PopcornSutton
Not mentioned yet is the bar condition. Worn grooves will allow a chain to wander side to side and cause crooked cuts. I replace them, but I saw a utube where a guy was using a roller to tighten groove.
A few different angles of the same set of cutters.Pic of a tooth?
Is that sharpened, or dull?A few different angles of the same set of cutters.
LOL.Is that sharpened, or dull?
Hard to tell (some pics aren't clear) but you appear to have wildly varying geometry
LOL.
Kinda in between - neither sharpened or totally dull.
I have the harbor freight one. It works very well. I normally wait until I have 5 or 6 chains ready to sharpen before I break it out. It won't touch the rakers though, so I still need to flat file or dremel those.I finally bought one of these.
This takes all the variation out of the job. I was having trouble w/ matching the left and right teeth just because of the difference in the way my arms work. Also had trouble w/ the flat file and getting all the teeth the same height. I have experimented w/ taking the rakers down an extra .010" and that really helps. It is a lot of $ but I now feel like I can make a chain not just better but equal to new.Loading…
www.northerntool.com
All dull as hell.A few different angles of the same set of cutters.
Go on YouTube and watch some saw sharpening videos. Specifically from the channels below. If your chain is properly sharpened and the rakers are at a proper depth to match the wood and saw it will literally bring a tear to your eye the first time you touch it to wood. I was told by an old logger buddy “stick the dogs in your carry bag and you’ll learn how to properly dress a chain in a hurry”. He was correct in a bunch of ways. The only time you really need the dogs are when you’re lining up a face cut and making the back cut. If the chain is sharp and the rakers are adjusted properly it should self feed in no matter the size of the saw or bar. My 066 and a 42” bar will self feed when things are proper. It’s neat.LOL.
Kinda in between - neither sharpened nor totally dull. Ever since cutting some roots, sharpening (as others have pointed 2 passes isn't enough, so I probably need to do several passes) has not yielded nice size chips the way I was getting on earlier sharpenings (prior to root cutting). I've got the depth guide on order, so I'll sharpen it some more, focusing on getting the cutters more consistent, then check the rakers. It's a $14 chain, so it's not worth going nuts over, but if I can get it churning out chips for a few minutes worth of work, I'll do it - I can make it my beater chain for cutting what I shouldn't be cutting with a chainsaw, and get a new chain that only ever touches wood.
Since we're on the topic - what chains do you folks like using?
I replaced one of my abused chains with a Husqvarna X cut (that was all the hardware store had) and was pretty impressed with how well it's held up since the change. It's only needed to be tightened once and I've put it through ~3 tanks of fuel and it's still throwing big chips.
Has anyone used a carbide chain? I'm definitely curious about them.
Those dont look right. Looks like a flat file cutting downward on the cutting teeth. If so, that is very wrong.A few different angles of the same set of cutters.
There are a couple guys here at work that run carbide chains but they do a lot of root type work. They require special stones for sharpening, so few shops offer sharpening.Since we're on the topic - what chains do you folks like using?
Billy Ray is a crack up but his videos tend to run long and a bit tiring. He is out on Vancouver Island in BC. From my view there is logger sharpening - for personal use, then there is rental/shop sharpening - which is what I do at work. I can sharpen much better than most of the guys here (Public Works) can use a saw.Go on YouTube and watch some saw sharpening videos. Specifically from the channels below. If your chain is properly sharpened and the rakers are at a proper depth to match the wood and saw it will literally bring a tear to your eye the first time you touch it to wood. I was told by an old logger buddy “stick the dogs in your carry bag and you’ll learn how to properly dress a chain in a hurry”. He was correct in a bunch of ways. The only time you really need the dogs are when you’re lining up a face cut and making the back cut. If the chain is sharp and the rakers are adjusted properly it should self feed in no matter the size of the saw or bar. My 066 and a 42” bar will self feed when things are proper. It’s neat.
Westcoast Saw
Guilty of Treeson
Buckin Billy (if you can stand him he has decent sharpening videos)
I use a mix of Stihl and 8Ten el'cheapos. The 8Ten chains came here on a whim one day to see what I could get a cheap chain to do and I'm actually very impressed. I've worn a few dozen full skip 24" chains down to the nubs and they hold their edges and don't seem to stretch excessively like some other cheap chains I've used.Since we're on the topic - what chains do you folks like using?
Yes but most of us don't do the kinds of cutting that a carbide chain will really show it's strength. They're great in rescue operations but slow as all get out if you're going to use it to actually cut wood. It's faster to keep a regular chain sharp than to cut with a sharp carbide chain. I can sharpen them here but probably only do a few dozen a year.Has anyone used a carbide chain? I'm definitely curious about them.
Most people that run saws don't spend enough time with the saw to really get to know it well enough to be able to tell the difference in the different kinds of sharpening. They'll see one grind as faster which is great but they never last as long. I sharpen for longevity and not speed. I would rather be able to run the same chain for a few hours, or all day, than have to carry tons of extra chains and take the time to swap or field sharpen them. That being said, having a fast chain is fun when you're trying to show off a bit. Toss an aggressive ground chain on the ported 066 and watch the chips fly !!Billy Ray is a crack up but his videos tend to run long and a bit tiring. He is out on Vancouver Island in BC. From my view there is logger sharpening - for personal use, then there is rental/shop sharpening - which is what I do at work. I can sharpen much better than most of the guys here (Public Works) can use a saw.
Carbide are great for rescue but hit the wrong thing and you can knock off the teeth, rendering the chain useless.Yes but most of us don't do the kinds of cutting that a carbide chain will really show it's strength. They're great in rescue operations but slow as all get out if you're going to use it to actually cut wood. It's faster to keep a regular chain sharp than to cut with a sharp carbide chain. I can sharpen them here but probably only do a few dozen a year.
Yet another tool I just couldn't live without. Ya'll are gonna drive me to the poor house.I was never very consistent using a file guide that required using your eye to maintain the proper angles when hand filing. Since I got a Granberg File-N-Joint (about 30 years ago), I’ve been able to consistently produce sharp chains.
G106B File-N-Joint Chainsaw File Guide | Made in USA
Precision bar-mounted chainsaw file guide for accurate sharpening and depth gauge setting. Invented by Granberg and made in the USA.www.granberg.com
There are lots of folks that put a lot of importance in making sure each tooth is exactly the same and I’ve never been one of them. It’s one of the few things that I will go against and say to sharpen each as its own. I don’t have issues with things cutting sideways or chattering or other issues. Sharpen each tooth and be on your way.Find the worst tooth, count the passes to bring that tooth back. Mark the tooth with a sharpie. Apply the same number of passes to all the other teeth. Check/file the rakers. Chuck the bar is parallel and doesn’t have a burr. Clean the groove out in the bar. Check its oiling. Done.
If I’ve only dinked a tooth or two I won’t file them all to match, but the problem with dressing each one not matching them is errors compound, which causes the chain to not cut straight and cause unnecessary bar wear.
That is very much true. File sharpening only removes the smallest amount needed, whereas using a machine grinder removes much more material.When I was 16 and working in a mower/chain saw shop, we had to use a file on rental chain saws but could use a Dremel tool on customer saws. Owner said he got twice the life of a chain by file sharpening it versus Dremel tool. He had been in business for 12 years at that time and told me it made sense to sharpen with a file if you owned the saw. That was over 60 years ago and is probably still true, but labor and chain prices have changed a bit.
For sure. I could see the material that using 4-1/2" cutoff disc was taking off, but for quickly sharpening an otherwise hopeless chain, this worked great. It would have been a waste of a file and my time to try to revive that chain by manually filing. I ordered a Dremel grinding stone of the appropriate diameter to maintain my beater chain going forward. I'll use the file and use it more frequently to maintain the new chain.That is very much true. File sharpening only removes the smallest amount needed, whereas using a machine grinder removes much more material.
At least 80% of the chains I sharpen at work need the grinder vs hand filing. Most of the guys treat their equipment worse than rental stuff.For sure. I could see the material that using 4-1/2" cutoff disc was taking off, but for quickly sharpening an otherwise hopeless chain, this worked great. It would have been a waste of a file and my time to try to revive that chain by manually filing. I ordered a Dremel grinding stone of the appropriate diameter to maintain my beater chain going forward. I'll use the file and use it more frequently to maintain the new chain.
Company in Portland, Oregon moves houses. I used them quite a few years ago. When they need to move them in pieces (say it's an L shape too big for the roads) they use carbide chains and just cut through everything - wood, gutters, shingles... No idea how often they replace them but they get the job done.Since we're on the topic - what chains do you folks like using?
