racecougar
Missouri
Tell us more about the Mercury cougar with the cowl hood. I had 2 Thunderbirds, Turbo coupes and Super coupes of the same era.
It's a '90 XR7 that I built back in the early 2000's whilst in college. The hood is all steel, and completely necessary. It has a 298ci Teksid-based stroker, 4V "B" heads, 2.1L KB twin-screw, dual methanol injection systems, etc. I swapped in a '97 interior, aluminum rear LCA's, 4-piston Brembo's, and so on. That build started the business that put me through college, landed me my first job out of college, and set me on the path to where I'm at today.
210687606_1485404621808538_1576996374857816226_n (1).jpg210580652_137589981793790_3542997516063692097_n.jpg
211018740_857293158220884_4241123446106388133_n.jpgIMG_E5576.JPGIMG_9840.JPG210524711_187359333330722_5134040507426755248_n.jpg
msharley
Central Pennsylvania
Replaced the Sirius XM antenna on the ElectraGlide yesterday. Old one? Had radio displaying the "Check Antenna" /chk-ant message.
Since it has 23' of lead.......stretched it out onto the driveway. Worked fine? (they say a couple/three years they go bad?? Guess with the water/vibration on a scooter?)
For those contemplating this...make sure yinz get the right antenna for your application...there are about a half dozen different plugs..
New one works fine...
Like it never happened..
msharley
That is one sharp looking Merc!
Looks like it hauls..............the mail!
WHAT tool are we supposed to be using to cut that 1/8" steel wire cable? Obviously those tools I currently own are not up to the task.
Wrap with tape first then a cut off wheel, or I even used a the cutter section on a pair of vice grips.
Key is wrapping the cable with electrician tape very tightly
Thin cut off wheel in a mini grinder does well or there are Impact type wire rope Cutters that are hammer/sledge driven that also work well
https://www.midwestunlimited.com/mo...n28T0TI3yBwn8LoSDgNvOgxVm8E9BqCgaAo8fEALw_wcB
Beerhippie
Far NE Oregon
Now, that is a proper looking shop!
That was before the great organization of '24.
This:
is the after pic. It just doesn't show the Wahoo as well. Frank the brewer is at the staff break table. That's also about as clean as it will ever be.
No, the shop is not that big. I'm using an extreme wide-angle lens to get it all in.
Well, yesterday was F'in' stupid. You know what you don't do when you have a broken rib a week on the mend and starting to feel pretty good? You don't lie on your back in variously contorted positions while wrenching under a rig--that what. I've set myself back a week in recovery.
I have access to a perfectly good shop with a perfectly good two-post lift. If I'd done all this standing up, I'd be fine right now.
INSP380
Cleveland, Ohio
Beautiful Camaro. Is that a turn signal light on the top of the fender? I didn’t know that was an option and never seen it before.
Thank you! That was the U46 Vigilite option. It used fiber optic line to signal a jewel for the headlights, parking lights, tail lights and license plate light. Mine was dealer installed. There is a unit on the rear package shelf as well. IMG_5882.jpeg
Snip's
Worked on the JD garden tractor yesterday... The ignition switch was being temperamental... Original 40 YO switch...
Tight space with my big hands...
Cleaned up the plug connector on the wireing harness that plugs into the switch... The contact cleaner did a nice job on the female spade terminals...
Decided to cut the old switch open... Looks tired and lots of carbon debris...
Today I tested the glow plugs with a clamp on DC amp meter... Initally jumped to 16.5 amps and 3-5 seconds about 13 amps, then zero amps when the timer shut the plugs down... Ignition switch works as expected now...
2001ZR2
Kansas City
I got the sights and bipod installed on a rifle.
Used the $1 Snap On soft face hammer garage sale score and the Bondhaus hex keys from a GJ recommendation.
Never had fooled with an M Lok mount before but not too bad. The sights were tight adding them.
Never know how well they'll work as the required loss in boating accident occurred after.🤔
nadogail
Coronado, CA
Found out what mistakes I had made in adding a switched outlet to my miter saw table. The first one was not using the most appropriate material for the job, I decided to make do with what I had rather than spending a few bucks on the preferred stuff.
Secondly I did not write out a plan, I was just going to wing it.
My experience normally involves using conventional wire colors and standard practices.
I got frustrated and tired Saturday afternoon and Sunday.
Sometimes trying to save a little money winds up costing you time and energy.
I “Cold Checked” my work today and will test for Smoke tomorrow.
One of these is cheap and invaluable insurance:
BuyMyGarage
MIchigan
2016 Cherokee with a service park brake error, and stuck in driveway.
Throwing code
C10Cd - park switch error.
Tried fuses - all good
Disconnected battery for 20 min - no change
Changed out switch in center console - no change
Removed rear trim pieces to get to the Electric Brake Module. Shows signs of corrosion between wiring harness and the module.
Ordered contact cleaner, sprayed male and female parts. Used turbo dryer to hasten the process.
Plugged back in, cleared code and all is good.
Reassembled trim.
About $20 in parts. More hours working on it that I would like. But vehicle works, for now.
msharley
gearhead1960
Gun cleaning time....had gone shooting late last year and now just getting around to cleaning the firearms I shot. I know, should have done it after shooting, but I don't use corrosive ammo. Today's subject was the 1915 Carl Gustafs M96 Mauser....
Shoots 6.55X55mm Swede.....a lovely round. All my vintage military guns are shooters...no safe queens here. My camping buddy had never shot anything bigger than a .22 and couldn't believe how easy and fun it was to shoot. Here's the action prior to removing the bolt....
Bolt removed....
...and dis-assembled for cleaning....
Owned this one for over 30 years. It's a numbers matching gun and never fails to bring a smile to my face...
Tomorrow, the S&W 686 gets it's turn.....
Beamer
Northeast
Attempted to get vehicle differential fill plugs out and found my set of hex plug sockets skipped 10mm. There was an empty space in the box! So chased around town, ended up at HD to get one "made in Taiwan, finished in China" for $5. How is that possible?
Lost ambition and decided to hike the dogs in the forest instead.
Tomorrow is another day.
Beamer
Northeast
Lucas, Prince of Darkness.
I never had an issue with Lucas in almost 50 years until the smoke got out of the wires on my Triumph when the saddle fell and the metal seat pan shorted the charger alligator clips on the battery. It turned out to be a very effective way to strip the insulation from the wires.
In retrospect, a me issue, not a Lucas issue. Now it has a pigtail and remote connection so no more alligator clips in harms way off season.
rharman
SoCal
Installed a 48" tailgate light bar on the Ridgeline. Lotsa fiddling and testing to insure everything cleared. Using the tripod and phone video to check and double check making sure everything worked and fit.
While doing that I thought of the recent discussion about keeping spring opening pliers closed. I strolled over and grabbed my o-ring kit. Opened and searched, low and behold I have these large seldom used heavy duty rubber bands in various sizes and they fit perfectly. YMMV1780461068188.png
I always keep a supply of these on hand for tasks like that. They're super handy for so many things in the shop and house. Gotta be the Gel Elastics. They have other variations that are not suitable for garage use.
zachgeo
I added a hardboard top to to the center of my OSB workbench, where I do most of my work. I noticed that the OSB was starting to show a bit of warpage there from working with solvents and other liquids - even had to add a few nails and hammer down the existing ones more to get it straight. I went ahead and treated the hardboard with a bit of BLO and then paste wax to make it more waterproof. I really like the look and feel of this, so now thinking of doing the rest of the bench off to the right, while leaving the left side all OSB for a less slippery surface.20260602_211554.jpg
rharman
SoCal
This:
So, you keep all your lanterns at the brewery shop? Not at home?
DGersic
DeKalb, IL
Parts arrived.
I ordered the plain compressor, they sent me the chrome one. Bit too shiny, but oh well.
Evacuated the system.
Removed the old compressor, drier, and expansion valve. Flushed the lines, evaporator, and condenser.
Waiting on some JB Weld to cure on the under dash box. One of the drain tube connections broke off. The plastic is pretty brittle, maybe from age.
Got the new drier and compressor in and connected up. Tomorrow I’ll be reassembling the under dash box and getting everything back together.
bmwrd0
Beaver Fever Oregon
I do this with both my benches, love it.
Josh Dekubber
Bothell Washington, Peoria Arizona
This is an original concept, reusing (much less restoring) last years grill. Around here every spring last years grill is set out at the curb and the following week the cardboard box from the new grill is set out at the curb.
Great job on the restoration, a 1992 grill still in use is amazing.
Thank you I appreciate that!
Josh Dekubber
Restored the side serving tray from my latest restoration Grill. Now it is 100% complete. The side serving trays are quite rare. I ended up getting pictures and dimensions of the original wood handles from my friend Mark in Australia who has one. Off of his detailed pictures and dimensions I fabricated new wood handles for the serving tray out of matching ipe Ironwood (Brazilian Walnut)image.jpgimage.jpgimage.jpgimage.jpgScreenshot_20260531_193524_Photos.jpgScreenshot_20260531_200132_Photos.jpgScreenshot_20260531_203015_Photos.jpgimage.jpgScreenshot_20260531_200923_Photos.jpg
kaymccampbell
Upstate New York
I never had an issue with Lucas in almost 50 years until the smoke got out of the wires when the saddle fell and the metal pan shorted the charger alligator clips on the battery. It turned out to be a very effective way to strip the insulation from the wires.
Every Lucas electric car I had got a new electric everything. My Triumphs were all GM products, my Jag, a mostly Chrysler with Ford heating.
