Drain Snakes 2026
pizza
Midwest, USA
hey guys,
looking for drain snake/auger recs for home use.
i want something for toilets, baths, showers, and sinks (including kitchen where there can be grease, i suppose).
i don't think i need a big-*** machine for the main line to get tree roots and stuff. it would be sick to have a machine like a K50 or K60, but on the other hand, it's just bulky and overkill for most things, and the cost is much harder to justify. i think i'm ok with hiring a plumber for that every few years or whatever. more than $500-ish total on this stuff will be a tough sell.
i guess i should get a toilet snake and then another tool for everything else... unless there is some way to use a general-purpose snake on a toilet without ******* up the bowl?
i'm thinking a 6' toilet snake. probably the ridgid K6-P ($65) unless you guys have better recs. i also saw milwaukee's trapsnake one, but they want you to use a dedicated M12 power tool to drive it vs a drill i already have? seems like a troll because that's another $150 (for battery kit -- they don't sell it as bare tool, lol?), and although you can use it on other trapsnake tools, i have doubts about the ecosystem being worthwhile.
as for the general purpose snake, i've used a ridgid 57043 powerspin+ ($50) at my friend's house on a tub drain and thought it was fine, but i don't mind slightly splurging if there's something better.
I borrowed a Ridgid PowerSpin from a friend. Yes, the reviews of it being fragile are out there, but I didn't break it with an M18 drill, and in any case, it has a lifetime warranty.
My issues were the hand strain, as well as the drum leaking. There's a rubber gasket sealing the front to the back of the drum, but the returning wet snake still managed to pull water into the drum that was sprayed out by centrifugal force as it spun. Before returning it, I took it apart and sealed that gap with RTV.
I then went out and bought a Ridgid 55808 PowerClear. It has a clear non-rotating cover over the drum, and frees up your drill hand for the snake end to reduce hand strain.
@rlitman have you used your PowerClear ($225) much? that's the one i'm leaning towards, and i also trust your opinions in general lol.
also saw the flexhshaft K9 series (i think the cheapest/smallest being K9-12 @ $230). seems ok except reviews say they're a ***** to feed through more than a couple bends. the system is cool in general though because the chain knocks **** off of pipe walls better (grease, maybe even scale), and the sheath around the cable doesn't spin. i suspect that it's more of a specialized thing though that isn't a total replacement for normal snakes. cleans better but tougher to feed through smaller pipes, longer runs, lots of bends, etc. so maybe the bigger versions are great for large lines with roots or whatever, and the smaller version can be good for greasy kitchen lines (as long as you don't have to navigate it through a lot of bends/fittings)... but maybe not great for general purpose or smaller jobs because hard to feed far?
rlitman
Long Island
...i'm thinking a 6' toilet snake. probably the ridgid K6-P ($65) unless you guys have better recs....
@rlitman have you used your PowerClear ($225) much? that's the one i'm leaning towards, and i also trust your opinions in general lol...
I have an OLD Ridgid toilet snake, and it looks like it's the K-3 without the drill attachment, and I really cannot comprehend why you'd ever want a drill on it. Toilet snakes are hit or miss, with many toilet traps bending too tightly to be snaked (my old American Standard was like that, and that's one reason I was happy to be rid of it), but my Ridgid toilet auger has saved me a lot of grief from the handful of uses it's gotten.
Looking up the differences of the K-6P with the K-3, it seems my toilet snake is the 3' type (which basically gets you through the trap and just past the lead bend), and the new kid in town has a telescoping pipe to reach down the trap arm to the vent connection (UPC limits trap arms to 6'). I can't say I've ever had something that extra 3' would have helped with (the one toiler drain issue I had was about 10' from the toilet, and gladly that's been fixed), but if you have a bad slope on the trap arm or some other error, not having to pull the toilet to snake from the flange would certainly justify this.
As for the PowerClear, I've used it twice, and it did not disappoint. The PowerSpin is just about equally capable (5' shorter) and easier to store. It's just that the PowerClear is so much more "civilized". Either one will do the same job, but I for one am not getting any younger, and I'll never grow a taste for getting sprayed in the face with drain "juice", so yeah, I'm happy with it. I did catch mine for about $150 at an all-time price low. I keep a pair of long and heavyweight PVC gloves (like sandblasting gloves) dedicated to snaking drains in the box with it, because leather gloves soak up everything. Yuck.
