New MaxJax Install Using Anchor Bolt Locations from Older Install?
Mike S.
Charlotte, NC
So the the guy that I bought my house from had a MaxJax installed in the garage. I wanted to buy a new MaxJax M7K kit and wanted to know what your thoughts are on installing a new kit using the old anchor bolt locations. I would prefer to do this rather drilling new holes into the concrete.
The previous owner probably bought his MaxJax kit sometime between 2016 and 2018. The baseplate of the MaxJax changed at some point, but I'm having a hard time finding a dimensional drawing for the baseplate of the older models.
Here's the dimensions for the current M7K model.
This is what I've measured in my garage using a caliper.
I spoke with a sales rep at BendPak. They said the the base plates can shrink a bit when they're welded at the factory, but I'm getting measurements that are 5 or 6 mm off from their drawings.
The MaxJax is on sale until the 29th. Now would be the time to buy it, if I can convince myself to pull the trigger.
AC-WC
NE, Indiana
You can always enlarge the holes on the columns to match the holes in the floor. At 5-6mm that's easily fixed with the washer from the kit.
lolaetype
North Western Arkansas
It might be useful to make a template out of something like heavy cardboard (not corrugated) or Masonite, based on the M7K baseplate drawing. Use that to check the fit with the existing holes.
Mike S.
Charlotte, NC
Thanks, I could probably do that. Do you have a MaxJax or is that a full size lift?
I'll try to put a template together tomorrow. It's probably a good idea to see what I would be working with.
Tonight I tried to put an outline of my smallest car on the garage floor and marked the lift points. The previous owner was a Mopar guy and was always wrenching on Challenger's and Charger's. The posts are a little far apart for my cars, but I think it will work.
The arms at full extension (40") will reach the lift points with an inch or two to spare.
mm08822
If the present lift locations are too far apart for your current vehicles, can you move one or both posts in one set of holes? So you would re-use 2 of the existing holes and drill 3 new for 1 or both plates. (Check for doors ability to open.)
AC-WC
NE, Indiana
I have a Triumph C7000, it's portable just like the MaxJack. Same concept just lifts higher and lower priced.
Here's what I used to enlarge the holes.
Would definitely make a template. I tried painting the holes using the columns for the layout and it was horrible and why I had to enlarge 1 or 2 holes for alignment. The base plates were warped due to the welding.
Mike S.
Charlotte, NC
I think that's what I'm going to do. It'll move the post in a little over 5 inches. (y)
I made the template last night, which showed me how screwed up the post is against the wall. I'll move the this post inwards and drill 3 new holes. Unfortunately, the hole that deviates the most from the template will be reused, so I'll have to open up the hole in the base plate to accommodate.
This is the post in the middle of the garage, which looks pretty good.
This is the post against the wall.
The hole in the lower left is 6.5 mm (1/4") off.
I'm going to pull the trigger today. Having a low rise lift will hold me over while I save up to build my dream garage.
Thanks for your help everyone.:beer:
Mike S.
Charlotte, NC
To follow up, I did receive the lift a couple of weeks ago. I haven't been able to work on it as much as I would like due to vacation and some other prior commitments. One of the first things I did was check to see if the lift was going to line up with the anchors in the floor.
It was a bit of a relief to see that the alignment was close enough that it might work, and the arms were going reach the lift points on my smallest car. I removed the bolts from the new box of anchors to test fitment and realized that the bolt threads didn't match the anchors that are already in the concrete. The bolts that shipped with the MaxJax are M16x2.0 while the anchors in my garage floor were 5/8"-11. I purchased some grade 8 bolts, instead of the grade 5 which is what shipped with the MaxJax, and now I'm wondering if I made a mistake? Google AI seems to think that grade 5 or 8 is appropriate for anchoring a lift.
I'm at the point now where I just need to screw in the two hoses that connect the pump to each of the posts. Last night I had a terrible time threading the hoses into the flow divider. It's very difficult getting the hose fittings lined up with the threads in the flow divider, and then having to twist the entire hose to thread it in. I can get the hose to thread in ~1 turn and then it gets tight. I tried using the trick of turning the threads backwards until I can feel the threads fall into alignment, but I haven't had any luck with that either. The hose is too awkward and stiff to smoothly turn it and feel for the "click" when the threads are aligned.
Does anyone have advice on what I should try next? Is there a different type of hose and/or fitting that would make this easier? I'm thinking about going to one of those hose shops and seeing if they can make me something that would make the process easier. I don't know what that would be. Maybe a hose that is less stiff, or Is there such a thing as a swivel fitting for hydraulic hoses?
I'd appreciate any advice that you might have.
Mike S.
Charlotte, NC
Well, I think I got it all put together last night. I called Bendpak and spoke with the rep. The hoses thread in tightly from the start, so I was just being overly cautious. The rep said if the connection leaks when I start up the pump, I can get new hoses and/or a new flow divider under warranty.
I'm giving the thread sealant 24 hours to cure. Tonight I'll get to add the hydraulic fluid and test it out.
