3D metal printing on low volume items
toplessHO
central florida
Completely new at this.
would like to duplicate an auto part that is diecast(potmetal).
brass or aluminum may be a better material,as it needs to be chrome plated
I have no scanner.part is approx 16x4 inches
T
toplessHO
central florida
wow you guys must be very proficient at this
I couldnt even do a bar room napkin drawing in that time.
So is this saying with a proper CAD file it would be less than $30 each?
Who do I have to have scan this?
there will be minor clean up of the scanned part,all of which can be done via software.
mike93lx
Richmond, VA
There are services out there that will do the scanning and cleanup. I haven't done a lot of looking, but I did find one locally to me that offers it.
I'd expect at least a few hundred $ if hiring it out, then the printing costs. I'd probably print and iterate in plastic then send a final out for metal.
jeepxj
a chrome part will need to get the dust spray on it for accuracy.
MushCreek
Upstate South Carolina
Just curious- what is the legality of copying an automotive part? I have a part for my Ford truck that is one year only, and very hard to find. I have one, but have thought about making some to sell.
T
toplessHO
central florida
depends on the part.
cant copy part# or manufacturers logos,any copyrighted info.
If it has a patent,would advise against.
GM has a program for repops,many years ago I got legal release
for a couple of items.Maybe contact Ford and ask if they can re release.
If they arent interested ask if they can release for you.
care to enlighten?
jeepxj
care to enlighten?
when 3d scanning it works on reflections. chrome will act like a mirror and jack the scanner all up. spray acts like a temp matte paint to make it scan better.
T
toplessHO
central florida
any advise to what works to replace the die cast (potmetal) material?
The place listed above doesnt list brass or bronze as a material,
only aluminum or steel.
I will need to chrome plate so aluminum is a little fussy.
what metal is SLM?
mike93lx
Richmond, VA
what metal is SLM?
Slm can be a variety of metals. Aluminum, titanium, stainless and others.
Does it need to be shiny? Bead blasted stainless won't work?
Irontoys
*******, you are correct that an aluminum part requires extra processing to plate. Treated with special cleaners, then a zincate, to fool the bath that it is pot metal, then nickel, and chrome. Steel, much easier. Would like to suggest you add some bosses, for threaded holes.
1) to drill and tap for final installation. 2) to allow some screws to be threaded in. There will be burn marks on this bezel, from plating. I can see this easily pulling 50-100 amps of current, in the chrome tank. By adding bosses for screws, the screws take the high current burn, and are disposable! It would also help the poor guy that has to try to hang onto this part, buffing in preparation for plating. Gotta have a death wish to try and hang onto a thin cross section bezel like this, using an open buffing wheel. Screw holes will allow it to be mounted to a board backing for polishing. If you make it as drawn, better make two. The first one will get pretzelled while buffing. irontoys
T
toplessHO
central florida
I know all too well about parts becoming projectiles.. :^)
there will be bosses built as part of the design. thanks for tips
jeepxj,that seemed like it was aimed at non metallic items for plating.
T
toplessHO
central florida
After months of run around first shop flaked on me.
So I ditched the shop thats 2 guys and a hobby and went for someone I had used before but was more expensive.
I got the 3D files from them yday and sent back a couple corrections.
Hopefully by next week I ll get a prototype sample.
T
toplessHO
central florida
shop called and said prototype is ready
when I go to pick up,they are going to provide the file to print off of.
What file format will the metal printer ask for?
jeepxj
T
toplessHO
central florida
got the beta versions of parts.
Still lots of work to do,one of which is to make a mold for the back side
so the new material has something to build on.As it is now it has "trees"
to build off of.
Im thinking plaster would work but unsure if the heat needed to fuse the parent metal
will destroy it.
Any tips here?
