wyliesdiesels
15a FLA? yeah thats a 3HP.
Thats a newer code item. Are you taking out a permit?
Are you feeling the need to voluntarily re-vamp all the electrical in your home to the latest Code? (not required)
What is 15a FLA?15a FLA? yeah thats a 3HP.
Why do you think this?You can make an adapter, but I bet the generator will stall out when the motor starts
Motors draw a huge amount more than their running amps when starting. Running amps are just one part of the equationWhy do you think this?
Tell us you don't know how motors work without telling us.Watts= Volts x Amps
The motor name plate is 13.1 amps and 230volts. So about 3k watts.
Watts= Volts x Amps
I tried. I made an adapter. The gas generator runs however the electric motor did not do anything.Post #50 explained it pretty simply.
The generator might have power beyond what it lists amd might sustain the industry load. Plug it in and find out. Worst case it works but kills your generator over time.
Something else is wrong. Did you test that the generator is outputting power?I tried. I made an adapter. The gas generator runs however the electric motor did not do anything.
Watts= Volts x Amps
Did you fully charge the tank and then run it down to trigger the motor again?Update: Someone gifted me a Powemate 5000 watt generator with a 20amp 240v outlet. It turns the motor over. The 4000 watt generator had low voltage and was bad. For this temporary project I don't need to wire a new outlet at the electrical panel.
It worked a few times then the motor started smoking. At full psi the electric motor struggles to move. So this generator is not the solution. I'm going to need to have a 20amp 240v gfci outlet wired in the garage.Did you fully charge the tank and then run it down to trigger the motor again?
On the motor? The motor still runs. The motor has a thermal cutoff circuit breaker.May have shorted a winding. Keep us up to date.
