You can use so much JB Weld! I cannot find a manufacture name on this handle. Installed about 20 years ago and I don't remember the depth. Can I turn the water source off, remove the head, cap the pipe and braze the crack? Otherwise, it will cost me a untold bucks to get a mini X to dig it up.
I am thinking the clap trap on the discharge end prevented it from draining and led to the freeze cracking.Doesn't it unscrew from right here:
Looks like a standard Yard Hydrant... or maybe similar internally to the U150 freezeless model and could be rebuilt on top without bothering what's below.
Curious what's attached to the discharge though. Wondering if that could have caused your troubles in the first place.![]()
Attention span is getting shorter and shorter these days...????????
Loading…
www.woodfordmfg.com
Loading…
www.woodfordmfg.com
Post 2 and the OP has not responded since yet has logged in after his posting.....Attention span is getting shorter and shorter these days...
In OP's defense, that WOODFORD signage was not accompanied by any sound or flashing notification!!
Thank you for the follow up.Post 2 and the OP has not responded since yet has logged in after his posting.....
I sent the same photos to Woodford and got a response back yesterday morning from Eagle Mountain in Colorado Springs. The replacement head was part #RK-W34-HA and was $150. Should have it installed over the weekend. No need to bring in a backhoe or do any shovel work. I remember at the time that I installed this, I passed on a Chinese copy on Amazon and bought the Woodford at a farm supply store. Glad I spent the extra bucks on an American made product.
You also mention something that I think we've forgotten about over the years. Woodford still has parts and the products can be fixed with parts. In the big picture those things are important.
I messed up years ago when putting in a frost free spigot. I picked up a sorta spendy ****** at one of those big box stores. The air relief valve started failing pretty early on. I went back to the big box store for a repair kit and guess how that went. One of the helpful staffers even mentioned that people usually don't repair the faucets, they just replace them.
I ended up going to my local plumbing supply shop to pick up a good assembly that still has parts readily available. Ironically, the faucet has been fine for years.
Garden hose thread screw on version is universal.Aren't vacuum breakers universal?
