Between 705 & 1200 SQ/FT My Mini Garagemahal
CGohring
Las Vegas
@CGohring - not, IS there a play, that IS THE PLAY!! LOL
I have that a piece of the rear bumper, then center section in between the tips, so that will get cut/sectioned and used to fill in where the original tip cutouts are and the originals will be moved to the center an made to look like a GT3R or Cayman
End goal is something like this
55296844607_053027cbf5_c.jpgUntitled by fouckhest, on Flickr
Should have know that you are way ahead of me on the design.. ;)
F
fouckhest
Greer, SC
Spent most of the night welding runners, finished the last one of the passengers side this morning.
But last night when I had enough intense focus on welding, I shifted back to the rear bumper. After a bunch of measuring, I cut the spare panel section
55298065587_dafba0fe5e_c.jpgUntitled by fouckhest, on Flickr
55299381920_ba3326c76c_c.jpgUntitled by fouckhest, on Flickr
Then some quick mock up, need to start by trimming these panels a little better and decide when I will take the plunge and start cutting up the actual bumper
55299124203_7ced7708fe_c.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
Back to the shop this weekend, had two runners on the passenger that one move a little and one moved a LOT, so that needed a little more rework, but turned out just fine. Lesson learned, lots of curves move in certain ways, and long straight runs, move in other ways...
55307409393_2eb45a2a54_c.jpgUntitled by fouckhest, on Flickr
After putting the puzzle back together, all 8 primaries are now tacked to the flange in a minimum of three places and ready to be pulled off and welded.
55306344677_832b32c267_c.jpgUntitled by fouckhest, on Flickr
55307409368_f344a2be75_c.jpgUntitled by fouckhest, on Flickr
55306344702_60c9c6615d_c.jpgUntitled by fouckhest, on Flickr
Ran to the metal store Saturday morning and grabbed this length of 1/4" wall rectangle tube, should work well to bold the header flange to for weld out, will also allow for a nice little hole to be drilled in the center of the primary tube for the argon to escape while back purging
55307479929_f2ddeeb566_c.jpgUntitled by fouckhest, on Flickr
With the argon tank 98% empty, I decided to move back to the rear bumper yesterday, weather was in the mid-70s, so opened up the shop door and had a cars & crafts day. First step was to cut out the entire lower section, you can see the areas I left are where the bumper cover bolts to the car
55307415428_a8b818b88f_c.jpgUntitled by fouckhest, on Flickr
Started the mock-up with the section I cut up last week
55306346407_83ffcc1d9a_c.jpgUntitled by fouckhest, on Flickr
Lots of cutting, clamping, screwing things together, this is where I stopped yesterday to help the wifey start getting ready for dinner. I remembered I have an old exhaust rear section from the R32T that had 4" tips, dug that out this morning, going to see how the 2x 4" tips look in that opening, I feel like its too wide, but I want a better visual, I'm annoyed that I didn't think about it yesterday, but oh well, I was in the zone
55306346477_2bccb67897_c.jpgUntitled by fouckhest, on Flickr
Need to go get more argon at lunch, then back on the bumper tonight, hopefully get that close enough to take to the body shop this week, then back to the headers. I still need to shorten the collector end of the primaries to bring the transition up to clear the x-member/trans support. Then back in the car to start on the tunnel.
F
fouckhest
Greer, SC
How do you measure the header runner lengths to keep them all reasonably the same length?
Impressive!
Honestly, I'd have to go back and look through photos, but I think I was trying to simply measure an inside and outside profile and hope the average was "close enough" to keep me in a +/- 10% between them, I recall being relatively successful. In the end, this is a high enough performance engine for it to matter, mostly for sound, which is a big focus for me, the primaries all hit the collector in a clockwise direction based on firing order, both primaries will feed into a megaphone, then a z-pipe, straight back to a dual 2.5" in/out muffler
In other news, mowed the front lawn Friday at lunch before picking up the wife from the airport, grass is finally coming around, dont pay attention to the clover popping up in a few spots (I'm not showing the really bad spot), but it should start to choke it out now that its doing better
55307659490_9723f4e484_c.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
Dug out that old axle back section, cut off the 4" tip sections to do a little mock up....glad I did, just wouldn't have looked right
55308674261_d3333d81f4_c.jpg by fouckhest, on Flickr
Sometimes its better to be lucky than good, luckily, after a little bit of measuring I was able to remove the upper center piece, but `3/4" off each side, slide the outer sections in, get it centered and all is right in the world. Hoping to get the body shop to give me advise on how much more I can/should do, versus just letting them take it from here. Either way, I am stoked at the results and think its going to be a great look on the car.
55309626783_92c7cdee69_c.jpgUntitled by fouckhest, on Flickr
55308674386_1e6ae948bf_c.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
Lot of work, but not a lot to show for it. My buddy that runs/is the main guy at the local for dealer body shop stopped by yesterday on his way home, I asked him if he'd come check out my progress and tell me what to do vs. what not to do. My marching orders were to merge everything together that was "overlayed," with the original bumper. Spend about 3hrs last night and an hour this morning getting it all cut in and level, bumper is now off and in the bed of the truck ready to be dropped off today.
Side angle shot, it all lines up pretty well, this was last night, its still missing the little vertical support in the lower valance, but you can sit it in the straight on photo....unfortunately I cut the passenger side piece wrong, so it will need to be fully plastic welded in 🤦‍♂️
55312057265_0f5ae06cbf_c.jpgUntitled by fouckhest, on Flickr
Ready to be removed and dropped off
55311794148_b3ab2eaf43_c.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
No shop time last night due to meeting up with an old coworker/friend I haven't seen in a while, but got back at it this morning to start on my welding base to bolt the header flange to while welding the runners.
Started by taking the OEM manifold flange to the 2x6 tube, then using my transfer punches and the OEM exhaust manifold as a template
55312750607_7d641a77a2_c.jpgUntitled by fouckhest, on Flickr
Onto the drill press for a pilot hole, then tap drill hole next
55313662231_3d01fb2926_c.jpgUntitled by fouckhest, on Flickr
55314069020_87ea531773_c.jpgUntitled by fouckhest, on Flickr
24x later, onto the tap....I wanted to make sure the holes were dead straight so started them using the drill press chuck as a guild, twisted it by hand to get a bite into the metal, then onto the tap handle...I'm always scared to break a tap (childhood trauma after having to drill a tap out)...so Kroil was used liberally!
55313815628_c16630825d_c.jpgUntitled by fouckhest, on Flickr
55312750602_565e3c2dce_c.jpgUntitled by fouckhest, on Flickr.
Quick chase of all the holes and a test
55312750677_961d36caf7_c.jpgUntitled by fouckhest, on Flickr
Removed the passengers side header and gave it a quick test, great success! Used m6 countersink bolts at the advise/recommendation of a good friend that has a fab shop, worked great!
55312750612_9a5439682a_c.jpgUntitled by fouckhest, on Flickr
55312750547_903b0d4a18_c.jpgUntitled by fouckhest, on Flickr
I was rather impressed to get that all knocked out before 8am this morning, so hopefully find some time to get the mig tacks cleaned up and start burning them in.
F
fouckhest
Greer, SC
With yard work done and the wife having dinner with her daughter, I headed to the shop. First order of business was to drill holes for the back purge to bleed out of the runners, then got started on welding the runners to the flange. While getting ready to make a foil purge feed I looked through my welding supply box and realized I had bought this at some point, thanks past me!
55315131474_599e18eecf_c.jpgUntitled by fouckhest, on Flickr
55313997312_0fbcbab587_c.jpgUntitled by fouckhest, on Flickr
Put in a few hours last night and another hour and some change this morning, many precarious torch holding positions later I have a couple little sections left to weld and then the drivers side will be done. Its so nice welding to thick steel, makes it seem easy, now if my hands just weren't so shakey!
55314704387_693f483dfd_c.jpgUntitled by fouckhest, on Flickr
55315616166_74bd410b70_c.jpgUntitled by fouckhest, on Flickr
Hope to get this them all done and back on the engine to trim the runners back so I can finalize the collector position and get them polished up and get the springs welded on.
F
fouckhest
Greer, SC
Was out of town for work the first part of the week, got back and settled Wednesday night after a sitting on the tarmac in Chicago for close to two hours, that was fun....and we were this close! Luckily they get generous with drinks in the cheap seats after they delay you for that long LOL
55330339363_ced8d7f0dd_c.jpgUntitled by fouckhest, on Flickr
After having a relaxing evening with the wife, I got back to my regular schedule, up yesterday morning before work to get back to the headers, I knew I wanted to shorten the runners as they feed the collector so it would bring the v-band up to allow for better clearance over the gearbox x-member
Took ~1" off one and ~1/2" off the other, could marks, cut off wheel and the portaband made short work of it.
55329246207_6207dcdc5f_c.jpgUntitled by fouckhest, on Flickr
Before:
55323559981_f4c331e0e4_c.jpgUntitled by fouckhest, on Flickr
After:
55330168116_925bae7114_c.jpgUntitled by fouckhest, on Flickr
Pretty happy with the results, they ended up pretty even
55330322518_89b3baf59f_c.jpgUntitled by fouckhest, on Flickr
Had to tend to lawn care duties after work last night as first priority, front lawn is starting to come in nicely, my clover/broadleaf crud seems to be "lightening" a bit after the recommended herbicide by @Cdubu52, curious to see how it does over the next week, unfortunately seeing more spittle bugs that I'd like, so going to need to treat the lawn for those little effers next....
55330340568_a4b12c616a_c.jpgUntitled by fouckhest, on Flickr
Knowing next steps on the car were going to be getting started on the exhaust, I decided it was time to dig out all the components that I've been gathering so that I can re-install the engine and get started on that so I can start working on the tunnel and floor.
First order of business was to tack up my megaphones, not sure why I am so stoked about these things, but I am!
55330168136_ca7d531607_c.jpgUntitled by fouckhest, on Flickr
Here is what I hope will be the majority of the components for the exhaust. I've got additional hangers and pie cut pieces still in a box, and the "Blackwidow, Angry Housewife" muffler that will be a swappable section in the very rear of the car.
55330386224_624b56a338_c.jpgUntitled by fouckhest, on Flickr
Cleaned up a few things this morning before work and got the engine back in the car. I am rather impressed with this lift/spreader bar contraption, it works really well and allows the entire engine/gearbox to balance nearly perfectly.
55330168286_76ec798081_c.jpgUntitled by fouckhest, on Flickr
55330386239_57584269ab_c.jpgUntitled by fouckhest, on Flickr
Hopefully I can get some solid shop time in this weekend.
F
fouckhest
Greer, SC
Building the exhaust is always my favorite part!
Went back through the pages and couldn't find my answer, that is a 4.2L Audi right?
LoL, exhausts are fun for sure! I am certainly excited to get started and see where it goes, I am certainly chasing sound and performance, but have some cool ideas for modularity in the system.
Correct, 4.2L from a b6 s4, 340bhp from the factory, the tuning company that has been big with that platform claims that with a little work you can squeeze another 30-50hp out of them, the top end requires bigger injectors, so that will be TBD, I want linear power, not peak numbers.
F
fouckhest
Greer, SC
Hope everyone had a good weekend, was rather productive in our world.
Saturday started with an adventure, the wifey has been hem hawing about a new car for a couple years now, she finally got herself amped up enough to pull the trigger. We loaded up early and headed down to the dealer, too many hours later she arrived home in a this Sandstone 2026 VW Tiguan, SEL R-Line, 4motion. Very nice car, quite happy for her and now we both should be set on vehicles for a number of years to come!
55336613740_b94b887c9e_c.jpgUntitled by fouckhest, on Flickr
That burned up the morning and early afternoon, so we snuck over to some friends for a little pool time before doing a little cookout with the family.
Yesterday I managed to squeeze in some shop time. Got started on the exhaust for the project car, having to work through a couple things before any real progress, but even non-glamourous progress is progress.
First order was to get the pipes from the collectors remade, many small cuts later I found an angle that gets me damn near parallel with the floor plane. Spent a lot of time ensuring these are nearly identical, they will need to get trimmed back to feed the megaphones, this is just the full 180° bend leg length
55336411434_fa10eb7a25_c.jpgUntitled by fouckhest, on Flickr
55335267027_ac50017627_c.jpgUntitled by fouckhest, on Flickr
Also spent a little time playing with pie cuts for getting out of the z-pipe and around.
Left is 6x 15° pies, right is 4x 15°
55336198976_9be193d4c9_c.jpgUntitled by fouckhest, on Flickr
I think 4x is the recipe
55336613690_6b72369401_c.jpgUntitled by fouckhest, on Flickr
If all goes as planned I hope to start melting some metal tonight, or at least getting some things tacked up
F
fouckhest
Greer, SC
Back to the exhaust last night, lots of fitting and trying to line things up, thought I was good, so tacked the v-bands on they pulled a little, so had to cut three tacks loose so I could adjust, got to this point last night, had to jump on a call and decided that was a good spot to call it a night and come back in the morning with fresh eyes and mind.
55338493521_d08096e308_c.jpgUntitled by fouckhest, on Flickr
55338493496_b453ac9bdd_c.jpgUntitled by fouckhest, on Flickr
Back at it before work this morning, tacked the v-bands back on, added a couple tacks to where those tubes meet the flex joints, then started fitting the z-pipe.
I found a pie-cut turn combo that seemed to work, so loosely tacked them together, seems like this is going to work
55338646428_d736c0e213_c.jpgUntitled by fouckhest, on Flickr
55338493416_51dbf353b3_c.jpgUntitled by fouckhest, on Flickr
55338646473_57464c5803_c.jpgUntitled by fouckhest, on Flickr
55337566577_3c91ca6373_c.jpgUntitled by fouckhest, on Flickr
Side shots, will add a small notch to the x-brace for the gearbox, picked up some 3" OD 1/8" wall DOM last weekend at the metal store for this exact purpose. But for now, the megaphone laying on there serves as a good support to keep them both even.
55338910310_ba290df831_c.jpgUntitled by fouckhest, on Flickr
55338493446_221a83cf6b_c.jpgUntitled by fouckhest, on Flickr
Spend the remainder of the morning before work tacking up the pie cut bends, might try and weld those out tonight and decide if I want to tack them to the megaphones or the z-pipe....tbd.
F
fouckhest
Greer, SC
Nice work on the exhaust Mike.
I know exhaust work is Marc's, aka @OutlawDrifter , favorite type of work, but it is one of my least favorite, next to interior work.
Thanks, Mike. Exhaust used to be my favorite, but this is making me second guess that LOL.
The Z-pipe concept is wild. Watched some videos on it a while back.
Your setup is coming together quite well!
Marc, it is wild how much they can change the sound of the exhaust, I just hope whatever comes out of this system is worth all the time, effort and money!
F
fouckhest
Greer, SC
No work last night, went to a concert w/a buddy, but got a little work in Tuesday night and Wednesday morning before work, tacked up the pie cut bends, got them tacked to the megaphones and then the megaphones to the z-pipe. Standing under a car TIG welding is not easy, but its tacked on and supporting its own weight
55339565447_f716db49dd_c.jpgUntitled by fouckhest, on Flickr
55339566052_50ab607e2e_c.jpgUntitled by fouckhest, on Flickr
55339566167_96b338ccef_c.jpgUntitled by fouckhest, on Flickr
55340705729_98930a74b8_c.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
Hope everyone had a good weekend, happy fathers day to all the dads!
Relatively productive weekend in our little world, Saturday morning was filled with chores, followed by a job I've been planning for and putting off for a while.....vapor barrier in the crawl space, no before or during photos, just these from when I called it good enough. I have enough material to do the walls, but by the time I got to this point, I'd had enough, it was getting hot and well, a beverage, shower and the pool were all calling!
55350377868_8987a2e844_c.jpgUntitled by fouckhest, on Flickr
55350639005_9fea5ca9c1_c.jpgUntitled by fouckhest, on Flickr
Yesterday started in a similar way, slow start after the half day of crawling around, but then managed to sneak in a little shop time and started plotting out the tunnel for the car. With the seat, shifter and steering wheel back installed, I think I've got a plan.
I think I am going to bring the steering column back towards the seat ~2", this will help with pedal position and steering column angle, as well should bring the steering wheel and shifter in line
55350219251_d2bc703267_c.jpgUntitled by fouckhest, on Flickr
55350638870_2cea732091_c.jpgUntitled by fouckhest, on Flickr
madison069
Monroeville, PA
Since you're lining the crawlspace, any thoughts on a radon migration system? Probably not really needed, but something to add to the crawlspace if you got radon down there and now making it airtight. The Radon migration kit isn't expensive as long as you have power close to the fan location. I just put one in our basement cause the radon level was over 4pCi/L before the install, after the install it dropped down to .5-.3pCi/L which is well below acceptable level. Since my youngest wanted the bedroom in the basement I wanted to be sure it was safe for her.
F
fouckhest
Greer, SC
Radon is part of the inspection process down here, it was never flagged when I bought the house, so no plans to do anything for now. Also, it will not be air tight for now, simply doing the better vapor barrier, I MIGHT close all the vents and put a dehumidifier down there, but that is TBD at the moment, need to see how this does with the humidity for now.
cccoltsicehockey
Charlotte, NC
Exhaust is coming along great.
I have a vapor barrier in my crawlspace. I really should check the humidity more often as I am curious about potentially sealing mine and adding a dehumidifier as well. Maybe a good place for another zwave temp/humidity sensor.
smschriefer
Yorktown, VA
Crawlspace looks good. Before you add material to the exterior walls check with your pest control service. I had to leave a minimum amount of wall uncovered for them to continue my termite bond. Memory makes me think is was 8" reveal. I also added 2" rigid foam board up to that level as well. I did it to prevent as much of a thermal barrier as I could.
F
fouckhest
Greer, SC
Thanks for that, I actually did this b/c my termite bond inspection and bait trap appointment needs to be done soon, so wanted to knock this out before.
Luckily it got hot and I forgot to get liquid nails to put attach it to the block
nicholam77
Minneapolis, MN
I don't have anything to add really — this is way outside my scope — but just wanted to say this is such a cool project and I am amazed at your work!
Also congrats to the wife on the new Tiguan.
F
fouckhest
Greer, SC
haha, thanks on both! I look at your wood working projects the same way!
