Spartan Zero Turn B&S 25 HP 724cc No Crank
Buckaroo5
Central Ohio
Went to start the mower today at the remote cabin and got a no crank. Spartan mower (only about 40 hours) generated a #12 error code that indicates battery issue or solenoid wiring short. Battery was just charged but jumped it just to make sure without success. Was scratching my head if it was the solenoid, wiring or starter. It is a 3 pole solenoid which means the ground is through the solenoid bracket to the frame of the mower. Fortunately determined it was a bad ground so I backed out the solenoid bracket anchor screws and retightened which fixed the problem - apparently just some corrosion during the winter. If I had decided it was the solenoid, I would have removed those screws to replace it and coincidently it would have started fine. Never would have known it was just a bad ground.
Firebrick43
West central Indiana
And if a trailer connection is involved, it's either ground or crappy aftermarket installation
Most non semi trailers the factory installation is a meth head with a bag of 3M scotch locks. I sort of wish scotch locks were heavier so you could put a handful of them in a sock and beat people that use them and it would actually hurt.
Buckaroo5
Central Ohio
It seems to me that the 3 pole solenoid design is a problem on lawn mowers which see a lot of moisture. The 4 pole with a dedicated ground would be more reliable, When I replace it, I'm going to put in a 4 pole.
Firebrick43
Use a conductive anti-seize like cop graph on the mount screws and you probably will never have a repeat.
zimman
Mark Twain National Forest
Remember it takes "AMPS" to start anything. Lawn mower batteries only have a 90 day or 1 year warranty mostly because junk. LOL I'd clean every ground surface and put a lock washer under it to insure continuity.
This is the second time I've posted this pic today.
If that don't work, buy a battery.
Zim
Retired dozer fixer
Leesburg Indiana
Damn scotch locks should be illegal. Nothing but trouble. Especially when it concerns trailers
