BurtEggley
- Joined
- Oct 8, 2024
- Messages
- 884
this just came up on my youtube feed. Good feedback on some of the grinders above.
Have you seen this one.this just came up on my youtube feed. Good feedback on some of the grinders above.
8" has draws more amps, but it's also gotta turn a wheel that's 33% bigger in diameter, which means that it's probably easier to stall, which seems to be a concern of yours. That said, if you let the wheel do the work like you should, the 8" will remove material faster because of the higher sfpm, all else being equal.yes. Thank you. I am thinking the jet 5 amp 6" jet if it will fit, but I don't know the base size. If not then maybe the dw756 or dw758 because they will fit my stand. They have no light so I will need to add something there because the grinder and stand are in a darker part or the garage, but i can add a light above them if needed. The DW756 6" is 4.0 amps and the DW758 8" is 4.2 amps. Either would work on my stand. The old grinder is 2.8 amps and is a 6" craftsman. Who knows, maybe I can rig a stand that fits the press when I am not using it and have both the old and new.Kudos to anyone who has stayed thru this with me.
But no one has the bolt pattern dimensions you needed.From Jet re JBG-6A for anyone who has the same question:
It largely depends on what you're doing.Not sure if this is considered trolling, but I can't see why anyone would invest in a new bench grinder. A used grinder made in Taiwan (not China), much like those sold by Dayton, would be a great basis for a BELT GRINDER. Having used and built numerous belt grinders over the past 20 years I rarely ever use a wheel grinder.
You can buy a decent adapter for $120 and belts are much cheaper (and safer) than wheels.
Interesting!Not sure if this is considered trolling, but I can't see why anyone would invest in a new bench grinder. A used grinder made in Taiwan (not China), much like those sold by Dayton, would be a great basis for a BELT GRINDER. Having used and built numerous belt grinders over the past 20 years I rarely ever use a wheel grinder.
multitoolgrinders.com
Everyone is just having fun, except you, apparently.Jesus, Mary, and Joseph! All of this chatter over a cheap freaking grinder. Just go buy one for God's sake. Also, I must say the tone of some of the comments explains why I come here less and less. Someone "kindly" told another that their father was full of BS. Well, that's lovely. I am getting tired of all of the people on-line and in person. Now that I am retired, a good week is when I only have to go out with the dullards and rude people in the general population once or twice. Less, if possible.
Wow! You ****! Nice find.Yesterday I picked up a new-in-box Craftsman grinder for $50 on Craigslist. It is 1/3 H.P., 4.7 amps, model # 397.19391, made in 1976.
I was the first to open the box and I had to assemble everything except the wheels. I inspected the wheels and no damage, the plastic eye shields are crystal clear, and just to check for spiders I peeked under the hood and no critters.
My dad had that exact same grinder when I was growing up. Sears knew their market pretty well, and this was perfectly fine for the typical handy homeowner shop.That's a Sears cheapy and it probably is more handy than the craptastic HF 6" Chynermans i purchased for my rented shop.
More handy? How would that work, a third wheel?That's a Sears cheapy and it probably is more handy than the craptastic HF 6" Chynermans i purchased for my rented shop.
Maybe there's supposed to be an arm and a hand that attaches to hold the work steady so you can use your own hands to scratch your, uh, noggin?More handy? How would that work, a third wheel?
I have a power feed drill press, 2 x 8" grinders and a large horizontal bandsaw bought in '86 = Taiwan, not Chinese. All still work just fine after many years of abuse. NOTHING was coming out of China then except Hong Kong and diplomatic students who played wicked table tennis.He said he’s in his seventies, and use tapers off with time.
Your father is full of BS. I picked up a Chinese grinder on clearance when a hardware store that was going out of business in about 1986. That’s forty years ago. Still works fine. That was in a residential situation. It’s moved a couple of times and is here in Az now.
