Prospecter
Maine
I am moving on. I am unable to continue due to health reasons. I would have driven them through construction of and a final move to a corporation owned site, which they desperately need.
However, what I have just learned is Long covid has made that not a possibility. I am actively minimizing my galactic footprint to concentrate on self-care. One planet, two websites, product development at Halfassed will be my foreseeable future.
You still seem very busy! I thought it wonderful to retire so work would not get in the way of things I want to do. Did the voluntary service gig for a while. Only to discover that body maintenance would replace work and make the service unworkable. Different health issues, but the same result. Oh, well. Hope you get good results from the changes.
PhantomEB
Medicine Hat, AB, Canuckistan
My biweekly Friday off so….
Wiring in a few more relays and labelling wires at the Center console.
-Electric fan done and will be on ignition power and a kill switch for creek crossings
-Front locker to be researched today and wired in
-Relay added in for the light bar.
hope to get some welding done and Center console painted up as well So I can finish off the switch panel, waiting on the dash switches.
Beerhippie
Far NE Oregon
Knocked down grass again after not being able to mow due to snow last week. It's growing FAST this time of year, so some of it went pretty slowly even with the torque of electrons pushing the freshly sharpened blade.
It's predicted to be the hottest weekend so far this season--maybe 90s. I think I'll try to knock off early today and get packed up for a camping trip down with the cactus. Should be good and warm down there.
Hoping to catch this bloom:
That's Pediocactus nigrispinnis, one of only two cacti that are found in the county. The other is a prickly pear. The pears bloom a little later, so I'll have an excuse to head back down that way in a month.
kaymccampbell
Upstate New York
How do they diagnose Long Covid now? I recall not too long ago it seemed to be a blanket label applied to a combination of symptoms the doctors couldn't figure out.
My particular strain had atypical symptomatology. It also is only detected by a special test that most places don't carry, cause it's rare. Then after the fact, it's detected by rheumatological tests, not the typical ones, along with hundreds of other tests to pin it down. So it took 2 years to get me round to the rheumatologist, who saw my tons of results and knew in a few minutes what I'd had and told me that my again atypical set of complications that faked 30 other diseases was long covid and not something else. It took at least 8 shoe boxes of blood to get all the tests and eliminate everything else to get my answer. So probably at least 1000 blood tests to find out.
It appears that covid rips a trench down the middle of your immune system and implants whatever joy it has. Then as your damaged immune system starts to try to rebuild, it triggers a long series of other symptoms, which is long covid or PCC. They say it could take 2 years to a decade for it to flush out if it ever does. I'm already at 2 years. In the meantime, I need to take tons of supplements to try to prop up what's left of my immune system. Lotsa fun.
Thank goodness for insurance. Without it, I would have never been able to gain a diagnosis.
larry4406
Northern Virginia
Ugh...
Wishing you the best Kay!
niget2002
Josephine, TX
Put a final coat of poly on the bottom of the chair. Waited a few hours, then hammered in some feet and flipped it over so I could put the first coat of poly on the top.
Just need to let that dry, sand it and then do one or two more coats and this project will be done.
M.Brane
1 hr N/W of LA LA Land
Started the re-assembly of Play Girl's™ rear end. I'm changing things up a bit so it was assemble, test fit, disassemble, reconfigure, re-assemble lather, rinse, repeat. Gonna need to fabricate new mounting brackets for the shock reservoir, and exhaust. Now it's beer, steak, and fire pit time.
Skyman
Central Maryland
Damn, Kay. Just damn. That truly *****. Covid can be a very nasty virus. Here’s wishing you all the best.
bugnut
Central Ohio
@kaymccampbell This truly *****, I pray a speedy recovery for you. Hang in there!
micromind
Fernley, Nevada, about 30 miles east of Reno.
That's just terrible.
I can't even imagine the anticipation with each test only to be told that they don't know what's going on.
Not to mention being jabbed so many times........
larry4406
Northern Virginia
Started gas grille grate project version 2.0.
Cut some 1” bar stock into (4) lengths of 16-1/4”.
Ground edges smooth and beveled the corners using Delta belt sander.
Coming week I plan to go get 3/8 stainless steel rods (304) and continue the gas grill grate project.
GrayFlattop
Chicago
Installed new sawblade organizers in the new cabinet. The old blade racks built last century was falling apart and was completely packed (which was why it was falling apart). Sorry, no photo. After cleaning the rest of the blades, I’ve come to the realization that all of the 10” blades were in great condition and I probably won’t need to buy any more for the rest of my life. Only one of the 8” blades looked sub-optimal. The advantages of being a compulsive tool hoarder, I guess…
Next, I put a new aluminum cutting blade on the cut-off saw as I wanted to get clean cuts on some aluminum extrusions for an upcoming project. After examining the old general-purpose blade that was shipped with the saw from Evolution, I was shocked that half of the teeth were broken off. I can’t say that I used it THAT much, but it was predominantly used to cut steel - flats and tubing. So it looks like I will have to buy a new blade, but 14” instead of 10”. That said, the Evolution 80 tooth Aluminum blade gave a superb, effortless cut.
Swept up Aluminum chips after. Yay..
dwasifar
Watch the temperature of those cables that have been bundled up. It probably won't be a problem due to the chargers not pulling that much power, but a cord bundled up like that can overheat.
They've been wrapped like that for years without issue, but it's a good point. I'll keep an eye on it.
More of an issue with them wrapped around something metal. A friend was a stage guy for plays and such and had wrapped a long power cord on a steel beam and was wondering why the lights got wonky. Then he traced back and said "Doh"!
Beerhippie
Far NE Oregon
Well, camping plans went the way of plans. I got about 80% of the way to where I'd planned to camp tonight when the throttle started to stick. This was right before where the really bad road got worse and became a single-rig-wide, tightly winding shelf road with about 1,200' of drop-off on one side. Not really where I want to be driving a rig that might decide to stick at full throttle at any time.
I turned back and got to where the really bad road ended and the just bad road began. Stopped for a smoke and a beer and to crawl under the rig to see why the throttle had decided to not only start sticking open, but getting harder to get open to begin with. Not good with a serious canyon to drive out of.
After removing the gear from the back so I could get into the engine compartment--nothing wrong there--and then repacking that area and laying out the old sleeping pad I carry just for this, crawling under the front of the Brick to check that end of the throttle cable (where I was able to dislodge a short ton of caked mud and dirt right into my eyes)--no problem there either--cable might be a little sticky in the housing. Finally looked at the most obvious and simplest part of the whole system--the pedal. Sure enough, the lever that connects the pedal to the bell crank had come unclipped from the pedal. One minute and fixed.
But that was what was causing the pedal to be hard to push--not why it was sticking. I concluded that discretion was the better part of valor, tucked my tail between my legs and headed home. Had a nice snack of fried chicken gizzards and an excellent red ale--Sockeye--at the Imnaha Store and Tavern and got back to town just in time to have beer at the TG pub before it closed.
But I did get to try to recreate a picture I took back in June of '05 purely from memory.
3/6/'05.
Today. Where the hell did my **** go?
Not horrible for working from memory--in the original, the Van, Ol' Blue, was parked about fifteen feet further up the road and the camera was placed a little higher and a little further down the road, but still, not bad.
I think I have video of most of the drive if I just get around to editing it and getting it posted--but, of course, as soon as I got back into cell range, my phone lit up with **** I need to fix. Damn, it was nice being out of cell reception for most of a day! Need to do that more often....
Tomorrow, I'll have to re-plumb the new water heater I installed the other day and apparently plumbed backwards and then replace the throttle cable to be ready for the next shake-down cruise.
Beerhippie
Far NE Oregon
Forgot a picture:
That sign used to say Reduced speed 35 MPH. I've been driving for hours, never getting above second gear, and 35 is supposed to be reduced speed? Let 'er rip!
I miss the irony of the old sign.
That was my air-up stop. I ran 25 rear, 20 front and it greatly increased the traction and comfort on the bad stuff. 40 rear and 35 front is my road pressure.
For rough, winding canyon/mountain roads, second gear seems to be optimal for a Vanagon--even with the larger engine.
