fflintstone
Are any of you serious when you say you put kerosene and diesel in your crankcases?
YES! Diesel is the same as fuel oil (home heating) it does have a lubricative property. I run my Sthil chainsaw its entire life at a 50:1 mix. If you have roughly a quart of oil in the filter and throughout the engine and you add a gallon of diesel (fuel oil) you have a 4:1 ratio. If an engine cant run for one minute at a 4:1 ratio of what is essentially a really low viscosity oil, then the engine has problems already. As I said I only do that on a used vehicle I buy or when a vehicle I purchased reaches 70k or more. When I bought my wrangler w/71k on the odo, the diesel mix came out black. The cheap oil came out dark 500 miles later. On my vehicles it comes out honey colored.
I am sure that Rislone is nothing more the a diesel derivative with extra detergent additives
I would never use kerosene though. Kerosene on the other hand is too flammable and has much less lubricity to it. It does however have microscopic paraffin wax like particles in it. Old timers used to rub raw metal with it as a rust inhibiter.
Everybody has his or her theories on properties of the internal combustion engine.
I like additives with molybdenum disulfide and or Teflon. Weather they actually embed themselves in the pours of the bearing surfaces is questionable, but I like the concept.
This is the primal, basic bond between man and machine; it is the first thing your dad teaches you as a kid, a very visceral experience.
