YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 502
Trying to use a ratchet ******** a ground stake in dirt. I'm using a cheap ground stake from home Depot and trying to pair it with a ratchet strap, with a metal pole on the other side for a portable garage. Whenever a bit of tension is put on the ratchet strap, the spike slowly pulls out of the ground. Will this be the case we've with some higher quality ground stakes? A ground stake can't resist the force or tension pulling it up from a ratchet strap? Can someone recommend some ones that can if its possible?
