Probably left on the bumper while loading up. In my world good meaning helpers do stuff equally lacking in wisdom. I have to be more aware when I have that sort of "help".I have found a lot of tools over the years, but today's find was one of the strangest I have had.
As found.
After a bit of cleaning. I found this in the gutter while walking home. Missing 2 bits. What makes the find strange to me is who would be working out of their vehicle with a router and leave the set where it could fall out? Plus, the plastic case is not damaged. And why would anyone have a router bit set out in the road even if they had been working on a project in their drive?
Might have been. I would have thought that any fall of a couple of feet or more would have damaged the hard plastic case. I found this a few blocks from home in an area I regularly drive, bicycle, or walk through (several times a week). I have never observed any home woodworking shops in this area or any recent home renovations. On another note, after cleaning up, I started looking closer and discovered the set is complete and no signs of wear on any of the contents.Probably left on the bumper while loading up. In my world good meaning helpers do stuff equally lacking in wisdom. I have to be more aware when I have that sort of "help".
About a mile from a Harbor Freight and multiple speed humps that have to be bounced over.How far was the find location from the closest HF? Maybe he just left that on top of the vehicle when coming out of the store, and it eventually fell off?
Mike
2 bits missing....How far was the find location from the closest HF? Maybe he just left that on top of the vehicle when coming out of the store, and it eventually fell off?
Mike
I found one of those years ago. Still use it in the driveway.
Tire chock?
YesTire chock?
Claymore?
THIS SIDE TOWARDS ENEMYClaymore?
Turn it vertical. It will be one of the smoothest drill presses you have ever used for woodworking.
Oh, I bet they've been found... in the middle of someone's Michelin.2 bits missing....
My dad found a punch that way some years ago. It actually blew back out of the tire and jammed itself halfway through the mudflap.Oh, I bet they've been found... in the middle of someone's Michelin.
That looks just like what I found the other day!Found along the road while mowing.
Was it holding the sign up? If so, did you do your civic duty and replace it with an import, or replace the missing nut?
Please do, it will help us all sleep at night!I was gonna replace it with a china made vice plier, but didn’t have one on me. Maybe I’ll go back.
I suspect someone was in the process of stealing the sign, and decided to bail.Was it holding the sign up? If so, did you do your civic duty and replace it with an import, or replace the missing nut?
