Wobble nut driver
bryant 24
Any one has experience with this wobble nut driver?
Was looking for a swivel socket and find this VESSEL one,thinking it will be perfect with my Milwaukee m12 impact driver;
Is this strong enough for car repair?Or i should just got a normal swivel socket to use with my impact wrench?
bryant 24
No experience with those but I just use a 1/4 wobble bit driver with regular sockets for my impact driver. It works fine for small low torque fasteners.
Totally agree this will be fine for small
fasteners,but this sets’ size is up to 24mm,who use a nut driver to drive that large?
DAWrench
Central AR
Those sizes are way to big for an impact driver. 12 mm is probably about where I change to the 3/8 impact and swivel sockets
bryant 24
I think this set is designed for hvac or construction where the nut torque is not that high?Not for mechanics.
Mechanics may not use impact nut driver that often?
KnurledNut
n/a
You answered your own question. These are for construction fasteners in the Japanese industry like solar components, unistrut, scaffolding, concrete anchors, road work, electrical/lighting, plumbing, etc.
I can’t tell you how many times I would have loved to have a 9/16 version of this wobble/fix socket.
We used 3/4 and 13/16 (heavy hex) deep sockets with impact drivers setting mudsill anchors. I’ve used 15/16 (24mm) working with structural steel bolts.
If Vessel offered these in SAE, I’d be interested in a set.
mattstevens
If you're considering the set pictured it looks like they have the 13mm shank used in Japan. Those won't lock into a standard impact driver chuck so you'd need an adapter that can accept them (or a tool with the deeper Japanese chuck).
bryant 24
SAE FROM 1/4 to 9/16"?
