Yes, of course I considered this option. And most likely I will install another one if I don't find the original one in working condition from the same motor.
Yes, I'll probably put separate brakes on the rear wheels.I have absolute respect for your design and fabrication skills using the resources available to you! Are separate rear turning brakes (as found on most tractors) not something you will be needing given the use(s) of your tractor? Keep up the amazing work, Vladimir!
I have a similar copper punch in my collection, doesn't get used as much as it did, amazing how short it has gotten through the years.
Of course it 's a cable . The electronic speedometer appeared very late on Soviet cars. I had a 2000 VAZ-2110 car with an electronic speedometer on it. And on exactly the same VAZ-2110 , but only in 1999 , it was with a cable drive.@Vieux , is the speedometer electronic or cable drive?
Very creative. Nicely done. This tractor is transforming into the Ferrari of tractorsThank you for your congratulations!
I continue to work on the tractor. I extended the transfer case shift lever and slightly changed the angle of the lever. Now it's convenient to switch. I also decided to maximize the use of the display on the dashboard. I made a light bulb that shows charging. I have another generator installed and the charging indication circuit is implemented differently. I also connected the speedometer, it is clear that it shows the weather on the moon, once it is there, it should work.
!More akin to Maserati...Very creative. Nicely done. This tractor is transforming into the Ferrari of tractors!
Since you're probably going to be driving under 16kmh, it might be possible to use a speedometer tuner/adjuster gearbox, like the ones used in big trucks, to make the speedometer read 10 times as fast as you're actually going. Then at least it would have some less than moon-like value. Assuming that Russian big trucks use the little reducer/increaser gearboxes like American trucks do.Of course it 's a cable . The electronic speedometer appeared very late on Soviet cars. I had a 2000 VAZ-2110 car with an electronic speedometer on it. And on exactly the same VAZ-2110 , but only in 1999 , it was with a cable drive.
It will be the coolest tractor ever.More akin to Maserati...
This is an interesting speedometer gear drive design. Unfortunately, I do not know if there is such a drive on our trucks. But you've given me an interesting idea, and I need to think about it.Since you're probably going to be driving under 16kmh, it might be possible to use a speedometer tuner/adjuster gearbox, like the ones used in big trucks, to make the speedometer read 10 times as fast as you're actually going. Then at least it would have some less than moon-like value. Assuming that Russian big trucks use the little reducer/increaser gearboxes like American trucks do.
Vlad, hope and pray that the tractor and other projects provide you with sanity and peacefulness in your daily life. Cannot imagine the mental hostility you are enduring.
Spring coming and warmer weather. Our daffodils and crocuses are about done, saw a few tulips the deer have not eaten and the trees are flowering.
Take care.
I was thinking about using a power steering pump. I just managed to buy a couple of new gear oil pumps from hydraulic systems very cheaply. They are called NSh-10. I will use them, and I plan to use the fire extinguisher body as an oil tank.Vlad, glad you're here. Does the pump require a tank also for the hydraulics? Just thinking if you don't need a lot of litres per minute a power steering, belt driven pump might keep up.
Good Luck
Yes, there are plans to make hydraulics for the snow removal blade and other devices. I was also thinking about 2 options here. Or I will have 1 hydraulic cylinder, which, depending on what is needed at the moment, I will move from the rear to the front and vice versa. Or I will use 2 cylinders and 2 distributors. It all depends on the price, a 2-section distributor and hydraulic cylinders are quite expensive. I also considered mounting the fuel tank at the back, but I would not like to go beyond the dimensions of the tractor frame. Although I will most likely install the tank at the back, it is also possible that I will redo the seat mounts (raise them a little higher) and install the tank and the hydraulic cylinder there.Vladimir
Are you also planning to use the hydraulics for other purposes such as for the tractor attachments (eg plow, snow plow etc.)?
As for the location of the fuel tank, since all the weight of the engine is in the front (with respect to the seat), what about creating a frame and welding it to the rear of the tractor frame at the same height as the seat for the tank?
This will also provide a bit of counter weight in the back which should help the plow in the back dig deeper in the soil. And since it is at height of the seat it should not interfere with any planned attachments such as a plow in the rear.
It is not always possible to access the GJ forum.Hi Vladimir
There has been no recent updates from you! I hope all is well and that you are just too busy to post!
Be safe!
Do you know the guys in the background? They were eyeing your shop pretty hard.Some guys I know from the tire repair shop gave me a pair of wheels. My rear tires on the tractor were completely bald and they were also slowly deflating. The guys offered me wheels in much better condition, and they did the tire service absolutely for free. The wheels are slightly smaller, but that's okay. But the video shows me driving into the garage on new wheels.
Today I also received a new hydraulic cylinder and a hydraulic distributor.
Yes, of course I know. These are my garage neighbors, normal guys.Do you know the guys in the background? They were eyeing your shop pretty hard.
They just park their cars in the garage. Sometimes I can have a beer with them. I'm probably the only one in the garage who does construction and repairs of various equipment. Many people use the garage as a place to store various junk like in the photo. I didn't take this photo, but we also really have similar garages.Tractors taking shape. The guys in the back ground, do they also build like you do or are they just parking cars in their garage space? Stay well!
