YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 502
2020 Honda Accord. Looking at possibly replacing the inner tie rods. The service information says to lower the front subframe. I thought this was a bit insane. However, looking at the actual part, it is not the typical setup. These inner tie rods have 8 wrench flats, as opposed to the typical 2 wrench flat design.
So a tool with only two wrench flats (like an open end on a box end wrench) that you put in a long pipe like the tool below, won't work in this design.
Looks like a tool like above, except supporting the 8 wrench flat design, does not exist? If it did, you could easily replace the inner tie rods without removing the front lower subframe. Seems like lowering the front subframe would allow you to vertically above or below the wrench flats with a normal open end wrench, allowing you to remove it.
