pima67
Tucson, AZ
Went in the garage and got in the Exp for a trip to the doc to renew my meds. forgot to disarm the Blink camera so stopped and did that. The doc is retiring at the end of the month so need to find a new one. This medical group is full of specialists but no other primary care doc or NP. Rather strange for a big group with offices in other locations. Could drive to 2 other locations for this group that have a PC but they are quite far away. I try to limit my driving due to the idiot drivers around here. The ones that race up to the red light, slam on the brakes and complain about the price of gasoline!
Beerhippie
Far NE Oregon
Got my newly rebuilt alternator tested over at NAPA. Fail. 11.5V and noisy as hell. I guess I'm not much of an alternator rebuilder.
Not sure why the new bearings are noisy--something isn't aligned right?
Maybe I should have replaced the rectifiers, too. Any suggestions on testing those?
Good news is that no magic smoke escaped.
Shadowdog500
Down the shore
I changed the desiccant in my old HF Pipe Bomb style line dryer today.
I’ve had this dryer for probably 15 years and decided to change the desiccant today to make sure it is good to do a little powder coating.
I have enough desiccant to fill It twice so I swap the desiccant when needed and keep the extra in a mason jar.
First thing is to regenerate the desiccant in the mason jar while I move things and get the desiccant out of the pipe. I used my powder coat oven and ran it at 250°f for 2.5 hours. I put a Kill A Watt meter on the outlet to check the max current, which is 11.12A max while heating, then the heater elements cycles on and off when at temperature with the low end being 0.08A. You can also enter your billing rate from the power company into the Kill A Watt and it will calculate the cost of the electricity used and it only cost 23¢ to regenerate the desiccant, so it’s worth the effort!
The desiccant was in the dryer for a couple years and I was surprised that it could have gone a bit more.
The threads are not tapered and do not bind because the cap is supposed to seal using this nylon washer in the bottom of the cap. It never sealed fully and leaked since new, so I usually put some Rectorseal on the threads and it seals beautifully.
Bottom baffle and cap
No leaks
The thing looked beautiful inside with no corrosion.
I topped it off with the regenerated desiccant, put the top baffle in, applied Rectorseal, and reinstalled the cap and snugged using a 36mm axle nut socket.
No leaks
Shadowdog500
Down the shore
This is the little powder coat project that prompted me to change the desiccant.
The latch on my new fence I had installed last fall does not go down enough to clear the pin in the door. The pin in the door always rubbed the latch when opening. My wife complained about it so I re-profiled the latch so it clears even if the door sags. Then I re powder coated the part I profiled.
This is a brand new latch to show it doesn’t completely open
This is the one I profiled
Profiled one Installed.
Now the latch fully opens.
I guess that's what I get for mistaking my vise for a bearing press....
Nah. Before I owned a press I pressed hundreds of bearings in with my vise. Maybe you got a bad/counterfeit bearing. I got saddled with a bunch once. Pissed me off. They lasted minutes.
One thing I learned about needle bearings (for U joints in particular) - the "grease" they are packed with at the factory is not a lubricant. its a preservative. Clean it out and repack with proper bearing grease.
ObnoxiousFumes
Southwest Sask
Still waiting for my rear tires to show up but I tried to start the garden tractor project yesterday and discovered I hadn’t drained the fuel before disassembly a year and a half ago…. Darn infernal combustion engines, the carbonator is all gummed up! Some nice crusties in the bowl:IMG_5697.jpeg
DGersic
DeKalb, IL
Waxed the car. Cleaned windows, inside and out, vacuumed. Checked the tires. Checked the lights. Checked the fluids, primed the carb, and fired the engine. checked for leaks. Let it come up to temp, fan kicked in, watched the temp gauge drop until the fan cut off. Declared it good to go for tomorrow’s run up in to Wisconsin.
GrayFlattop
Chicago
Be careful crossing the Cheddar curtain!
ObnoxiousFumes
Southwest Sask
Tires showed up this afternoon! Boy I wish I had a tire machine.
Need to get some proper carb cleaner to finish up the carb, then maybe I can cut grass this weekend. It’s kinda getting away on me already.
rd65
Granite Falls, WA
Not too terrible. One from work awhile back, cant remember what it was off of.
Demon69
Surrey UK
I don’t know man, that thing looks sketchy as hell. And if you really look at it, the bolts that hold those plastic wheels are holding the whole thing up.
Notice the guy always steps to the side too, just incase that thing decides to shoot out from under the wheel.lol
Not so bad bud, those bolts are partially threaded M12, grade 8 (allegedly 😅). Offset rollers are a normal design but usually tucked away out of sight and mind in a column. Them failing is way down the list of my concerns :ROFLMAO:
That electric effort under the van, not so sure that spitting outs a problem but it is at capacity in that situation, and after a quick play with the cheapies lifting from the side like that, a couple issues became obvious. The vehicle goes up in a tighter arc and the jack has to travel, also the contact patch of the tyre creeps to the outside edge of the fork as the vehicle goes up, this increases the bending moment on the jack. The nicest way to lift is two jacks under the same axle, straight up, no need for the lift to travel.
Shimming the uprights got the carriage freed up and the whole gig working well, also chopped 10 inch of the lever, no need for it at these loads and so I dont have to cut slots in my walls 😂
Some pics to make ya eye twitch 😅(y)
edit: man i should proof read my stuff before I post, sound like an import lol
Mike65
Horse Pasture, Va.
@Demon69 The first new car dealership I worked at back in 1978-1983 had these air bumper jacks. They remined me of the ones you have pictured.
Demon69
Surrey UK
Cheers man, Ive never come across one of those in the uk before.
kaymccampbell
Upstate New York
I used to have the Mohawk version of those. Jumpy as hell.
Jakeweldsalittle
My dad still has an old version of these that my grandfather used in his Texaco station back in the day. We don't use it all the time, but it is handy. Takes up some space though ha.
The problem with those is they need a steel bumper car to use them. once 5MPH bumpers came they were useless. My buddy had one. We used it for his 59 PU truck.
Jakeweldsalittle
Yep absolutely agree. That's why we don't use it as much now. Worked great on the ol man's 85 chevy before it went to the junkyard, newer vehicles not so much. We built a couple sets of stacked wood ramps that get most of the use now for oil changes, etc.
M.Brane
1 hr N/W of LA LA Land
That electric effort under the van, not so sure that spitting outs a problem but it is at capacity in that situation, and after a quick play with the cheapies lifting from the side like that, a couple issues became obvious. The vehicle goes up in tighter arc and the jack has to travel, also the contact patch of the tyre creeps to the outside edge of the fork as the vehicle goes up, this increases the bending moment on the jack. The nicest way to lift is two jacks under the same axle, straight up, no need for lift to travel.
Shimming the uprights got the carriage freed up whole gig working well, also chopped 10 inch of the lever, not need for it at these loads and so I dont have to cut slots in my walls 😂
Those are like mini manual versions of the MAHA lifts we have at work.
