Between 705 & 1200 SQ/FT Mixed Grill - From London , England - GRIZZMAKES world
G
Grizz1963
Rochester, KENT. UK
So…….
Clear lacquer runs.
100% my fault for being in a hurry, but also, painting outside in a mix of sunshine and shadows.
So you can’t always judge how wet the panels are.
Honestly, I think I have done pretty well with the limited amount of screw ups I had throughout this process, considering how little I had known and how much I tried and pushed my luck.
So the next step once I had the runs in the clear lacquer, was to “razor blade it off” using a variety of blades, in my case a used Stanley knife blade, remember that mostly we use the front 5% of the blade for cutting. So you have 80-90 percent of the straight edge still super sharp and unused.
Once the lacquer dries, an hour or so later, you cautiously slice off to droplets in a few passes so that there will be a bit of material left over to block sand with 600 grit or finer.
Followed by thorough cleaning and then a tack coat and another wet coat.
I did all of this with excellent results.
Final step would be to wait a few weeks and to then wash the car thoroughly and put a polisher and some rubbing compound over it repeatedly to smooth it out more, followed by various polish options.
I am hoping the buffing takes out more of the irregularities and the remaining undulations in coat number 6.
Overall, the whole car has a minimum of 6 coats and the roof, hood, trunk and bumper horizontal surfaces all have at least 7 good coats to work with.
Once I had allowed coat no 6 to dry it was time to unmask lights, sills, side repeaters, reflectors, mirrors (which are still in original paint) and of course the glass all the way around and all the doors, shut lines and more.
A job that took me about two hours.
Parts of that job again done with a heat gun to soften glue so as not to damage any paint.
Some of the bought masking film and masking tape, also left loads of glue and residue on glass, rubbers etc.
This necessitated the use of Turpentine or white spirit to shift.
After this, more soapy water to wipe that residue again.
Spider does show depth of 7 coats of glossy lacquer.
And still we are not done.
Razorblading lacquer runs.
gman007
West Michigan
Rian
In any project, fumbling is part of the journey. How well one recovers from the fumble is a good indication of one’s skills and mental fortitude.
Ernest Hemingway famously defined courage as "grace under pressure”
You definitely have what it takes and the grace under the pressure to deliver a great work of art at end of day despite all the obstacles and challenges. Others under the same pressure might throw their hands in the air and surrender but not you.
Well done and thank you once again for all the tips and tutorials.
Now to the subject of the chemical reactions of clear with the paint. Do you think if the weather was warmer and there was longer time between applying the coats ( to let the layers cure well), would that help to avoid the reaction?
Bob Heine
Boca Raton, Florida
People go mad if animals look at anything that’s been deemed unhealthy, dangerous, poisonous or harmful in a residential environment.
Rian, apologies for not keeping up. People go mad when they learn Liane has reached the age of 82 on a three-staple diet: Caffeine, nicotine and chocolate. Because she still smokes cigarettes our doctor sends her in for a CT scan every year -- only to discover the nodules in her lungs have not changed in 15 years. Ninety percent of her hair is still red (but darker than it was) I have photographic proof she's doing better than her veggie munching partner (she tells me chips and dips don't qualify as 'veggies). Sixty-four years takes a harder toll on some more than others.
Bob Heine
Boca Raton, Florida
Quick question to those who are skilled at street fighting or playing dirty.
Do I even respond or reply to this guy??
From those pictures that's about $1999 too much for that. Not being a jerk, but it looks like it's in horrible shape.
Rian, I like to think of myself as a lover, not a fighter.
During my recovery, Liane and I made friends with a mason. His father took him out of school when he was nine to help doing concrete block work. I met him when he was 22 and saw him pick up four blocks in each hand and set them on the scaffold above his head. He was as wide as he was tall and worked part-time in a junk yard pulling engines from cars too buried to get a machine near them. He just bolted a chain to two places on the top of the engine and lifted the damn thing out.
One Saturday night we went to a dive bar with Nickie and his wife. We were having a wonderful time and the hours flew by. I ordered two 15¢ beers for Liane and Nickie's wife and two minutes later the bouncer walked up to us and told us the bar was closing. Liane told him she would leave when she finished her beer and he told her to get the hell out. She said OK and poured the beer on his shoes. He made some nasty and profane remarks to her so skinny me stepped up (with Nickie hiding behind me) and raised my artificial arm as high as I could and brought it down hard on the ubiquitous Formica table next to me. The table didn't break but there was a significant dent in the top. I told the bouncer he had two choices: "You can beat up a cripple or be beaten up by a cripple but either way I expect you to apologize to my wife" and he hesitated for two seconds -- the time it took Nickie to step forward to my side.
My more common use of the hook was to lift extremely hot items off the Barbie without burning myself.
Bob Heine
Boca Raton, Florida
Bob Heine
Boca Raton, Florida
Polarising is good.
Shows people are thinking.
Rian, I was given a failing grade on a kindergarten assignment because I thought the car I was told to color would look better if each panel was a different color. I was nowhere near as talented and creative as you because I also failed to color inside the lines consistently.
I love what you are doing and it reminds me that people cling to their vehicle brand and color as if there were no other options.
G
Grizz1963
Rochester, KENT. UK
The Oldsmobile is not yet done.
But it is unmasked and I have driven it.
There are a few more jobs to do.
Saturday morning I got the B-Pillars that are aluminium, cleaned up and got some etch primer on there.
Followed by three or four coats of gloss black.
Of course rain and wind, once again screwed up my day.
But it looks great.
Those little jobs.
Coolabah
2nd Floor, 3rd on the Right,Narooma, Australia
So…….
Clear lacquer runs.
1) 100% my fault for being in a hurry, but also, painting outside in a mix of sunshine and shadows.
2) So the next step once I had the runs in the clear lacquer, was to “razor blade it off” using a variety of blades, in my case a used Stanley knife blade, remember that mostly we use the front 5% of the blade for cutting. So you have 80-90 percent of the straight edge still super sharp and unused.
3) Final step would be to wait a few weeks and to then wash the car thoroughly and put a polisher and some rubbing compound over it repeatedly to smooth it out more, followed by various polish options.
( I added my numbers 'cos I'm too lazy too figure out the right way ???)
1) yep, been there ! We don't have a spray booth , if we did we would both have exceptional results. Flawless I say !!
2) What works for me is getting a new single edged razor blade , round the 2 corners off on a sanding disc and go from there. One blade will last for years (Where I live they are much cheaper than the Stanley knife blades)
3) If the clear coat is not 2k, be careful of using anything other than elbow grease ( ie reconsider power polisher) , most clearcoat brands I've used are VERY soft
Looking good !
littlebean
Do we show the FIRST REVEAL next ?
Or do we continue to discuss further PARTS ACQUISITION and show that?
what sort of a choice is this - both obviously................:ROFLMAO:
from all the part of car pics I'm really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really looking forward to seeing the whole thing
hmmm might not be enough reallys in there to convey my enthusiasm :cool:
thomfr
The Netherlands
Sorry Rian,
I should have asked you before but I was out of town last weekend investigating:
and obviously
But also:
And
We where in Dublin last weekend. What a lovely city with very friendly locals, good food en even fresh but dry weather. But (maybe due to the fuel blockings in the city) almost no classic cars (only saw one MG B GT parked in a front garden while returning to the airport) Highly recommended to visit!
G
Grizz1963
Rochester, KENT. UK
Sounds like you would be happy with both.
Stand by for 48 hours.
Maybe less
G
Grizz1963
Rochester, KENT. UK
Sorry Rian,
and obviously
But also:
And
Very nice.
Glad you didn’t contact me to join you, I tend to avoid cities and tourist attractions.
But looks awesome.
G
Grizz1963
Rochester, KENT. UK
Just bought these.
Get my drift?
bugnut
Central Ohio
Oh look new parts.
PS you have done it now, yesterday stopped at the hardware, came out Buick, similar to the freshly painted euro version parked next to me. Red base coat, well various paint schemes started waltzing thru my head!
THANKS
gman007
West Michigan
:+1: What he said
Oh look new parts.
THANKS
:+1::+1:
G
Grizz1963
Rochester, KENT. UK
ya think?? - OH YES
Some of you may have been following the evolution of my Oldsmobile in my random builds thread 😂😂😂😂😂
Question is………
UK based responses needed.
The car is down as Blue online.
Primary colour is still BLUE (and many others)
Simplistically I don’t think it needs notifying.
It’s not exactly a bank robbers getaway car now, is it??
gman007
West Michigan
Question is………
Irrespective of the country, that is an interesting question?
How does the mind of a bureaucrat work (well some might say that, this in itself is a rhetoric question, as it seems that mind of bureaucrats never works in the first place :) ) in classifying the color of a multi color car?
Brian R
Chestertown, MD
Sorry Rian,
and obviously
But also:
And
Splitting the "G" FTW.
Bob Heine
Boca Raton, Florida
You are kind of like the guy with $5,000 of wheels and tires on a old used up $1,000 Chevy!
A question asked elsewhere.
Copied and pasted below.
More research for comparison is in your own hands.
I think totals will scare me if I kept a record.
If I had a football (soccer) season ticket for a club I supported……
Even the cheapest tickets are a lot of money and you don’t have a useful tool and car, plus mental health to show for it.
You also couldn’t sell the used season ticket for the money you spent at the end of the season.
I also only have to walk to my work shop to get my fix.
So it is probably all relative.
Football is probably a bad example as I dislike it intensely
Rian, I have a different view. I paid $41,000 for my used 2011 Cadillac CTS-V in 2016 (it had 11,700 miles on the odometer). To have a professional paint it like yours it would cost another $40,000. You put your imagination and vision to work, followed by some practice on a junkyard door canvas and then took on a full paint project on a huge American sedan. The Oldsmobile you chose for the project will not bankrupt you, regardless of the end result. You now have a unique vehicle, especially in Great Britain. Love it or hate it, it's a real statement. I love it!
I paid $18,000 for our used 2004 PT Cruiser Turbo (243 miles on odometer) in December 2004. The Florida sun has fried the paint on the horizontal surfaces so the bonnet, roof and upper strip of the rear hatch. I am patiently waiting for you to finish your project so I can show Liane the roof lace on your Olds. I'd shoot a pearl white base on the damaged panels, apply the lace and then shoot a fresh coat of silver through the lace. The white lace would be subtle and there's a body line that would make masking pretty simple.
It would give me a chance to de-badge the bonnet and weld the holes up.
Best part of my project would be my invisible left middle finger to all the PT Cruiser haters.
Bob Heine
Boca Raton, Florida
Rian, you have already solved the runs in the paint issue so this is just for future you.
I mixed up a batch of body filler in the garage and walked past the '87 Corvette with the mixed filler on a board. Didn't notice the gob of filler that fell off the board and landed on the front bonnet for a day or two. I managed to carefully sand the small dots but attacked the large glob with a different technique.
Rather than try to razor blade the hardened filler off the paint, I covered the biggest glob with painter's tape. A small block of wood with rounded sides wrapped with 400-grit sandpaper sanded through the tape, which protected the paint adjacent to the glob.
Stepped through the series of grits until the body filler disappeared. Hand buffing removed all trace of sanding.
G
Grizz1963
Rochester, KENT. UK
So when is a reveal not a REVEAL in the true sense ??
I would say, when you have been following the evolution step by step.
In this case, it it when the masking came off the glass, wheel inner arches, sills, lights, rear view mirrors and various other bits wrapped for 5 weeks.
So on Friday I actually had a bit of a hectic day, including the unmasking.
I still had jobs to do, like the aluminium window frame sections I painted on Saturday.
I also got involved in a Facebook Marketplace battle, thanks to my friend @pauly spending my money.
I have decided to edit a short 6 minute video which has a load of IMPORTANT NEW INFORMATION that you need to know if you actually read the words and text that takes me hours to create on here because I not adding that information into the “REVEAL” on here.
Anyway, I eventually got to drive the Oldsmobile out from its paint shop just after 5.00 because Pedro had actually made it home and went to inspect the unmasked car.
Watch this video.
LIKE IT
SHARE IT
SUBSCRIBE TO MY CHANNEL
HELL, I AM STUCK AT 920-ish SUBSCRIBERS.
PLEASE.
Photos
I will upload a bunch taken in the garden.
Hope you like it.
G
Grizz1963
Rochester, KENT. UK
Perfect Rian, amazing skills in achieving the look that you had visioned. Waiting patiently for the full reveal with the new wheels. Warren
Thank you Warren
I appreciate that.
When I did the Rezin Rockit I had managed to get to 95% of the vision.
The last 5% would have cost me the two years of MOT certifications I managed to get.
Perfectly executed, it would have been like those built in the Philippines.
G
Grizz1963
Rochester, KENT. UK
cooler than a sack full of Fonzies!!!!!!!!!
Thank you mate.
and I even watched the video (that's twice now..........)
Weirdly, I obviously edited it, reloaded it with a different soundtrack because of copyright on the first version.
So I have watched the uploaded version twice too.
And it made me smile.
It is a touch gritty, I could have edited Pedro out and tigtened up bits, removed the still photos…….
But then it wouldn’t have been true to me.
Thanks for watching.
Twice 😉
G
Grizz1963
Rochester, KENT. UK
Bob, I wrote a long reply without posting it, stepped out to get Liane some photos and came back with photos and a disappearing text.
In summary, I wrote thst it seemed a great idea. 22 years later the PT needs a new dress or is it boxing shorts?
Also, being of an age where the invisible middle finger should be visible 24/7
Why not go a bit louder with the color choices?
Or even two tones.
Roof…… a favourite color like rootbeer metallic or green, orange etc. The sort of thing you look back at in a carpark and smile or if a sad guy like me….. another selfie.
The lower surfaces more subtle.
But keep in mind, there is a point in subtle where you may as well just respray in silver.
Conversely………. Involve Mrs Boss to lay some flames on those sections, overlay the lace like on the Oldsmobile hood and have fun.
Bottom line…….
Your Circus, Your Monkeys
gman007
West Michigan
Rian
What can I say? Fantastic job! Great work of art! Bravo!
I also really enjoyed the slick video!
This car will definitely grab attention even from those who are not into this kind of artwork. I am sure it will be featured in many selfies every time it is parked anywhere in public.
The new Jewelry aka wheels are icing on the cake! Great choice! Looking forward seeing them mounted!
Now onto on the C10 project!
