Bamacruiser98
- Joined
- May 1, 2024
- Messages
- 106
duplicate post
So I should disconnect at the bottom of box and reattach to maybe the switch mounting screw?I'd make sure that metal frame is connected to the ground
That’s what I did the first time but no light but I figured out that the bulb base wasn’t deep enough inside of the socket, I fixed it. She’s up and running now. Thanks fellasFind an inconspicuous place on the inside of the lamp and drill and tap a hole for the ground and attach it using a crimp on ring or fork terminal. You might even be able to use the screw in the second picture. If not, ground screws are cheap and available at any box store and probably a hardware store; those are 10-32.
If and where the ground is connected won't have anything to do with the lamp working or not. It's there to trip the breaker in the event of a fault.That’s what I did the first time but no light but I figured out that the bulb base wasn’t deep enough inside of the socket, I fixed it. She’s up and running now. Thanks fellas
I’m currently finishing up a lighting project. Let’s just say it’s a type of floor lamp. I’m using an old push button light switch to control the lamp. I have a modern three wire cord(hot, neutral , ground) coming into the switch (black cord) and a two wire cord(the white cord) going out of the switch to the light. I currently have the ground from the black incoming cord attached to the bottom of the switch itself and it works but is that the best place for it? There’s no obvious ground point on this switch bc of the age. Just making sure this is good. I’m just putting this together with stuff I already have. Thanks for info.
