Between 265 & 485 SQ/FT My new garage in Wales
Z
Zebedeewesty
Wales, UK
How does mileage compartment to gasoline/petrol?
Supposedly around a 10-20% loss. Its just a basic open loop system with a mixer ring on the top of the carburettor. The closed loop (with lambda probe in the exhaust) gets better MPG and the sequential injection setups used on FI engines have virtually no loss of MPG. I was gonna put a fuel injected mk3 golf gti motor in when this engine went pop but it just keeps soldiering on.
Its averaged 17.5mpg (14.5mpg US) vs around 20-21 over the past 60k miles still saving me around £400 to 500 a year.
Fantastic decals! I might have to borrow a few of those! My Type 181 fits the "why drive boring cars" nicely.
They were cheap off TEMU.
You can't get any less boring than a 181. One has come up for sale local to me fairly cheaply, though its in need of a lot of work as its been sat in a field for years with a leaky roof. :(
Its still in army green with red cross logos. Ex Bundeswehr i believe.
ArmyVW_GuyInTX
North of the Fort Worth/Dallas metro area
I
Your garage builds are fantastic & your tin worm repairs!
If I was in the market for another type 181, I would prefer on from the Bundeswehr with the reduction gearboxes - as they came from the factory with limited slip. My other un-boring car is my 66 VW doublecab
Cheers!
Z
Zebedeewesty
Wales, UK
Had a look at the drivers side front brake on the bug today. With the wheel off the ground it didn't spin freely. The caliper's outer piston was quite stiff to push back to remove the pads. Inner was free though.
I did the passengers side one back in November 2023 with new seals but didn't touch the drivers side as it was fine at the time.
godzillaGTR
My previous garage was slightly smaller than a 20ft container, just 8ft wide and 18.5ft long. Even so i still managed to do a full body off restoration and respray on my 1970 VW Beetle.
After 20 years of living in Cumbria in the North West of England we made the move 300 miles south to a small village in South Wales.
One of the big plus points of our new house is a much larger detached garage.
Its around 20 ft deep and 24 foot wide though theres only a single 8ft wide door.
Theres a toilet built into the front corner which reduces the space a little but theres still enough space for two cars if go jacks or similar are used.
The area behind the toilet is around 12ft deep by 6 ft wide.
Theres a set of stairs in the rear corner with the bottom 3 steps being able to be up folded out of the way to allow access to a bit more storage under the stairs.
Upstairs theres a boarded out loft area which could really do with being insulated and plaster boarded as its hot as hell up there at the moment.
Bugs new home.
So far all i've done is to erect some Big Dug shelving to get some of the clutter off the floor. I'm still working my way though boxes of household stuff and sorting the house so progress will likely be rather slow.
I love it! Looks fantastic
Prospecter
Maine
Older vehicles take patience and persistence to keep them on the road. Good for you!
Do you have room to park the Caravelle in front of your garage? Maybe put a temporary awning over the Caravelle to work on it?
Prospecter
Maine
Yeah, theres loads of space in front of the garage. I've got a huge tarp and loads of bolt in wall anchors too. I could screw them into the wall above the door (just under the eaves) which would stop any water from pouring into the garage if the door was open.
Sounds like you have a plan!
ArmyVW_GuyInTX
Got the beetle's caliper reassembled and bled. Just been for a bit of a test drive and its no longer so hot you can't even touch the wheel. 👍
Mid summer car run on sunday and it looks like its gonna be a scorcher.
I miss those two pin brake calipers instead of the garbage sliding caliper on most of today's awful consumer buckets!
Z
Zebedeewesty
Wales, UK
My 1988 caravelle has the sliding calipers and the slider pins stick every year or so. They're easier to remove and reinstall the piston though.
These calipers were off an early 1980s Talbot Horizon (same as a Dodge Omni in the US) and are huge compared to standard beetle ones. About the same size as a vw bus uses. 48mm pistons vs the stock 40mm in a bug's.
ArmyVW_GuyInTX
The Doge Omni (Plymouth Horizon) in the US was a shyte imposter of the Golf!
Z
Zebedeewesty
Wales, UK
Yeah, they weren't brilliant. Rotted like crazy too. Don't think i've seen one on the road or at a car show since the 1990s.
Its just a shame Lotus didn't continue with their mid engined Group B Horizon.
The prototype looked pretty cool.
Z
Zebedeewesty
Wales, UK
Holly wouldn't put weight on one of her back legs last night. Think she's possibly twisted it or something. Decided to leave her at home while i took Lucy out on her own. When i got back i took her out into the garden for the loo and she's starting to put a bit more weight on it.
Proper nasty drizzly morning again. :(
Lucy wasn't sure what was going on being on her own. She kept stopping and looking back as it she was waiting for Holly.
Z
Zebedeewesty
Wales, UK
Spare tyre removed from its holder for the first time since we bought her and it's dated 1995. One side wall has an indent shaped like the chassis crossmember and the other the shape of the tyre holder. Oops.
We've gained a new motor for the weekend. Council road works start on the corner opposite the house on Monday so got asked if they could leave the roller for the weekend.
Z
Zebedeewesty
Wales, UK
Did they leave the key? You do need to take old tyres out for repair. No flats in the loaner too.
You can start them with a screwdriver or any flat piece of metal. ;)
I'm just going to replace the tyre valve on the one that failed. I've got one of those cheap valve tools that allows you to remove and replace without taking the tyre off the rim. Saves me about £10 or more for the labour and a 20 mile round trip to the nearest garage that will do tyres.
The spare is just about holding the van up its that perished. Its not even the right load rating. :rolleyes:
Once i've got it back on its good tyres i'll take the valve out of the spare, wire brush the rust off and repaint the rim then get a new tyre fitted.
They're not too bad a price and theres a load more choice as its got 15" rims too. The exact same tyres for the caravelles 14" rims are £20 ($27) more.
Z
Zebedeewesty
Wales, UK
Appears no-one can get quantities right when selling on ebay. I bought two sets of points for my model railway and 4 arrived. I also bought a 125ml tin of brake caliper paint and a 250ml tin arrived.
I think i'm being watched.:ROFLMAO:
I'm starting to get quite a collection now. All now converted to DCC and i'm able to control them off an app on my phone.
I was told you couldn't make an old Lima loco run smoothly and slowly due to the ringfield motor being rubbish. Can't get much slower running than this.
It's weird though, the other Lima class 37 I have from the same year and with the same motor won't run anywhere like as slowly. :unsure:
Z
Zebedeewesty
Wales, UK
Looking back a bit
looking at the front of your garage a car port on the front would look good and be useful maybe a old fuel pump to a side too
It would be handy.
Had a good run around with the classis car club on their mid summer run yesterday. Only around 45 miles or so but the bug got to stretch her legs a bit. I really need to give it a proper tune up as i'm still getting a bit of popping on overrun on a closed throttle. I think its possibly still a little lean at idle.
Z
Zebedeewesty
Wales, UK
It could be a small exhaust leak but I bet you have checked for that
G
Yeah, i've not found one though the exhaust pipe in the heat exchangers are enclosed in an outer skin so unable to fully check.
Richening up the idle screw makes it pop less though that could possibly just masking up a leak somewhere.
Z
Zebedeewesty
Wales, UK
Electricity board helicopter checking the power lines. Its the same colour as the air ambulance so it looked quite ominous as i thought it was landing in the field across the road. :rolleyes:
Been having a look at the A/C plumbing trying to work out where the fill point is in the system. There isn't one fitted in one of the hoses. Its an aftermarket Diavia made system i believe.
Line A goes straight to the compressor (to connection C in the second picture). B comes from the condenser. No idea what the connection ? on the drier is for.
Hose A above is connected to C on the compressor. The hose from connection D on the compressor goes to the condensor then hose B runs to the dryer and then through the bulkhead to the evaporator. I think the two grey caps i marked ? are the two (high D and low S) recharge points.
