Show your new tool arrivals
mikegt4
sw ohio
Ok this ranks up there with the PVC glue can opener/grip I found last year. A simple cheap product I wish I had 30 years ago.
Adhesives and gasket makers will never be the same around here. It turns any tube into a mini caulk gun with no waste.
Those are made within walking distance of me, one has to fiddle with it at first but after you figure them out they work very well and seemingly extrude every tiny bit of product from the tube. They also make a gasket scraper (hand or powered versions) called the Peeler, I haven't tried one yet but it is interesting.
BlakeTheCarGuy
Roanoke Virginia
DieHard 13 piece 6 point 1/2 inch drive chrome sockets from 12-24mm no skips. Strangely they don’t sell individual 6 point sockets only 12 points in 1/2 drive so to get the 6 points I had to buy a whole set which is fine now I’ll have two sets at the house lol. I also ordered an individual Craftsman USA 22mm 6 point to complete that set from Walmart I got a few days ago that I’m making for the house. I’ll wait on the 20 and 21mm for that set till I can find reasonably priced ones on eBay or on here. I have so many 1/2 drive chrome 12 points that I wanted 6 points. Mainly just wanted an excuse to buy new tools lol. I work right next door to Advance Auto so I just walked over there and got them during lunch. The guy who must of remembered me and who delivers to our work sometimes was like dang you are getting a whole set this time usually you just buy one haha. I don’t know why it’s so hard to find 6 point half inch drive chrome sockets locally I guess most people don’t really pay attention or know the difference or don’t care because they need it in a pinch. I almost decided to get the three I needed just in 12 points but it was going to be about $10 cheaper to just buy this whole set of 6 points so that’s what I did. I might go get the SAE set tomorrow haven’t made up my mind yet. So far I’ve had really good luck with DieHard tools. I used their warranty once too and they replaced it no questions asked when the chrome started peeling so I call that good warranty.
lund
I'd be happier if the chrome hadn't peeled in the first place, but at least the warranty was easy.
I generally prefer 6-point sockets. I know there are use cases for 12-point, but I rarely encounter such jobs.
Mike
For larger sockets I am not sure 6 point generally makes good sense. You are unlikely to round the edges on larger nuts with 12 point sockets, and with large sizes, it is much easier to index the socket and wrench to get started with 12 point rather than 6 point.
In my context of experience (mostly automotive and home construction), I generally want 6 point in 1/4 drive ranges and also (outside of the largest sizes) also for 3/8 drive. But for larger end 1/2 drive sockets, I do not so see the utility of 6 point sockets since you very rarely damage them breaking them free or torquing them to spec. Where that division line is between 6 pt and 12 pt working better may be somewhat subjective, but for me, I feel it is around 15-19 mm. In larger sizes, if the nut and threads are that damaged or corrosion bonded and distorted, you are not likely going to be using a socket anyway and will be cutting it off with a angle grinder or using a torch, etc. Some larger nuts on machinery are also 12 point nuts (example, some axle nuts), and you need to use a 12 point socket anyway.
M.Jay
Southern Germany
And once again, this forum is costing me my hard earned money.
Jtels85
Glad to see a brick and mortar store offering 1/2” drive chrome 6 point. That also looks like a really nice rail compared to the cheap peg style Duralast uses.
Who makes Diehards sockets? I was curious if they’re Apex sourced and have the double detent feature on the drive end.
BlakeTheCarGuy
Roanoke Virginia
I believe it is Apex. Once I open them I’ll look at the drive end and see if they are double detent or not.
BlakeTheCarGuy
Roanoke Virginia
M635_Guy
NC
My recent day on the ground sweating in my mom's driveway while working on her car drove two acquisitions. One is still on the way, but the first one is this:
The thing puts out a very-good amount of air, and I like the ability to plug it in too. Stepless speed adjustment too.
[EDIT - for $26 list, it's a pretty awesome deal. I've added a couple Hercules things (Sander, jigsaw) where I wanted cordless but didn't want to spend Milwaukee money and so I have a Hercules 5Ah battery that will apparently last for 8+ hours with the fan at the upper speeds]
In another acquisition driven/justified by my pebbly driveway and other house-factors, I got a monster shopvac.
This thing is seriously powerful, and I really like the big wheels and handle.
mikeinri
Adjustable wrench just delivered. Matches the smaller one, minus the red handle. I have to say, the Lobster is a lot smoother adjuster than the Klein and Kobalt.
I wish those were dual-marked (metric and SAE). I do a lot of work around the house that needs SAE, but of course most of my vehicles have metric fasteners.
I use adjustable wrenches more commonly as a rough caliper to find a socket size than as an actual wrench. Having it be a wrench also has advantages over just using a caliper.
Mike
Skyman
Central Maryland
Mike
^^^This exactly ^^^
The right-angle configuration of a caliper is often unfriendly in confined areas. An adjustable with scales is handy for quick sizing of hex fasteners, especially when visibility of the fastener is limited. Dual scales is great when working on various things that might have SAE, metric, or a mixture of fasteners. Thin, sharply angled jaws fit better into tight spaces.
I just this week bought a couple of cheap-****, thin-jawed, chinese adjustables for this purpose, because I couldn't find decent quality, thin jaw, adjustables that were dual-marked (Bahco, are you listening?). These fairly **** as wrenches, but I don't intend to task them with that duty very often. The little guy will reside on my work cart. The bigger guy will only be used when the little guy's jaws won't open wide enough.
BlakeTheCarGuy
Roanoke Virginia
@BlakeTheCarGuy
Do you have to exchange the entire socket set back or can you just exchange the one socket under their Diehard warranty?
So with these since they don’t come individually I’d imagine you need to bring the whole set back most likely. Same with the 1/4 sets since they don’t sell 1/4 drive sockets individually which I find strange.
GeoBruin
Like others above, I received my Klein ratcheting driver. The Japanese made non-ratcheting driver has become one of my favorite tools, so I knew I would be picking this one up as soon as it came out.
Initial impressions are very positive. I'm confident the "sheen" on the rubber grip will wear off with time (which is a good thing!), the ratcheting mechanism has very low back drag, and the ergonomics of holding the ball in the palm of your hand and spinning the shaft is really nice.
The only drawback initially is that is it much heavier than its fixed counterpart, but that is to be expected.
captain14
That’s what I figured. Lowes is the same way about exchanging a screwdriver or a socket. Gotta bring the whole set back.
ecotec
^^^This exactly ^^^
BlakeTheCarGuy
Roanoke Virginia
Wow that *****. Even though they have individuals. There’s so many different things I’ve heard about Lowe’s I guess it varies by location. Mine won’t even do anything for Craftsman or at least the people I’ve tried to ask wouldn’t. They tell you call Craftsman.
BlakeTheCarGuy
Roanoke Virginia
Got a couple odds and ins today. Duralast 10mm deep 1/4 drive socket. My Craftsman Taiwan one is under the hood of some RAV4 out there lol. I had a Snap-on one but I don’t like to use it because the chrome started peeling off a lot more so I’m going to get it warrantied but I forgot today. A 22mm wrench to have so I don’t have to unroll my set of Snap-on that goes from 20-24 I can just grab this one and go. I actually will say I liked the fit of this one it seems a bit tighter than Snap-on to be honest. Power Torque short ball allen sockets. I have a long set of Carlyle at work already but I know a place where the 10mm one will be very useful on some Toyota stuff. Also got a Power Torque 10mm deep 1/4 drive socket too which I put in the car tool bag. I also picked up three Snap-on chrome 6 point 1/2 drive sockets a 17mm deep, 21mm deep and 30mm shallow. The guy at O’Reilly was like if any of these break just bring it back and we will replace it no questions asked. Glad to see they acknowledge the tool has a warranty. It was the O’Reilly in my work town and AutoZone I work less than a mile from both and Advance Auto is right next door so I love going to these places on my lunch break. Napa is about a 5 minute drive but they don’t have any tools hardly at all. This O’Reilly still had some of the old brand GM Performance tools there I was so tempted to get them but I sure don’t need them lol. The Snap-on are all for the house. Didn’t need the 30 it just looked cool and mine are all 12 point so had to get the 6 point lol. IMG_5067.jpeg
Nobody-named-Olli
Dual scales? All I could find were not.
The old? Snap-On branded definitely are. (Scroll down, see edit 3!)
Edit: And per Snap-On ( https://shop.snapon.com/product/Wide-Mouth-Adjustable-Cushion-Handle/8"-Wide-Mouth-Adjustable-Wrench/ADHW8A ) still are dual scale.
Edit 2: Sorry, they are obviously not “thin jaw”. …
Edit 3: But Snap-On brands the “thin jaw” version as well, and it has dual scales! https://shop.snapon.com/product/Wide-Mouth-Adjustable-Cushion-Handle/8"-Slim-Jaw-Wide-Mouth-Adjustable-Wrench-(Red)/ADHWS8
But also Made in Spain, not USA - if that is a deal breaker.
Kind regards,
Olli
