Can someone check my wiring in a sub-panel?
sparky 1971
Central Iowa
Panels NEVER come with ground bars. Why?
Money. Why put a ground bar in the panel and sell it that way for an extra $.25 when you can sell them separate for $12.00-18.00 each
I have no clue but you always have to buy them separate
Mostly. For some reason Square D QO 200 main breaker outdoor panels with feed through lugs come with a ground bar (at least the one I bought last fall did) and a couple of weeks ago I bought a Siemens 20 space MLO for my brother along with two 12 hole ground bars. I was pleasantly surprised when I took the panel out of the box and there was a factory ground bar in it. Then I dropped the cover and broke the plastic hinges.
purplezr2
Central MN
to keep wiring tidy.
if you only have 1 on 1 side or bottom, it means you have to run excess wire in the panel to get to it.
Ah makes sense, thanks for the answer.
I know on the one sub, all the circuits go out the bottom, hence installing it on the bottom.
Codyboy
S.E. TEXAS
The code change for this was 2008 NOT 2011
Just for clarification , the rule to have separate neutral and grounds was 2008?
When I wired my house (2005) I did not separate them.
My breaker panel could be considered a sub panel I guess but not sure.
There is a main breaker only in the garage, it then feeds to a closet in the house where the breaker panel is. Sch 40 pvc between the two panels with 4 wire , two hots , neutral and ground wire.
Neutral and ground are not separated .
And if it matters this is all the same structure.
wyliesdiesels
Modesto, CA
the code change in 2008 was only for subpanels in DETACHED buildings.
It is a subpanel because of the main breaker ahead of it.
This is totally incorrect. bonded neutral has NEVER been allowed in a subpanel in the same structure as the main. the code change we are discussing above is for DETACHED buildings.
they need to be separated as you have created a potential for shock.
and whats crazy is you ran a 4-wire feed but then left the neutral bonded.
post some pics of your subpanel with the cover removed. and do it on a new thread so you dont hijack this one.
