Man, it's close though....good to see data back up the uselessness of the TX twister though!As I suspected, not a 10lb slide hammer level. Though I dont know why that's my 1st assumption it would be when these only recent came onto the scene I suppose.
Cheap pullers have screws made of butter / chinesium. Good ones will hold up and have replacement screws available as well.. I have stripped 3 jaw pullers.
The body ones usually have larger threads and larger rod. You'd need one like bought in the videoI would like to get a 10lb slide hammer for wheel bearings. There seem to be body shop 10lb slide hammers but I do not know if the attachment is the same size and thread pitch for the accessories I have for my 5lb hammers. In the northeast, we have rust that gets in the way of removing stuff. I have stripped 3 jaw pullers.
I wanted a 10 lb weight (only) to use with my existing OTC shaft. I found a couple but they were stupid expensive.I would like to get a 10lb slide hammer for wheel bearings. There seem to be body shop 10lb slide hammers but I do not know if the attachment is the same size and thread pitch for the accessories I have for my 5lb hammers. In the northeast, we have rust that gets in the way of removing stuff. I have stripped 3 jaw pullers.
The cheapest route I found at the time was a Westward kit from Grainger (of all places). I don't remember how much I paid for it because it was years ago, and they also currently have the OTC for about $180. Not sure what the thread is because my intent was to just use the weight withe the OTC rod and keep the Westward rod as backup. Also never used it because like all dedicated GJ member, I bought it without needing it - just to have in case I needed it and haven't needed it yet.
Whoops, we couldn't find that.
www.grainger.com
I find the "towel" method works really well if you need more "Impact" with a slide hammer.That is why I asked — I was pulling rear wheel bearings from a BMW that had seen many years of New England winters and it took about 75 pulls with my 5 lb puller. After that I decided I should buy a 10 lb for next time. Next time has not come yet but I maintain a few BMWs so it will come.
Wonder what it would take to get it to pull out ringshank nails that have been in my pole barn roof for 40 years ....
Need to redo the roof and it would pay for itself if i could make the nail removal easier.
I think i can visualize what you are saying. Sounds like a good idea to set up a custom pry bar. I will experiment with some shapes. Thanks!I needed to remove a bunch of pole barn tin about 20 years ago. Ended up using a modified cat's paw prybar with a short piece of round tubing welded to the back of the "head", perpendicular to the axis of the nails. worked well to pull nails with minimal damage to the sheet metal. I wish I had a picture, as I had borrowed the tool from a friend who salvaged a lot of stuff.
You likely need one of these.Wonder what it would take to get it to pull out ringshank nails that have been in my pole barn roof for 40 years ....
If I had this problem I feel like I'd just buy a chunk of 4140 rod, drill an 11/16 hole in it, and wrap it in grip tape or something.I wanted a 10 lb weight (only) to use with my existing OTC shaft. I found a couple but they were stupid expensive.
www.grainger.com
Have you seen the side pull nail hammers?Wonder what it would take to get it to pull out ringshank nails that have been in my pole barn roof for 40 years ....
I've tried one of those but it is really hard on the existing roof that i would like to preserve.You likely need one of these.
HK Porter made them back in the day, and Hultafors makes a mini one.
Most here in the rust belt dont even bother with the slide hammer.This is what I like about ASTRO. Eric O. got the first version and pronounced it unsuitable for his upstate NY rust buckets. So Chris Petit and his team came up with the bigger, better model that's not quite but pretty close to what the 10# slide hammer can do. That's listening to your customers, or in Eric's case Beta Tester, and making an improvement. All companies should be this responsive.
