Workbench needed
Tinkerer2
Central Florida
Needing a 24 X 30 inch workbench 36 inches high. Looking at building something like the image below. However, it needs to be 36" tall without wheels. The bench legs should sit on the ground with some way to put wheels down in order to move it. I know they make Retractable Casters but these will stick out too far and I need the footprint smaller. Table must be steady when complete. Any ideas as to how I can achieve this?
Shiftless
East Bay SFO
How steady do you need it to be? I see locking castors on the one in your picture. I built one of my workbenches with locking castors and it is certainly steady enough to use with the castors locked.
nadogail
Coronado, CA
I have a bench mounted on a Harbor Freight mobile tool base.
When I step on the pedal one end rises and it can be rolled around.
DGersic
DeKalb, IL
They make other types of retractable casters.
Or incorporate some kind of lift pad, with a floor jack, to allow a cart of some sort to be rolled under it.
If you don’t mind the need to store externally, something like the pinskates design could be adapted to lift and move your table.
T
Tinkerer2
Central Florida
Thanks. I saw the Holkie ones. I'm too old to get down on my knees and move the levers. I also looked at a video of them installed and the pads are "springy" - not solid/sturdy. The pin skate won't work with the area I have around the bench.
bigredcornhead
I used these recently on my benches purchased off amazon, they use a cam locked wheel for rolling, and when not needed unlock and fold out of the way:
full
T
Tinkerer2
Central Florida
What is the distance from the table leg to the end of the orange lifting handle? And how tall is it from the top of the mounting bracket to the bottom of the table leg?
zak77
Monson, MA
Norm built this table with adjustable wheels several years ago on The New Yankee Workshop. He worked up his plans after visiting a nearby scenic shop.
I built a table using this idea and it works pretty good. The only downside is that the table has to be empty, or almost empty, to lower the wheels since you're picking the table up.
T
Tinkerer2
Central Florida
The wheel isn't on the ground. It's just touching. When you raise your bench the mechanism lowers the wheel and locks it below the bench foot. Raise it again and it releases it so it doesn't have the bench pressure on it. Check the video here: (scroll down on page))
How they work
