welding pinholes in sheetmetal,TIG?
toplessHO
central florida
Ive got some pinholes from rust in a trunk floor.
I dont want to go thru the replacement of trunk floor.
I have a small 140A multiprocess welder,that Ive bought a scratch start
TIG gun for,but wondering if thats the right way to go.
Should I scrap the scratch start and go with a finger control?
KwikFab
Central Valley, CA
Clean it all up nice and clean on both sides.
Wear a respirator for anything that may burn off and be harmful (adhesives, etc).
Worst case you blow through it and you replace a larger panel anyway but it won't hurt to work on what's there already for practice.
If you're not used to TIG at all, practice on some scrap first on a table. The trick is establishing the arc and maintaining a proper distance, followed by flicking it to kill the arc and hovering back over to provide shielding gas.
Watch some videos, and learn some technique before doing the actual project.
LopezBart
Lopez Island, WA
You should be able to weld this w/ a brass or copper block/ heavy sheet held underneath the floor against the hole using a MIG or TIG welder turned down quite low. Eastwood makes a little magnetic gadget to help hold it in place; a piece of brass sheet and some strong magnets should work as well.
T
toplessHO
central florida
Yes Ive used copper plate and various pieces of busbar to back up the voids.
ctandc72
VA
Have you cleaned it yet? You are likely to find you have more holes than you think.
What he said. Get the flap wheel out. Where there are pinholes there are at least weak spots or other rot. At least take a dead blow / sledge and see how sound the floor is.
T
toplessHO
central florida
Cleaning is done... knotted wire wheel,then blasting
what Im most concerned about is the need to regulate heat,
but I dont want to use a foot pedal
K13
St. Albert, AB Canada
Just use the MIG. Scratch starting while trying to do pinholes would be a nightmare and you are 100% going to need amperage control with a TIG for doing that type of work. Quick burst at low amperage with a MIG will be easier than the TIG if you don't have a proper set up, might even be easier than if you did. I TIG pretty much all my automotive sheetmetal work but would seriously consider using my MIG for pinholes in a trunk.
The Cobbler
mig with pulses . on/off .
might need to back it up with brass or copper depending on size of pin hole
you can also drill the pin holes out a bit larger & make round plugs to fit the hole ( weld a coat hanger to a pc of metal , put it in a drill and use an angle grinder to make it round & to size. tack in place, followed by pulses to weld it solid
Fitzees Fabrications on You Tube has done several episodes where he welds up pin holes using the above technique .
yhprum
Brisbane Australia
I know you didn’t ask and I might get roasted but have you thought about filling the hole with solder. Acid free and would have to be absolutely spotless. I have a large electric soldering iron that would put the heat right where it’s needed.
rlitman
Long Island
Yeah, out of position foot pedal control is annoying. I have an SSC Controls Touch 4 fingertip paddle, and find it no less intuitive than my SSC pedal. Me, I'm like a fish out of water without power control. YMMV, but if you're looking to find a way to get pedal like control without the pedal, there's good stuff out there that's not crazy expensive.
Sumboodie
AK
I usually use fiberglass Bondo. The metal is lilely paper thin and trying to weld will be tough.
Will end up turning a 1/4" hole into something like a 3" welded area.
v8nutz
rocklin,ca
If metal isn't perfectly spotless with a tight fit up TIG is really hard to work with. It keeps getting bubbles in it . MIG is way better for this.
I have a finger control for my TIG that I don't use, it's really hard for me to control it that way, pedal is much easier.
T
toplessHO
central florida
I may still do that in some areas,but will use body solder(lead).
Firebrick43
West central Indiana
No way I would use my tig for rust hole repair, no matter how clean you think it is, it isn't clean enough. And i have have a thumb control if I need it. Scratch start makes it worse.
Copper block behind with Mig if you are stuck on welding.
If the holes are small a moisture cured urethane like Chassis saver, POR15, rust bullet, or sherwin williams corothane applied and then while wet put 1.5 oz chop strand mat then apply another layer of POR15.
Or coat with epoxy and a layer or two of 1.5 twill weave fiberglass. Don't use polyester resin as its hydroscopic.
T
toplessHO
central florida
been looking at a finger control,Im calling manufacturer Monday and see what they say.
Im pretty sure they offer a foot pedal so finger trigger should be same.
Heres an Eastwood video showing both MIG and TIG repair.
kmacht
Connecticut
Filling that pinholes with a welder rarely works. The rusted area is usually super thin to start and even if you get a weld to fill the hole, when you go to grind or sand the weld down the surrounding metal starts to designate. If it’s a trunk floor and nobody will see it you will be miles ahead just laying some fiberglass down over the area if you don’t want to cut and patch with metal.
MOS3522
Colorado
A lot of good advice in this thread.
In the hands of a good welder, may be possible.
But for us average mortals, bondo - or cut out and replace the whole damaged and weld in a new piece of sheet metal.
dffay
Silicon Bronze rod if TIG or SiB spool if MIG will manage your lower heat due to thin sheet metal concern. Pure Argon and DCEP.
rlitman
Long Island
Im pretty sure they offer a foot pedal so finger trigger should be same...
Not all fingertip controls are created equal. I had a Miller side wheel that was an absolute piece of garbage. The only two on the market that I feel are worth a damn are the SSC Touch 4, and the TIG Button.
lilredex
Toronto
This one, think it was discontinued.......remember looking for that stuff about fifteen years ago.
T
toplessHO
central florida
yep.
Harris has gone thru alot of restructuring.
No idea why it was discontinued
Im going on an easter egg hunt to see if I can find a dusty spool .
BigMike782
My .02?
.023 S6, surgically clean, a copper spoon will give the best results.
If you have never TIG’d before(amperage control be damned) you may want to lay your grapes on the workbench and give them a good hard smack with a hammer, it will be less painful.
welder4956
Birmingham, AL USA
TIG would not be my first choice for this work. "Pinholes" in metal due to rust are never just a small hole straight thru the metal. If it looks like a pinhole on the inside of the car, the area on the bottom side will be a larger rust pit and thinned. MIG with 0.023 wire, low amps and quick bursts will do a better job.
T
toplessHO
central florida
lots of good results posted on the JW Harris "twenty gauge" wire in .030.
Any idea where to find any of this?
Ive called Harris and no luck
scooby074
Nova Scotia
Problem is pinhole rusted thru areas are usually surrounded by quarter-sized paper thin metal. When you weld it, it blows through the paper thin area!. Really need to cut and patch with full thickness metal larger than the thin area
T
toplessHO
central florida
Sounds like it may have been discontinued. You might try calling Harris back with the part numbers in the pic below.
Thanks for finding the factory specs
When I talked to Harris/Lincoln,I did provide part #s.
I asked"If this product was so revered and respected,why was it discontinued?
Was it because of the merger?" Rep said it basically was because Lincoln already had a product,
which he gave me part# E70C-6,which is a powdered metal filler,but geared towards industrial apps
with smallest being .045. So short answer is they discontinued without a replacement
545_days
Texas
I cleaned a rusty part with Evaporust and it damn near evaporated. 😂
Edit: This is not a dig at Evaporust, which is a great product. The part was mostly rust with only a spider web of steel left holding it together.
