250 ft-lb torque wrench for very occasional use?
Innovate1
Have a simple beam type but only goes to 150. Don't find that style in searching. The dual beam are reliable from what I have read and have an obvious snap when torque is reached (at least some of them from what I have read). Whats a good reliable low cost option?
Had checked Autozone loan a tool but didn't find torque wrenches. I see other places have them as loaner but then accuracy may be an issue if they are used/abused. Here's one:
https://www.oreillyauto.com/detail/...ntal-tools-evertough-torque-wrench/ren1/67075
ecotec
I don’t even know anymore. I have had my Precision Instruments so long that they have, basically, doubled in price.
Split beams are so easy… set it and forget it. You don’t need to zero it out.
I got mine on sale for half of what they sell for today.
While I love mine, I don’t think that I would recommend it for occasional use at today’s prices. Maybe look at the ICON copy when they do a 40% off sale.
If you need angle, maybe look at the Gearwrench digital torque wrenches.
pbon
Is there a project farm type test that includes dond cheap clickers?
jayemm
up high down low
I like the eTork torque wrenches. They are much easier to read than the typical design. The 1/2" goes up to 250 ft lbs.
At 74.95 that's a good price on a quality TW. The owner of eTork was previous owner/founder of JS Technologies which made TW's for S-K, ATD, Craftsman and other labels. Mine was S-K branded and had it for years. I own 2 eTork TW's and am very sure that this style, with the direct readout in the handle, uses the same proven internal design as the JS Technologies.
On another note, I got a cheaper 10-160 ft lb TW from Amazon to be used for lug nuts or hitch balls. Cost me ~$30 at the time and is well built and accurate per testing with my digital torque adapter. For only occasional, non critical use, I think a person could get a decent 250 ft-lb clicker for $40-60 if they don't mind a weird name brand. Mine is a UYECOVE. Amazon is full of unpronounceable name brands. LOL.
T45
ICON 1/2 split beam at HF has been on sale (recently) for as low as ~$100. Never used it, but for the money I'd give it serious consideration. As noted above, inflation has really taken its toll on some tools.
It seems alot harder to get something higher end now at ~$100 vs ~$200 than say even 5-6 years ago. Whereas before that, you could score new precision instruments or used snap-ons at decent prices used or on sale with coupons etc.
charbar
Midwest
I was looking at either an Icon or Tekton earlier strictly for tire duty. I would have no problem with either one. Ended up finding a basically new Precision locally for $50. Kid said he "upgraded" to a Snap On and said the snappy dealer wasn't going to give him anything for his PI :lol:
Its worth it to check out the local marketplaces if you haven't yet.
Black300zx
Elkton, Md
What kind of accuracy do you need? Are we dealing with something like head bolts, or are you dealing with something less critical where fastener condition is going to introduce a ton of error and something like +/-10% accuracy would be perfectly adequate?
Junkman
Northeastern CT
My experience has been that if the torque wrench is going to be off in its readings, it is always less than the setting. I have also found that as long as all the head bolts are tightened equally and in the pattern that the manual suggests, ha it will be OK. All the engines that I have worked on haven't been in production for decades, so you can get away with more than you can on a modern engine. The last time I tried to tighten the head nuts on my Corvair engine, they stripped before I reached the setting the manual called for. I called the supplier, and they said to use a lower setting, and it would be fine. Instead, I used the original head nuts, and they went to the full setting, and I haven't blown any head gaskets yet. Every year, Chevrolet kept increasing the head-bolt torque due to blown head gaskets. When they gave up on the copper head gaskets and switched to higher-torque steel gaskets, they solved the blown head gasket problem. The only problem that they never solved was the dropped steel valve seats in the aluminum heads.
FigN⋅m
Like they say: "Quality, Service, Value. Pick 2."
Since you'll likely have it the rest of your life, just get modern split beam in your favorite color and go to town.(y)
I
Innovate1
No need for super accuracy. Most of the torque spec ranges I am looking at are about +/-10%.
shoggoth80
Seattle
I've bought some of the Icon split beams for use at work. They're surprisingly nice for the money. Unidirectional, but that's not a huge concern these days.
