Shop Utility Sink - Drain Stub up through concrete Distance from wall
nmjwolf
Dumb question - I plan on installing a utility sink in my shop. Whats the recommended distance from the wall to stub up the drain pipe?
larry4406
Northern Virginia
Exterior wall?
At the day job, we install plumbing roughs typically around 4" off the rough framed wall.
How are you venting? AAV?
larry4406
Northern Virginia
Sink plumbing normally comes up where it lands inside the wall cavity. At least the ones I've seen a done.
If it’s an exterior wall, supply piping isn’t typically run in it due to freeze concerns. That leaves the waste.
If the supply comes thru the floor and waste comes thru the wall, it makes it a real ***** to install a vanity cabinet due to the piping on two different surfaces at 90 degrees to each other.
I know OP said shop utility sink, which might not have a cabinet. OP also did not specify if this was an exterior wall or interior.
OP also does not list his location so we don’t know if freezing is a concern.
Over the years, I’ve found best practice is keeping supplies and waste on same surface - all thru the floor or all thru the wall, but not both.
If thru the wall, we typically stub waste out at 18” above floor and the supplies a couple inches higher.
Codyboy
S.E. TEXAS
@larry4406
Yeah , I guess I don't really think of the freezing aspect on projects because we don't really have that around here.
And yes I agree where ever it needs to come through then both supply and drains need to be done that way.
It would **** to have to fit a cabinet with wall and floor penetrations.
N
nmjwolf
I was just curious distance from wall
Exterior wall?
Yeah AAV and coming up through concrete in front of wall (heated shop) I put it at 7" off the wall.
My notifications must have been turned off didn't see any responses to the thread.
yatg
Southern Oregon
If you're using a typical utility sink, it may drain it towards the back or the center.
At 7" from the wall, you're probably not going to have the centerline of the sink over the pipe to make a trap connection.
Might want to get the sink and mock it up.
Particularly if you want the sink "exactly here".
