The VISES of Garage Journal
larry4406
Northern Virginia
Picked up this beauty today at a yard sale. It’s damn near mint condition but it’s missing the jaws and pin 🤬🤬 I searched around for them but no luck! Here it is a Prentiss 2-1/2 swivel jaw stationary. I paid $75 for it, now to get to work on some jaws and pin. Luckily I have a Bridgeport and lathe at work to whip some up.
I bet @KMScott has designs that will work for you.
Patrickm82
Massachusetts
I think I found a set of jaws for my new 2-1/2. Found this broken 52 that I offered $30 for and she accepted. I think I’ll be getting it this afternoon. It would be $30 in material to make a new set so I figured why not. Hopefully it works out.
Edit:
Maybe not I just double checked and the 52 has 4-1/4” jaws damn!!
KMScott
Patrick, Prentiss was pretty good about having the same channel width and depth. The center to center on the screws are standard 3”. The width can be fixed with a carbide endmill on your mill. Those jaws should work for you. I made my 4” sets a 1/8 over size to cover the wider jaw towers back when I was selling jaws.
Patrickm82
Massachusetts
You are just the guy I was hoping would respond!! 😉 thank you it is just a little bit of a ride that I didn’t want to make for no reason. I’m going to get it then. Thanks again Mr. Scott.
chargedmr2
WA
So, I picked up a Snap-On tool box yesterday and it came with this vise. Anyone know much about when these were made? The box and tools were from 1987 (ish), so I figured this vise probably dates to the same time. I did figure out that it's a Columbian D45 rebadged for MAC Tools. But I'm wondering how long they were made?
Patrickm82
Massachusetts
Edit:
And I just sold the donor vise for $20 and got the jaws I wanted. All in all a good day
bsoup
Happy Memorial Day everyone. I'm working on repairing a Rock Island 541B, and I am missing one of the three pipe jaws. I'm curious if anyone knows of someone out there making replacements of these, or if you think a local machine shop would be able to do something like this... I'll attach some photos. Thanks.
ldg397
College Station, TX
Just acquired a new to me Reed 105R. The slide has been beat on quite a bit to where it cupped the metal some up close to the jaw. I cleaned it up removed the paint and see no evidence of any cracks anywhere on the jaw or slide. I guess the cupped metal doesn’t hurt anything since it slides in and out fine and has no cracks??? The split nut has an extra split in it. It is in three pieces don’t know if it was already broken or I broke it getting it out?? My question is does it really matter it is a clean break and still threads in tight?? Guess I could try welding it back together? Opinions??
I think you are good to go. two piece/three piece; should not matter.
Here is a pick up from last weekend's GS adventures. This was a Tool & Die maker's joy to own. He was quite proud of it, bought it second hand. Me, being a sucker for home made tools, decided I needed to add it to my arsenal. ETA: Oops, maybe not home made, looks like a Uni-Mat tool, see below . Jaws are 1-3.8" wide, and open to 1-1/8". Total weight is 294 g or 10.4 oz. Uses a 3/16" Allen key for the handle. I like the fact that it's set up to latch into a T track of some nature'
PXL_20260525_205125375-X2.jpgPXL_20260525_205145469-X2.jpgPXL_20260525_205130581-X2.jpg
KMScott
Rock Island 541B after cleaning and paint. I drew inspiration from another 541 on the forum.
I restored one like yours. I know someone that might be able to make your pipe jaws. Send a pm and I’ll share the jaw builder.
hudstr
Here is a pick up from last weekend's GS adventures. This was a Tool & Die maker's joy to own. He was quite proud of it, bought it second hand. Me, being a sucker for home made tools, decided I needed to add it to my arsenal. Jaws are 1-3.8" wide, and open to 1-1/8". Total weight is 294 g or 10.4 oz. Uses a 3/16" Allen key for the handle. I like the fact that it's set up to latch into a T track of some nature'
This is a unimat vise for the unimat DB and SL models lathe/milling machine. The T-nuts fit into the T-slot of the carriage or milling table accessory. I don't think the were included in the base machine package, I think they were an accessory you had to buy. They sell for ~$90 on ebay.
MongoTA
CT
Picked up two of these Turtlebacks this week. When rotating the handle on one of them there was a little binding, like the screw was tweaked just a bit. Took it apart and sure enough, sighting down the length there's a bit of a bend in the screw.
Use an arbor press to very carefully o_O take the bend out using blocks of wood to protect the threads.
I put the screw back in and it spins like a champ which was a relief. I'll take it apart again, this time for a thorough cleaning, then put it back into service.
Mr. Wonderful
I finally started work on my Craftsman 05198. I noticed something wedged into the drive nut. It was a very crude piece of metal in the adjustment area of the drive nut. Let me tell you I haven't taken this much care in doing anything in a long time. Any guesses as to what in the world it was for?????
PghJKB
Industrial Heartland
Parker? No markings. Looks like it might be missing big wingnut for under bench mount.
Lugz
I agree. Based on the patent below it is a Parker or a licensee.
Look closely, there is s collar - a bit thin, but a collar.
It is missing it's wrench-like "clamp screw" (Isn't it cool just to make up a name for something)
JKB
I assume that pivoted or was anchored on the screw shown? (Oops, @Outlawmws just answered this: Is this To tighten up the backlash perchance? ) So it would seem to be to limit it. Did any of the ears on that piece engage in the threads of the screw? If not, I'd agree that its a user added scrap to stop overtightening. If it did engage in the screw, lots of wild impractical ideas come to mind, based on it pivotingin
I did come home with a vise. Ca. 1914 Bonney "Champion" No. 112 (1-1/2" jaws). :)
