YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 498
I installed a new outdoor faucet. Have done this on indoor ones a few times for sinks. Something like this I installed for outside. The older one was the same length, but a different brand, it was not shutting completely and believed to be kind old from previous home owners.
I used plumbers tape around the threads. Went around clockwise (i.e., the direction you have to turn it, to fasten it into the water line inside the house), roughly twice. Got it installed with the anti-freeze mechanism facing up. After turning the water back on I noticed that I have a very small leak. Maybe a single drop or two per hour at the joint that has the blue arrow. I have put a plastic cup there for the mean time. Came here to see if anyone has any suggestions on how to achieve zero leaks. I have tightened it pretty good with open end combination wrenches. Not really comfortable tightening it any more. Defiantly cannot tighten it another 360 degrees and get another revolution out of it to get the anti-frost mechanism at the top.
Thank you for any help!
