105x20 7k or 10k enclosed trailer for moving and resale
Crabman
Alexandria, VA/Dameron, MD
Enclosed 20 footer will weigh in the range of 3000 lb plus or minus.
So cargo capacity is 4000 lb with the 7000, 7000 with the 10,000, a big difference.
Not sure what the delta is on the cost but I would lean 10,000.
Of course this is GJ where bigger is nearly always better...
Good luck with finding the right fit and also with the move!
dcg9381
Austin, TX
Planning on purchasing a trailer to move from tx to tn, would a 10k trailer be better for resale than a 7k?
Thanks
Might look at FB marketplace and change location to TN. A 10k trailer is usually 20'+... Pretty big, starting to get into not-great with 1/2 tons.
Why not U-haul trailer it? You're going to eat a few thousand on resale.
LJZ
Rochester NY
Careful on the trailers.
Seen friends go down the road your on and its a good alternative.
Your not time strapped and ya can do with it what ya will.
If main thinking is resale then ya have to think of that market.
Make sure its a ramp door not cargo door for bigger resale market.
If you get a steel trailer instead of Alloy it will be cheaper.
Your target is racers or the high end landscaper etc.
Its nice to have torsion axles. Upgrade tires if available
Go to racing junk and have a look. There's good used on there but obs be vigilant.
My Haulmark has been flawless for me
good luck
finn
The UP, God's country
I bought a lightly used, 25’ 7k, low quality Georgia made trailer for my 440 mile move. It was really too big for my Ram1500, but was tolerable after I added load leveling torsion bars. The truck had Firestone air bag helpers and was totally satisfactory with my regular open car trailer on the many similar trips I made. The enclosed trailer was a little shakey. Made several trips without real issues, though.
Sold it for exactly what I paid, to a more or less local circle track racer a couple of months later. First phone call an hour after posting it on CL And it was gone.
kwb
PNW
I have a similar trailer - didn't think too much about it since it was for snowmobiles which are fairly light. I wish I had upsized the axles when I ordered it, I also wish I opted for the thicker skin thickness (.040" instead of .030")
jblnut
In the Middle of MN
2024 ram 2500 hd power wagon w 6.4 gas engine, w 4.10 gears.
Best get a bed mounted fuel tank as well lol.
If budget allows going larger in all dimensions isn’t something you’ll regret up to the point that it’s actually too large. Such as a 40’ stacked trailer. That’s obviously too large but a 24’ or larger with heavier axles would likely be fine behind that truck. Going slower with a larger load in my eyes is always safer than going faster with a lighter load.
TerryH
Springdale, AR
Thanks not sure the market/resale value for at24'.
Resale is likely better for a 24'. Racers often have 4 wheelers or golf cars so that extra room is a big plus. We have a Haulmark Edge 20' race trailer for our show cars. 10k GVW on torsion axles. It's our 4th Haulmark and they are great trailers. I'd be very cautious of a lot of the cheaper made trailers. I see nightmare stories posted on the racing groups all the time on the cheap ones. Good brands like Haulmark etc... will definitely cost more but will also sell for more when you are done with it. Racers are going to be looking for cabinets and such also but a bare interior is definitely cheaper and will appeal to many. Haulmark has different packages. Our is a Sportsman so it has front cabinets and a completely finished out interior. Trailers are super handy for all sorts of things so you may discover that keeping it would be to your advantage.
iagsxr
Vinton, Iowa
An 8.5' x 24' with 5200lb axles is gold in the enclosed trailer world.
A kid I help with his race car is looking for a 8,5' x 20' V-nose. I can tell you that on my FB Marketplace for every one with 5200lb axles there are ten with 3500lb.
I would absolutely go with 5200lb axles irregardless of which length you end up with.
LXCam
I’d suggest going with a 28 considering the rig you have (same as mine) This was my mover n shaker out to AZ on our move. I built some raised platforms to help deal with not stacking whatever’s and it worked out perfect. I never made a trip that wasn’t maxed out in capacity.
Snapped-off
Indiana
My last move I paid 15.5k for the 20' trailer and struggled to sell it a few months later for 9k.
***** cause I sold the first 28' trailer a few years prior to that. Should've just kept it. The 3 years of storage fees would've been less than the loss on the 2nd trailer.
R
roadrunner255
Driftwood, Texas
Anyone have knowledge with trailers plus interstate patriot nose 9990k trailer.
Any reputable dealers folks cold recommend in central Texas?
thanks
R
roadrunner255
Driftwood, Texas
Thanks all, how often do you all grease the hubs?
Trip is almost 1100 miles one way, and I know that your supposed to jack up the wheel and rotate it while you do 2 or 3 pumps on the grease gun.
Diesel Dan
TN
Personally, I wouldn't go lower than a 10k trailer.
Bought new enclosed trailers for 2 different moves. 20ft, 10k and one had +1' of height. If your only plan with the trailer is moving, buy the cheapest model you can. One of my trailers was a better brand auto hauler and most that looked at it kept comparing my asking price to that of a low end trailer.
Short of no grease or water intrusion bearing life has more to do with driving style, jmo. Running heavy and doing lots of tight turns, scrubbing the tires, is hard on the bearings/spindles regardless of grease.
WE3ZS
Media PA
In my experience, trailer brake gain is dependent on the particular trailer and current brake wear and adjustments. On my fifthwheel camper with electric over hydraulic disc brakes I run the gain at 5.5 out of 10, but that is a completely different situation from (assuming) your electric drum brakes.
In the past I would set the gain by playing around on a loose surface at 10 MPH and adjust to where they would just flirt with locking up.
R
roadrunner255
Driftwood, Texas
Thanks all, how many folks use the gear selector while in tiw mode?
I liked using it when not in tow mode, let's me know what gear I'm in and disables mds mode.
WE3ZS
Media PA
My dash always shows which gear it’s in (‘24 F-450) and yes I do sometimes use the +/- buttons on the shifter to help control downhill speed when towing the fiver, that and the auto exhaust brake setting. I never use the shift buttons accelerating, the truck has ridiculous power and handles the 19K fiver with zero drama.
R
roadrunner255
Driftwood, Texas
Thanks all, my wd hitch doesn't have sway control but can be added.
Air is suggesting dual sway control due to the size and weight of the trailer.
Would it be worth adding?
Cheers
Blk88GT
Manitoba
The only time I've experienced enough sway to bother me was when the trailer was empty. Oddly enough, both my trailers were purchased ~850 miles away and came home empty.
I've always towed with 3/4 tons or a (now) 1 ton though!
OldCarGuy
I recommend 10K axles over 7K. A few bucks more gives you far more carrying capacity. Along with more ground clearance, bigger tires and most import larger brakes.
Second I suggest purchasing an all aluminum construction model. Though the cost difference is steep; it will have better resale value. The weight savings approximately 1,500 pounds, that you'll be dragging behind you.
It was a no brainier for me. My smaller motorhome maximum towing capacity is 5,000 pounds. My 102” by 24' steel car hauler is 4,000 pounds leaves but 1,000 load. I picked up an aluminum 102” by 20' with 7' ceiling with a curb weight is 2,100 pounds giving 2,900 load capacity. Just returned from a 4,300 mile round trip to Phoenix.
WE3ZS
Media PA
Cheers
Serious trailer sway is typically caused by too little weight on the tongue, when loading it be sure to load the heavier stuff up front to avoid sway.
Do you fully understand how to set up and adjust your weight distribution hitch? It important to to get it dialed in correctly.
R
roadrunner255
Driftwood, Texas
Forgot to ask, I plan on trailering my 1100 lb harley road glide on a condor wheel chock.
What's the best way to protect the bike from shifting cargo?
Cheers!
mike93lx
Richmond, VA
Cheers!
Properly securing everything. Straps, load bars.
A great way to get moving blankets to stay in place is stretch wrap. For moving, I like having both a narrow roll and a wide roll on hand.
Diesel Dan
TN
I think you mean 10k gvw.
They do make single wheel 10k axles but those wheels/tires are not rated for that. My dump trailer has 8k axles and has 17.5" wheels/tires.
That said, I wouldn't buy a tandem axle trailer with a 7k gvw either. Minimum 10k with 6 lug 5200/6000 lb axles. On a quality axle the only difference between 5.2/6k axles is the wheel/tire combo. Usually, to get the 6k rating it requires 16" wheels/tires.
Nice looking rig.
