MWBC allowed and would it make sense to do in my situation? Or since it's a short run and I believe I have room in the 3/4" conduit just pull another neutral?
Can I run two 120V/20A circuits or one 240V/20A MWBC in 3/4" conduit and then also run my compressor wiring in there? Think the wire fill would be fine but not sure about the derating part for number of conductors? Thanks
