IndyGarage
Indy
I suppose this is a list of tools that change the game. I've got a few of those:
1. Jawhorse - I don't know if they still make them (I looked, they do!), and I don't think they ever got as popular as they should have, but I love this thing. You can clamp and hold such a wide variety of stuff, plus I have bench tools mounted on boards and put them in the Jawhorse and they work like they are bench mounted.
2. Makita XWT07Z - First impact that could literally take any lugnut right off without hesitation. I carry one in my truck and I've changed people's tires at the side of the road countless times.
3. Knipex Cobras - These were so much better than any other slip joint pliers. Today there are knock offs that are nearly as good, but the you cannot go wrong with the originals.
4. Fiskars utility knife and blades - I like a lot of Fiskars tools, but the utility knives are great, and the blades are worth buying if you use any other utility knife.
5. Nissan Electric Forklift - This thing has done so much for me over the years. If it breaks, I'm finding another one tomorrow. No decent sized shop should be without a forklift.
6. Vermette 5-12 lift - Another lifting device - this is a rolling forklift type device that can lift 500 lbs up to 12 feet. It weighs probably 150 lbs, so somewhat portable. I use it to lift stuff into and out of a truck when a forklift isn't available. I can put it in the back of the truck and take it with me to load something and unload it. The other day I unloaded an 11 foot 800 lb stainless kitchen and cooler unit out of a box truck with it. Of course a real forklift is better, but for those times and places where one isn't available, this thing is great.
7. XSTO stair climbing dolly - This is a new device I've only seen in the last couple years. It's a hand truck with a motor and rotating arm that will pull heavy stuff up or down stairs without effort. I recently bought a condo that is three stories tall. The main living area is on the 2nd floor. Everything had to go up the stairs. I manhandled a washer and dryer up to the 2nd floor with a conventional appliance dolly, but it wore me out for a week. I decided there was no way I was getting everything up without help, so I sprung for one of these. Game changer. I moved a full size stainless Kitchen Aid refrigerator upstairs with this thing - solo. I've moved literally tons of furniture and boxes with it - and it's still on the original battery charge. it's kind of a one trick pony, but if you need it, you need it.
warhammer2020
I have collected a “few” ammo cans over my 22 yrs as an Army mechanic…. But I custom made some .50 cans for my Jeep JLU. One on each side!! I painted them matte gunmetal gray to go with theme
Steve.S
Cincinnati, Ohio
My Benchmade Griptillian knife is my EDC and I use it every day. In the garage, I can't live without my Dewalt 1/4" impact. It gets used 4-5 times per week and I have no idea how I ever lived without it!
atch
Columbia, Missouri
From Ryan's original post:
3. Vintage Craftsman Drill Press.
Tools from the 1940s make me genuinely happy in a way that is difficult to explain to a normal person. The build quality, the look, the sheer density of the things. But the 103.231.40 earns its place on this list for a simpler reason: it works, and it never stops working. I have no reason to ever own another drill press. This one will outlive me.
My comment:
I have two of these. One is exclusively for metal use and the other is exclusively for wood use. One I've had for over 50 years and the other I've had for about 30 years. I don't know what I would do without them. Whatever drill press you have I highly recommend duplicates for metal and wood use. I also have two band saws for the same reason.
okay.
If we are working within the context of "game changer" stuff:
#1 would have to be the model 104 Posi-Lock puller. Initially, the $120 price tag seemed obscene, until I brought it home and put it to use.
Takes that drive hub off first time, every time.
#2 - would have to be the Vessel "Ball Grip" Phillips screwdrivers. No more cam-out ********. Grabs 'em and takes 'em out. Every time.
IndyGarage
Indy
What I appreciate about the older machines is the weight and thick castings of the iron and the generous use of the steel used in the design of the older machines. They were simple in their design, but built to last.
The newer machines look to save weight so metal parts seem to be of lower quality steel and are lighter by design and of course more use of plastics in their design. You do not get the same sense they are built to last like the older machines.
A link back to the drill press thread. That is an unbelievable restoration. I've been looking for one like that for awhile to replace a Jet, that works fine, but doesn't offer anything more than utility. I recently picked up a Rockwell drill press from probably the same era as Ryan's Craftsman. If anything it's heavier than that craftsman - The Rockwell probably weighs 400-500lbs.
It's been sitting in a shop for probably 40 years and has never had a lot of love, but it switched on instantly. I also bought a Rockwell belt/disc sander from the same shop, also built like a tank. I probably won't take the time to restore them to that level, but I will make sure they live through my time with them and on to their next owner.
okay.
You got me... I ordered a couple of those ball grips as soon as I read your description.
^ For the price of admission on the Vessels (about $12 bucks a pop) you're going to be surprised.
The P2 x 150mm is my "go to".
ON THAT NOTE: if you order from BowersTool.com - take advantage of his "free tools" deals. Not sure what the deal on Vessel is at the moment through Harry Epstein, but check their prices as well. All my Vessel has been purchased through Bowers.
dr_clyde
Holland, MI
Game changers for me -
Inverter tig welders. I have made so much damn money by being able to put a tig rig in my pickup and go weld wherever it needs it. I can stick weld and tig weld anywhere i can walk to that has a 20 amp 120v circuit. Being able to make welds inside the deep bowels of a customer's facility with just an extension cord instead of a huge engine drive machine and massive amounts of leads is a BIG deal. Up on scissor lifts, inside tanks, finished office buildings, finished homes, out on the beach, inside clean rooms, all these and more I have TIG welded because I was able to bring the welder to the work.
My Acorn platen fixture table has forever spoiled me for other tables. It's dead flat, rock solid and big enough to handle most any project I can deal with on a table. I don't see myself ever buying a different style table if I have a say in the matter.
It would be hard for me to work in a shop without a bridge crane ever again. It's just so much faster and safer to move things with the crane even with the forklift available. I can place machines, move heavy stock, handle big weldments or even just assist in simple repair jobs by lifting them to where you can see the work. I freakin' love my crane.
The Marvel tilt-frame bandsaw. The undisputed king of manual saws. The ability to clamp parts directly to the saw table and bypass the vise allows you to cut finished weldments apart, or cut weird things that need a fixture to hold like spheres or cones is an absolute game changer in the custom fab world.
Despite my professed love for the Marvel, a CNC tube laser is really the best tool to come along in decades for the fabricator. It allows you to cut round tube, square/rectangle tube, channel, beams, angle or basically any structural shape to your CAD model. It will bevel, cut tapers and miters, holes and tabs, whatever. And it will do it the same, every single time. The nicer ones will even tap the threads for you or flow drill the tube to give you material to tap on a thin wall. I design every tube/structural weldment to use the tube laser if I can.
One of the best tools you can possibly use is 3D parametric CAD software. I use Solidworks, but there are lots of available options that fit different budgets. I draw EVERYTHING now before I even turn on the lights in the shop. It saves so much time and money by having the plan figured out before I turn on any tools that I very rarely try to freestyle anymore. Solidworks lets me build virtually, solving problems I didn't foresee in the model before I commit to metal. I design sheet metal, machined components, structural weldments, heck it even has pre-sets for lumber so you can design structures and woodworking projects. You should learn some CAD if you want stay relevant in the world we live in for making stuff.
cgrutt
Surprised the CT36 made top of the list I have one too and think its awesome but pretty sure that wouldn't be the first thing I'd grab if garage was burning down. Curious if you have added the 495802 handle and/or 452900/452902 stainless extension handles? Makes a good vac that much better IMHO.
CDKennedy
central Ohio
Well spoken, Ryan. Without getting specific as to a list of my "got to have and keep?" - @ 70, I look at my tools that I have done much with in a variety of categories. How many will/or do I wish to ever use again? Spud bars, post hole diggers and wet tile saws (and their accouterments to set), come to mind. Inherited tools (used at times) from Dad and Grandpa's farm are a few. I will say that when I chose to build a house and researched cordless tools that I have no regret to going with a Bosche system - still giving great service 10 years later. And as a buy American Union man - if Milwaukee and dewalt rated as well then I would have gone there. WE USA make GOOD ****. but my son in law, contractor, has several Festool tools that I marvel about. I leave with " what are the memories vs the cubic feet of storage"....
I just looked through the entire thread and did not see this item:
called a "Skin Wedge" (or just "4140") - these are available from $7.99 and up. These Taiwan-made models work just fine, and I did not pay more than about $8 or $9 bucks a pop for them when I ordered them a few years ago. Buy at least two - just search "skin wedge" and pick your poison.
You can thank me later.
My Old Tools
Hamrick Lake, TX
Lot's of older shop tools, but the latest to become indispensable is the M12 stubby hex drive impact. I build wheelchair ramps 2 days a week. That thing drives screws by the hundreds. On other days, it functions as a regular impact for mechanic type work with hex inserts for 1/4, 3/8, and 1/2 inch sockets. One I could live without is the M12 Fuel Insider ratchet. I'm trying but it just seems gutless.
smokey0810
Canyon, Texas
Honestly, my Jorgensen saw horses, nice to be able to setup shop in the yard or garage and have simple takedown.
My Rigid cordless drill and impact. Both have been part of my collection since I built my old garage and started coming here.
Can’t live without my Snap On ratchets. Nice working on a project, having different things in your head and just flipping the switch to ON or OFF…
Lastly my cordless dewalt sawzall and oscillator…they have both been pure work horses since I’ve got them, and helped cutting up our hot tub and the bathroom remodel project. Dewalt cordless angle grinder is next. Didn’t know I needed and angle grinder until my FIL let be borrow his corded Makita. Now I want one badly.
Squankum
Southeast
" Festool CT36. When I bought this thing, the $799 price tag felt like a personal insult."
Now it's even higher and more of an insult!
I'm so glad I got the Bosch that's very similar. Used it for the first time the other day. Sanding in a dimly lit closet with my LED headlamp on and I'm not seeing any dust in the air in front of me!
Bosch VAC090AH has the anti-static hose and HEPA bag and panel filter and the thump-thump-thump and the tool activation. I don't feel like I'm missing out on anything. Strong shop vac, too! Currently $630ish at Amazon, I paid just under $400 three years ago.
zimman
Mark Twain National Forest
I've separated more pinch welds than I'd like to remember and my Whale Bone is the hero for that.
Then, I have to agree that safety glasses are a must. I've been to the emergency room three times for metal in my eye. Twice they used a needle and the last they used an eraser. Holy eye pain on the eraser. Yeah, three pair of glasses, all perscription and just wonderful. You can't weld if you can't see. Period.
Finding the size of bolt is really important. There are many size gauges but this set wins the game. I've seen people pass out in the parts store when I pull these out. Be "That Guy" in the store when you whip this out. LOL
Finally I've carried a holster for decades with a few things I use every day. A multi-tool, flashlight, calipers, pen and ruler.
Squankum
Southeast
I got that Thexton thread checker set years ago. Since joining GJ and having a shop, not a closet, I have bought more thread checky tools, but I still use those Thextons a lot!
And I bought a set for the counter guys at my local little funny furrrin car parts store. They were amazed.
Squankum
Southeast
Did you use a flapper wheel? Got to get a flapper wheel for your angle grinder! That was my introduction to them
GJ celebrity Jack Olsen got tired of changing discs on his grinder and just wound up with a rack of four or five angle grinders. (He likes to weld up stuff.)
I'm happy with my basic consumer grade B&D corded for the time being.
Squankum
Southeast
2.My knipex 10inch Alligator pliers , they do so much too from tightening water fittings to pulling out nails from old hard 1950s 2X4s , they are really good at that and easy to use doing that. Just grip , get some leverage and they pull them right out with minimal effort , easier than using a claw hammer or actual nail pullers.
Just a reminder that Knipex makes nail pullers, too! As Knipex goes, they're fairly priced. Many size options.
Yes. The cheapie angle grinder was purchased from HF to perform ONE task, using a small cut-off wheel.
Later I went back up to HF and asked them about "sanding disks" that I might be able to use with the same angle grinder.
Older guy (older than me even!) behind me said "flap wheel".
I had no clue what he was talking about, so he and I walked back to the wall where they were displayed.
"If you want to remove paint and rust, this is what you want."
Game changer.
Used to spend hours cleaning mower decks.
Flap wheel = 20 minutes tops.
Squankum
Southeast
Game changer.
Now if you're going to put a wire brush in there, you need the kind with the twisted/knotted groupings of wires! Otherwise they fly out too easily. I was surprised at how much I didn't feel it when they stabbed me a most delicate place. Also, HF has leather aprons in the welding department for like, $12.
^ I have three or four of those in the box with the angle grinder - the twisted wire models. Great for cleaning old rusy lawnmower decks.
Wore out a straight-wire one the other day cleaning up the table for the grinder.
Used to use a 1/4" drill with a cup brush. GAH! Took hours! Angle grinder with flap wheel = minutes.
Definitely required the acquisition of a respirator, however. (y)
I just had a moment where I was considering starting a new thread (something I am reticent about doing.)
I was thinking of thread title of:
"If there is ONE thing that you learned about on GarageJournal that made your life better, what was it?"
just ONE thing:
I sold all kinds of brands of "penetrating oil". I always thought the "K & W Knock-er-Loose" was the best stuff in the galaxy.
When I worked as an independent sales agent, K & W was one of the lines I sold. Spendy, but it worked.
I've used "PB Blaster" - not impressed at all.
This stuff blows the others out of the water.
You will wince when you see the price. Use sparingly. Only takes a couple drops.
JohnX14
Boston 'burbs
  1. Makita cordless track saw - by far the biggest game changer purchase and worth every penny
I first bought a festool corded track saw. I then supplemented it with a DeWalt cordless track saw. Love it, and while the corded saw is a better saw, the convenience of the DW makes it the go to.
