GrayFlattop
Chicago
Sanded (many times) some newly built drawers for the shop, then sprayed them AGAIN with Polyurethane. The first go around was with a Minwax water-based poly. Complete ****. I don't know if it was the rattle can tip or the mix or what, but it dried dusty and pebbly - almost like a conventional spray gun with WAY too much pressure. So I sanded it all down the next day and then used Varithane water-based poly MUCH better - exactly as I would expect. Sadly, none of this stuff is cheap @ $13/can.IMG_6698.jpeg
Normally I would have used Danish Oil, but I wanted to start using the drawers sooner - my mistake...
All better now.
cody1325
Southwest Virginia
The expected GJ reply is “time to buy a welder and learn a new skill!!” So there it is lol. I love weldering. The world opens up to you but you gotta have the space for a decent fab area and storage for all the stuff. Annnnnnnd then you could build a massive shop to keep it all in lol.
Good thing is that the farm shop here has a welder, a 1986-ish Lincoln IdealArc 250. American LaFrance operated here in my town from '86-94, and they only used that model in the plant (plus the trucks all had stainless bodies in an attempt to compete with E-One's new at the time aluminum body). I know it's welded some pretty thick steel, so it's definitely more capable than one of those small HF welders. Also got a plasma cutter Granddad used a couple of times.
I am reworking the "fabrication" part of the little farm shop, however. The only bench in there is a tiny plywood job that's rather rickety. I'm thinking about getting a good-sized welding table to replace it.
Skyman
Central Maryland
Misdiagnosed what I presumed was a dying washer pump on the Blazer. Nope. Turns out the hard plastic line between the two discharge nozzles had split lengthwise for the majority of its length. Apparently along a seam, and nearly invisibly. I belatedly discovered that it was dumping the juice under the hood, rather than onto the glass. I now have a spare pump. And replacement line set on order from RA.
Changed the oil and filter while I had it in the garage, and cleaned the MAF to see if that'll put an end to the occasional MAF error code that been intermittently triggering the SES lamp.
Beerhippie
Far NE Oregon
Did some more organizing in the Brick. Took it for a cruise down the highway to Wallowa to scout the local junque store for things that might help with the organization. Pretty much struck out on that, but had a nice drive. I'm still loving the looks on peoples faces as I pass them at 75 in a Vanagon!
Sanded down the roof rack fire/latrine shovel and gave it a few new coats of BLO. It should be good for another year in the elements. Touched up the edge while I was at it. Debating trying to cut the welds on the roof rack tool holder on the Toyota to transfer it to the Brick. I didn't make it easy for myself when I welded it on.
Crazyjake8493
Upstate NY
Built a dolly for my ballast barrel, then took it off the tractor. Took the forks off the tractor, put the bucket on. Put the post hole digger on the 3-point, greased everything up.
Cleaned for a bit, got a bunch of stuff to go in the dumpster tomorrow and a few tools to give away at work.
Used up some EMT scraps and made hangers for a few things, like a roll of shrink wrap that kept rolling around on the floor because I didn't have a good spot for it.
BonzoHansen
A mixed weekend. Paid my state taxes. Restaurant screwed up all our orders Saturday night.
Got the bathroom almost done. Just need a light fixture and a mirror. Nothing like a new toilet to make the day better.
Got the replacement rear for my k1500 cleaned, painted and new axle bearings installed. Gear oil smells lovely lol.
pancholasvegas
Almost everything aligned this weekend for some good time in the shop -
I had some time off work due to taking some elective machining courses at the community college this week, so I had some extra garage time. With the major rust repair handled, it’s getting time to put all of these panels together so the left side can be handled as a single unit.
Threw together a quick stand to hold the upper panel while the adjacent panels were clamped and fitted.
This served as a reference for the adjustments that needed before plug welding the pieces together. It was taken apart multiple times and adjusted.
Enough eventually gets to be enough and you have to start.
The factory spot weld holes were used as much as possible throughout as it was put back together.
If you’ll recall - I earlier mentioned that the flanges were coated on the insides with SPI epoxy primer. Before the welding is done on these spots, I use a modified drill bit to clean the primer off the inside of the plug weld. The outside top is cleaned as well. I learned this trick from another forum member - works great.
I got about 90% of the plug welds done before I ran out of gas - and it’s Sunday. Bummer.
Not to be defeated - I took some time to build a matching stand for the opposite side and do some test fitment to see if I screwed the pooch on this whole thing.
Crazy enough I think it may work.
Enough heavy lifting for the day, I had gotten tired of cleaning the flash rust off these wheel wells for quite a while - took advantage of the weather and sprayed a couple coats of epoxy on them - they’ll receive more attention down the line, but some epoxy is good for before they get plug welded to the new floor.
Miss the Pontiacs
Saskatchewan Canada
Added some slat for mounting some of my phone collection. Repaired a couple old crank phones RX handset devices
and switch hooks. Cleaned up a couple of dial phones because I know cleaning them up won’t happen once they are screwed up to the wall.
I know seeing the pic now one phone looks crooked, looked fine when I originally mounted the damn thing.
bugnut
Central Ohio
Work on the Ford 2000 brakes continued. The stuck clevis it finally broke, new part on order, drilled and tapped to clean the stuck threaded rod out of the clevis to salvage it as I only ordered the rod with the welded end. Waiting on parts, liberal application of anti seize to be applied. Need some 3/8-24 nuts and lock-nuts.
kaymccampbell
Upstate New York
Not going to weld the bolt onto the remains of the connecting rod?
GirchyGirchy
Central Indiana
Don't let animals get to that - it will kill them, not pleasantly.
It's already been dumped into an empty oil container, just took the pic while waiting for the engine to warm up. The four-legged helper only watched from the storm door.
I never make a mess with oil changes, but coolant changes are another story.
Beerhippie
Far NE Oregon
It is 78 degrees right now in the Detroit area.
It was eighty two weeks ago and 75 day before yesterday. Spring around here (4,000' ASL) keeps you on your toes!
The rain for the last two day, which escalated to a torrential downpour yesterday afternoon and night and then turned to three inches of heavy, wet snow found leaks in the roofs around the brewery and pub I never knew existed.
I've tried various tube goods to stop the leaks I did know about with rather poor results, so I bought a gallon of this stuff:
and applied it just now when we'd had an hour or so of dry and sunny. Time and weather will tell. This stuff is just thin enough to flow and, in theory, get right down into the leaks.
SMOKEYBEAR
Spark plugs and oil pump inspection on the Mercury after a few outings. Used my new spark plug tool one of ya'll posted on here..works great setting the gap. The Mercury is very particular to plugs and gap settings.
rktinc
Midwest/USA
Productive weekend! Work has started in the front, retail portion of my build. Found a great vintage sign for the workshop that fits perfectly with the 1901 history of the building. Perfect sign and spot for it. spent a little time using my new, cheap battery orbital buffer to start removing scratches from my black Silverado.
