Old tool guy
- Joined
- Apr 13, 2023
- Messages
- 3,560
Steve … did that hall used to be on the outside of the building. Looks like an exterior window.
I'm planning on panelling our hall - not sure if the fact that it's 6' long by 4' wide with doors in two of the walls, a window in the third and a radiator on the fourth means it will be harder or not..................Three days at floaty last week and I, batterned, plaster boarded, panelled and filled the long hall.
Now that he’s retired, he could show up and lend a hand.Trouble is I've now got to try and match your skills whilst having none of my own![]()
I retired in 2015 and thats when the real work started.
Hi GuysRetirement is hard work, but at least making a living doesn't need to get in the way of the hard stuff.![]()
Hi mateSteve … did that hall used to be on the outside of the building. Looks like an exterior window.
Finnish the "Honey Do List" ****** hilarious.Hi Guys
Yes it feels that you’re both right, it’s hard and dirty work at the moment trying to get to being retired. We should be done by the end of May.
Then if I blast through the Honey Do list and get it done , my time will be my own.
That’s how it works right ?
Steve![]()
It wasn’t to hard really.I'm planning on panelling our hall - not sure if the fact that it's 6' long by 4' wide with doors in two of the walls, a window in the third and a radiator on the fourth means it will be harder or not..................
I’m more than happy to accept a temporary part time supervisors position. I have my own cupNow that he’s retired, he could show up and lend a hand.
Wow. I guess you made it safely? That looks like a capsize waiting to happen.A couple of more days down at Floaty last week,
to finish boarding out the inner hall. See above.
More electrics getting connect each trip
We now have light in the bathroom even in the shower
The little boat earning its keep
When I get a minute I must investigate getting the steering wheel on straight.
Steve![]()
I know it’s normal for you, but I can’t get used to the high doorknobs.
hopefully in your best Harry Enfield voiceI’m more than happy to accept a temporary part time supervisors position. I have my own cup
and I just need a comfy chair, and I can point and say “ you don’t wanna do it like that”
Yeah, made it back to the van safely, thanksWow. I guess you made it safely? That looks like a capsize waiting to happen.
It’s due to the locks and the style of door.I know it’s normal for you, but I can’t get used to the high doorknobs.
You got it. Not many did.hopefully in your best Harry Enfield voice![]()
Trickle vents.What are the eyebrow thingies over the windows?
LMGTFYWhat does it do?
Since about 2010 many and various rules and regs
That’s clever.
It certainly is a good setup, probably 10k’s worth at least. The whole roof has been off including the timbers and it’s all be reworked to include, 2 beds and a bath upstairs where originally there was none.Wow!! That is some scaffolding set up and tarping so you could install and maybe remove your very nice looking work no matter how much it’s raining or windy.
I’m positive you’ll be asked to either consult or make and install many more projects in your future so let them try to convince you with lots of cash cause you do great work!!
I know you’re enjoying your retirement even though you might be busier with the shop clean out and mcfloaty but it’s your choice.
www.doorandwindowexperts.co.uk
Vents can be opened or closed.So do the trickle vents stay open at all times?
edit. Never mind, found this good explanation. I have heard talk that the old houses in the states, the ones with ill-fitting windows and doors, don’t suffer from sick building syndrome because there was always a little fresh air leaking in, and the new houses with air tight envelopes have issues.
Trickle Vents Explained. Why And When You Need Them | DWE
Do you really need trickle vents in new windows and doors? Here's everything you need to know, including busting some myths around trickle vents.www.doorandwindowexperts.co.uk
Is that wisteria in the garden picture.
I have always been a bit curious about the position of windows in traditional cavity block/brick walls, in England. In Northern Ireland, with similar building regs I assume, we have a vertical dpc behind the outer leaf and the inner leaf returned out, with a 25mm thermal break behind the dpc. The window or door frame sits behind the dpc, which slightly overlaps the face, sealed with expanding foam that bonds onto the rigid foam thermal break. This results in a 100mm set back reveal on the outside of all windows and doors and the frame doesn't touch the wet outer leaf.
Yeah, it certainly isBittersweet.....
Evening TomI have always been a bit curious about the position of windows in traditional cavity block/brick walls, in England. In Northern Ireland, with similar building regs I assume, we have a vertical dpc behind the outer leaf and the inner leaf returned out, with a 25mm thermal break behind the dpc. The window or door frame sits behind the dpc, which slightly overlaps the face, sealed with expanding foam that bonds onto the rigid foam thermal break. This results in a 100mm set back reveal on the outside of all windows and doors and the frame doesn't touch the wet outer leaf.
What is the setup with yours in mainland GB?
I hope so too. They do want to sell the machines on when they reach Tanzania, but who knows.I hope they have a competent person packing the container. I can imagine bits & pieces getting knocked off, like the fence rails and arm on the table saw.
4,000,000 Tanzanian Shilling equalsI hope so too. They do want to sell the machines on when they reach Tanzania, but who knows.
These are the guys that bought them.
4,000,000 for a cement mixer
Steve![]()
