nadogail
Coronado, CA
Completed the cutting all of the parts for 6 Elevated Raised Bed Planter Boxes that I am hiring a 20 year old kid to assemble.
He needs Money, has no work history and I can afford to pay him. He will not be using any tools with sharp edges, just a pneumatic brad nailer. If he shows up tomorrow. he will leave with a little skill and some honest cash in his pocket
GrayFlattop
Chicago
Swapped winter for summer rubber on the wife’s car and gave it a the once-over. I’ve not been able to duplicate an issue reported last week. There were no stored DTC’s. While driving, the emergency flashers started flashing, at least she pulled over, cycling button did nothing. Turning the car off and restarting had no effect. Frustrated, she headed home and the flashers stopped operating.
The switch appears to work fine and it hasn’t happened since. I’m ok with that repair.
If it happens again I’ll dig a little deeper, but the car is 18 years old, garage kept and driven twice a week at most. I love an intermittent electrical problem. Yay.
Fordguy1964
Houston County, Alabama
Pulled the mower into the garage to diagnose slow drive. Was worried that the non serviceable drive motors were going out. Found out it was a lot easier than that. The belt had stretched and the tensioner was at almost max travel. The tensioner was hitting the edge of the stamped hole for the motor. I went through my stash of belts and found one the right size and replaced it. The whole process wasn't too bad and it was good to get a fix for $0! Still running strong. Not bad for a 16 year old mower!
Got battery powered yard tools out and then put them back later on.
Last Sat I ordered a pole chain saw, with 2 batteries and extra blades.
As long as you didn't actually use them... that would be work.
Which will lead to work... 30 + YO dead maple tree to take down, and poplars and oaks needs some trimming, probably the alder as well
Fordguy1964
Sounds like a lot of work. The cutting isn't so bad. It is the bending to pick it up that would kill me.
Beerhippie
Far NE Oregon
A twenty-year old? We were full grown at twenty. Out in the woods using chainsaws and other nice, safe tools. I have ten fingers and ten toes, so it worked.
Firewood! Alder is my favorite smoking wood, esp. for salmon. Maybe not the same alder you have.
bugnut
Central Ohio
printed a 5.5" diam with a 4 on 4 hole pattern traced to the spare holder, ground and painted installed spare. Then a cheap trailer jack foot arrived, installed that, really want to change bolt for more clearance, added to shopping list. Started tackling making the wheelie bar on the trike easy to remove. I think I have a solution......TBD
trailer foot was dirt cheap at $3.59
bmwrd0
Beaver Fever Oregon
Spent the time cleaning, packing, shipping, and then a fun project: The new project gun!
spent time disassembling so I can soak the trigger and breach assemblies and get a good cleaning out of the stocks. This is a shot of the two assemblies, which are made to be easy to pull for cleaning, ready for a mineral spirits bath. More info in my shop thread if it interests you. I will say that the machining on this is top notch, blows almost everything else away.
BreeStephany
Oregon
Garage queen or user?
Me or the saw? :ROFLMAO:
Its a gift for a very skilled carpenter friend of mine. When I started the project, they were actively working in the trade, however, the winter after our big move to Oregon, they had a very significant skiing accident that resulted in multiple surgeries and a pretty life altering head injury. They are still mobile and getting better each and every day, but still have a long road ahead to recovery, so I'm not sure if it will be a wall hanger or a put through its paces, but the saw itself was fully rebuilt and has been tested and ready for a life of abuse in the field.
Either way, I know it is a tool they will truly appreciate!
BreeStephany
Oregon
Oh, c'mon--not a hand-sharpened steel-tooth blade to match?
I still have the original Skil 10" blade it came with, just haven't got around to cleaning it up yet, but the 10" carbide diablo's do VERY well on these saws and are quick and easy to modify in the field if you need a replacement. Just need a dremel, scratch awl, small needle file and a a diamond knockout filler for the stencil and you can have a new blade made up in less than 10 minutes.
I will be sending them the 'jig' tool for making new blades which is a 5/8" x 1" bolt, 2x fender washers, a 5/8" diamond knockout plug, lockwasher and nut. Simply put the bolt through the factory 5/8" hole, tighten down, trace the diamond knockout and cut out the diamond and you are ready to go.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Just did the finishing touches on my Skil 107 tonight and put on the labels that @mattblast made up for this project. Very happy with how it all came together.
It has some a LONG way from where I found it 2 years ago!
I'm curious; does it use the same brushes and switch as the modern 77?
Also, I've fixed a number of saws like this that didn't work.
The brush holder has a groove in it and at the end of the stator wire there's a spring-like thing that wraps around it. If you rip with a dull blade for very long, the spring will weaken and burn up. If the saw is plugged in to 240 volts, the spring will blow up......
My solution is to solder the wire directly to the brass brush holder.
Beerhippie
Far NE Oregon
Spent most of the morning playing with my black caulk:
The original job I did about twenty years ago had begun to fail, so I cut and scraped the old stuff out, then laid down a fresh bead. I've done better, but it's been a while and my hands shake more than they used to.
Once the caulk is fully set, I'll go back with my razor scraper and clean that up some.
BreeStephany
Oregon
The brushes on the 107 are 0.2500 x 0.7490 x 0.8750 deep.
As for the switch, they are the same switch on the 67 - 127 series of the era, but are not the same as the modern switches. They were made by CH / Eaton and are MUCH more durable and user servicable than the modern switches.... BUT... replacements do not exist unless you find NOS, at least that I have found.
If a saw is missing a switch or the switch cover on the handle, its generally a no-go for me unless I can get it for cheap enough to part it out.
The 107 and 127 have a round brass strap clamp that the wire is soldered to and then tightens down onto the brush holders with a set screw. They are pretty durable, but when abused, will do the same as the spring. In my opnion, this is a good fusible link in the design that protects the motor from buring up.
Just my two cents.
kaymccampbell
Upstate New York
I bought a caulk tool on Crapazon. Makes my essential tremor go away.
Beerhippie
Far NE Oregon
I was taught to cut the end of the tube square at the size you want your fillet to be. Push the caulk in front of the cut end, adding just enough to see a tiny bead in front. Done well, it leaves a perfect fillet bead.
I should have made a few practice passes on something and then finished my morning coffee before attempting something I wanted to look nice. Worse comes to worst, I'll cut out it out and do it again. The only part that really matters is that long pass down the front--which was the first one I did after being a few (ten?) years out of practice.
I used the odorless silicone for this so the pub doesn't stink of acetic acid--something really undesirable in beer. It takes forever to set.
Mr. Tool
Repurposed an old shelf / coat rack my son no longer wanted. He's had it forever, but I guess he's to the age where it is no longer cool. Makes a fine place to hang shop shirts and aprons, and keeps some shop solvents handy.
That shelf is nice and good that you "re-purposed it".....but what I really am diggin are those shop "solvents"! (y)
