YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 520
Working on a Honda McPherson Strut assembly. It has a "pinch" setup, where the strut fits into a "bore" within the knuckle. A bolt is used to tighten the knuckle to "pinch" around the strut. My question is, is it a good idea to put anti-seize in the bore or around the strut where the strut rests inside the bore of the knuckle, to prevent the two from rusting or seizing together into one piece. I'm not talking about applying anti-seize to the fastener. Could it possibly lubricate it to much and it needs to go in dry?
I'm also wondering about the upper mount that gets bolted to the frame. Clamping down one piece of metal to another. I know that the mounts are typically rubber, and petroleum based products like anti-seize, grease or oil will be bad on the rubber. What about silicone grease? Just a light coat on the upper mount that will come into contact with the frame, being shore not to get any silicone grease on the studs that to to the frame, and nuts go on top that are accessible from the engine bay.
