Estimating paint usage
lund
It's zip sheathing, so a step above commodity osb.
I also went through a lot of paint
Ah, makes sense on it being a better grade to come out looking like that with only paint. I am a cheapskate so I bought regular grade 1/2" OSB used for framing (very low cost). I think I "paid" for the modest savings in terms of sweat, paint, and fumes! Probably the coarser grade absorbs even more paint. My initial primer coverage was awful.
mike93lx
Richmond, VA
A while back, I did a workbench with an osb top. I did a light coat of a dark paint, sanded it back so the paint was just highlighting low areas then I coated with a bunch of poly. It makes for a really interesting look that I quite like.
But I also have built furniture with plywood that specifically highlights the layers, so my taste may not align with most 😂
lund
I tend to like the layered cake look of laminates also. Everyone has their taste. But it looks nice to me. Laminates with high glue impregnation are also incredibly strong and stable relative to ordinary wood. Wood makes a lightweight lattice that becomes much stronger and dimensionally stable when it absorbs a lot of glue. Realistically, it is the way a lot of future construction will be done. The material has a lot of upsides relative to steel and dimensional lumber. It should last very long, is extremely versatile, and it is also immune to rot.
volaredon
IL
I haven't read the whole thing but I have had the opposite happen in my 2 latest painting projects... Both done with my air compressor and an HVLP gun. The first time I have ever used an HVLP
I'm used to binks and devilibiss siphon feed quart capacity guns. My last 2 projects have taken much less paint than expected.
The first was a bare truck frame, and you want to talk about expensive stuff. That stuff was $500 a gallon with the hardener. An industrial and marine grade high solids polyurethane.
Then my garage doors and 2 man doors. Sherwin Williams sold me 1 gallon of primer and 2 gallons plus 2 cans of hardener of a water based 2 part polyurethane.
In each case they asked how much area I was painting and in each case I only needed half of what they sold me. Although these products only come in gallons and 5 gallon containers. No quarts available. I need some of the primer for the $500 paint for a Dana 60 I want to paint and can't get that in less than a gallon either. I have plenty of the $500 stuff left to do the rear end and then some. I expected to need to use a whole lot more if it.
