Painting a fiberglass man door on garage
reader2580
Minneapolis, MN
I have a fiberglass man door on my garage that has not been painted. The UV is causing the fiberglass to delaminate slightly. I know I need to sand before painting. Do I need to use filler before painting? I am going to use an acrylic trim paint from Sherwin-Williams.
PCustoms
VT
Not sure paint is going to help a delaminated door....
Also not sure what the goal is with fillers.
Pictures?
R
reader2580
Minneapolis, MN
The delamination is hardly noticeable. I just happened to notice it the other day. I did some Google searching and found suggestions to use body filler or epoxy to make the door smooth after sanding with 400 grit.
bluedog225
Texas
People routinely paint fiberglass boats. Lots of info there. Some use quality house paint for a “workboat” finish. Works fine. Would look fine for a garage door. You are not going for boat gloss. Depending on condition, delam might just look like wood finish.
Shiftless
East Bay SFO
Sand lightly. Wash thoroughly. Apply good quality primer… I use Stix. Then 2 coats of acrylic satin finish and you’ll be good to go.
Unless there are major defects, I wouldn’t use filler.
If you apply with a roller, the resulting texture will hide very minor imperfections. If you want a show car finish, there is going to be a LOT of work and lots of expensive product involved. 😎
At some point, a new door would be easier and less expensive.
PCustoms
VT
If you've sanded to 400 grit that is more then smooth enough for paint...
A pic or two of what you're dealing with will help steer the advice
R
reader2580
Minneapolis, MN
The recommendations I have seen are to sand with 400 grit. I have not done anything yet. I will try to get a picture. The delamination is very slight.
I am not trying to do anything fancy here. I hadn't painted it prior to this because the white look is just fine to me. I didn't realize UV would damage the unpainted fiberglass.
R
reader2580
Minneapolis, MN
for brush or roller painting 400 is overkill... but it will work . I like a bit more tooth to help the paint bond, but C'est la vie
I am just going by what I found on another forum when doing a Google search yesterday. I forgot to take a picture when I was outside earlier, but I am heading back out in a few minutes.
R
reader2580
Minneapolis, MN
I took a close up picture because you couldn't see the delaminations in in the fading light otherwise. The door is very dirty. The thumbnail is not enough to see the damage. You will need to click on the thumbnail. It is quite rough.
PCustoms
VT
What the hell...
That's not delamination, that's the raw glass from the fiberglass matt used on the outer layer.
Edit:
CSM
Typical (cheap) fiberglass process:
Wax tool (this is the outward facing surface)
Apply gel coat/finish
Back gel coat with strand mat
Back mat with structural glass
You seem to be very light on the gel/finish. If the door is super old it my be degraded as it wasn't painted. Not sure you can save it or how interested you are in dealing with itchy nasty dust vs. Buying a new door.
PCustoms
VT
This thread made me think of walking past the door and window aisle at the orange store, you can smell the styrene off gassing from poorly cured doors.
Based on smell alone I'm not sure I'd buy a fiberglass product
R
reader2580
Minneapolis, MN
What the hell...
It is a Menards door. Probably not the best door. The damage is new. It definitely was not like that last fall. I have a two year old door from Menards on my new garage that doesn't have this issue. This door is from 2019 I recall.
PCustoms
VT
Is the newer one painted?
If you're looking to save this I'd hit a spot with 220 on a DA sander and see how it looks. Be warned, that could be a super itchy process and you absolutely need to wear proper lung protection.
Assuming you can get it sort of kind of smooth, I would hit it with the best exterior primer you can find followed by several coats of exterior paint.
Their specific products for fiberglass that would work really well in this situation, but they're probably going to run you more than just buying a new door
K13
St. Albert, AB Canada
Body filler will work perfectly fine on that but I would probably use a finishing putty rather that a filler as you won't need much build. Sand put a light skim on it sand again then prime and paint.
volaredon
IL
I need new man doors for both the attached garage and the detached. Am seeing more fiberglass doors these days for sale. I was gonna ask for pros/cons vs typical metal clad wood doors as mine are definitely delaminated at the bottom. I was looking at a fiberglass one on the clearance rack at the local lumber yard that needs to be painted since it's green and my stuff is brown. Laying a door on sawhorses and getting out the spray gun is not a big deal
volaredon
IL
Ok I went to Sherwin Williams as I need to spray 2 of my overhead garage doors. All over Google they show that Sherwin Williams and behr have the paint codes for their factory colors. I actually have the code from Ideal door/clopay and nobody here could do anything with that.
The SW "guru" actually came to my house and color matched my 2 newer (2 years old) doors so I could make my 20 year old ones look 2 years old again
I ended up buying 2 fiberglass man doors that come printed and need top coated and Id like to match the overhead doors
The guru came up with their acrolon line a water based 2 part polyurethane. Matched I guess to a common SW color which they call "otter". Clopay doors calls it a chocolate brown.
He sold me a gallon of primer and 2 gallons of the paint and 2 quarts of hardener mixed to this color.
The overhead doors that need paint are steel and are 100 feet away from the ones im trying to match. Not right adjacent to the newer doors so close is good enough, off a 1/2 a shade most won't notice.
The guru went with water based because he was worried about how genuine the "fiberglass" is on the man doors and what solvent in conventional paint might do to the fiberglass.
I've never dealt with water based besides latex house paint before so this will be new to me.
volaredon
IL
Finally had good weather and no wind.
I filled some dents in the overhead doors and primed them before I painted.
The whole reason for going to this amount of work is because after our recent hailstorm state farm will only allow for replacing 3 panels of the 10 that there are between the 2 doors. 3 new panels among 10 that are 20 years old and faded... No way. I told them to replace all or none. Supposedly I'm getting paid for those 3 panels. But the payments are locked up between the construction company doing the roof/gutters on the house and garage and my mortgage company. Something I am very sore about. Pay and pay and pay and pay some more and listen to the spiel what's covered and when I need to use them they bend me over the coals and nit pick
They allowed for exactly ONE piece of 20 yo siding on that garage door side of the garage 3 pieces of siding on the right side as you are looking 3tge door end and siding for the entire north wall only (back wall opposite the overhead doors) when all is said and done I am kicking PNC Bank and state fraud insurance to the curb
Any place I can tell my story and how I'm being screwed to keep someone else from the same fate im all ears... I never in a million years thought state fraud would name the bank along with my name on the "pay to the order of" line
Instead of signing off so I can continue with repairs they confiscated the insurance check and 2.5 weeks later I get $4k from PNC when the check I took them that I got from state fraud was for $14k.... They're holding (rounded off, it's a little more than) $10k of my money for no reason. I am beyond furious.
