High torque electric impact that won't break the bank?
Bennylava
Cleburne, TX
I searched and found this in another thread, someone said it worked great:
Straight outta china of course. But it's $90 not $280 like the known good brands. I need one for stubborn lug nuts. So I wanted to ask if anyone else has any experience with it. If not, is there another one that passes the Honda crank bolt test? For something like $150 shipped.
Gozo
Central VA
I’ve got the corded one from Harbor Freight. Had it about 4 years or so. Use it on those tough ones where I can’t get a breaker bar in there. Hasn’t let me down yet. Make sure you use an impact rated socket; ask me how I know. 🙄
Etchase
Hawaii
Seesii makes good stuff in my limited experience, which doesn’t include the one you are looking at. YouTube channel torque test likes their impacts. I have two glass suction cup lifters, two mini chainsaws, and a floating pump. All operate on Makita batteries as well as their own.
Bennylava
Cleburne, TX
Yeah I was thinking maybe they're Makita rebrands. But who knows. I'll only be using a few times per year to rotate tires.
Tchicken
THE Motor City
For a couple times a year and on mounted tires a breaker bar makes more sense. Particularly if the lug nuts in question weren't run down excessively by some other fool with a power toy.
ecotec
Even an impact rated socket might not work on a Honda crank bolt.
The OP should buy the Lisle weighted crank bolt socket.
ecotec
Could you please elaborate?
Sure. Like I said. There are times a 1/2” battery or air impact with an impact socket will not get a Honda crank bolt off.
More power (3/4” impact) or more mass (1/2” impact with weighted socket) is what works.
A weighted socket has a lot more mass than a regular impact socket of the same size.
Lassen Forge
Question is if you already have a battery platform or not.
I started with the "evil Yellow" 18/20 volt system years ago - they just happened to have a HD 1/2" impact that will remove truck lug nuts. Cost a but more, but since I was already "invested" in their battery platform, it made sense. And I used (and use) it for everything from engine work to scaffolding clamps.
If not, then why not?
Bennylava
Cleburne, TX
Every seesii tool I have has performed well, punching well above their cost.
That's what I'm looking for. It's not always possible, but sometimes you can find an inexpensive tool that does a fine job.
I don't like buying chinese, but in these hard times it beats paying $280 for name brand to do the same thing.
rust in the eye
Chicagoland
Hard times, indeed.
A tool packing "explosive power", two 4ah batteries, charger, case and half a dozen tools for $120. I suspect you'll be sorry but would be pleased to be proven wrong.
Let us know if this thing has any guts(Honda crank bolt you say?), run & recharge time and ultimately how long these batteries last.
I might have slightly more confidence in these Chinesium bits if they would cough up a few Yuan for a native English speaker to proof read their advertising.
Beerhippie
Far NE Oregon
I bought a Milwaukee 1/2 mid-torque just for rotating/changing tires. I figured I'd use it a few times a year. I use it at least once a week.
Stubborn fasteners? "RESISTANCE IS FUTILE!!"
Bulldog13
Cape Coral ,FL
I’m sure I’ll get flamed over this but…..I have 2 Ryobi impact guns…18v battery…zero issues removing anything from my Harley compensator to my truck lug nuts. I personally think for the average homeowner you can’t go wrong with their line of tools for the cost .
powertrip
Columbus Ohio
I use the mid torque and high torque HP Ryobi impacts. They are basically last years tech Milwaukee in a green wrapper. Shop Tool reviews tore a couple down and pretty much determined that. I could afford Milwaukee but when I can get these at under $100 bare tool each a couple of years ago, I jumped on it. No complaints at all. Just use the better silver batteries. Those work better in impacts.
Bennylava
Cleburne, TX
My ryobi won't take the lug nuts off the wife's toyota, but I don't think it's the "high torque" model. Also the last time it was done, it was some oil change place that also rotates tires. So they're probably super torqued to 500 ft lbs or something
cgrutt
I have an older Milwaukee hi torque that wasn't able to take the rear lug nuts off my wife's Mercedes the other day. Last place that had it was the Mercedes dealer I don't know what they used but those lug nuts were on tight. Had to use my 3/4 ICON breaker bar with wheels on the ground and even that was a struggle. Up until now the Milwaukee has handled everything I've used it for was really surprised it didn't even budge them. Sad thing is the torque spec is only about 100 ft lbs (130 Nm) and this was done at a Mercedes dealer...
Bennylava
Cleburne, TX
Seems to work fine, for now at least. Zipped off the over torqued bolts on my camry hybrid work car. Fortunately you're only supposed to put them on with 77 ft lbs so I don't have to buy a bigger torque wrench. Torque tests on youtube say this SeeSii makes 380 ft lbs reverse (taking stuff off), and 320 putting stuff on.
Apparently they've been in business since 2015. Not sure if that helps in any way. But you know how the chinese like to just create a new company name every few months, so maybe it means something.
It accepts makita batteries so I guess I'll be looking for Makita brand tools. If needed in the future.
u2slow
BC
i got this one when it was only $50
So far so good. More jam than 1/4" driver gun and of course bigger/heavier. Can't complain for the price.
Edit: i dont use it to free super-stubborn things. Regularly serviced lugnuts are fine. Its a convenience tool. I have a hefty air gun and breaker bars for extra tough jobs.
AEAdam
SE PA
That’s a mid torque gun today and probably wouldn't work for a crank bolt. High torque guns today are putting out well over 1000ftlbs. That puts outs out 1000nm which is not the same.
Couple things you can do:
1) Sounds like you aren’t actually removing a Honda crank pulley. For tires a mid torque gun is fine. You might find a bare CPO Milwaukee gun for that money. Then you just need a few batteries which you could use on other tools, including lawn care products.
2) Stuck lug nuts happen because your hubs are corroded. Remove the wheels of your cars and carefully clean the surface of your wheel hub, then apply a thin film of anti-seize compound. Use 3 in 1 oil on the wheel stud threads. I would scrub it in there with a tooth brush. You could soak the lug nuts in penetrating oil. Then optionally TINY bit of anti seize on the threads and at the bottom of the nut where it contacts the wheel and you’ll never need an impact again. Only down side is if you are too liberal with the antisieze on the threads, a careless shop could over load your lugs. I recheck my lugs after tire changes etc.
