Ryan
Administrator
Texas/Hawaii
I found myself at a buddy’s place over the weekend, pulled there by some vague notion of watching a man wrestle with history. He’s deep into restoring a house from the early 1900s, and for the last several weeks he’s been rebuilding solid mahogany doors by hand. That sounded like the kind of madness worth witnessing up close.
The doors were something, sure. But the real story was the saw sitting on his workbench like a small, beautiful artifact from a better civilization. Tagged as a Guildtool 4-A, though the cognoscenti know it as the Porter Cable A4 trim saw. All cast aluminum body, worm drive, takes a 4.5” blade, and produces a genuinely obscene amount of torque for something you can hold in one hand. They started building these things in 1938 and kept at it until sometime in the 1950s, when apparently someone in a boardroom decided the world didn’t need good tools anymore.
I need one. This is not a casual want. This is a biological imperative. The thing makes savage...
Continue reading...
R
Ryan
Administrator
Texas/Hawaii
One of my Uncles had one, pretty impressive little saw!
Left hand blade would have been better but since it's small, it's ok as it is.
As noted, tons of torque, cuts well even with a dull blade.
Considering when it was built, it'll never wear out......
The blade on my buddies was super old and looked abused as hell… I guess blades aren’t easy to come by… but even so, it cut so damned cleanly.
Squankum
Southeast
The saw in the stolen picture, and the one in the ebay listing, have a 4.5" blade. Those are available from HF ("Hercules") to Diablo.
willy3486
Middle Tennessee
Most of my tools are the older tools most people cast off. I have so many aluminum hand drills I don't know the exact number, maybe 10 to 15. If I see a old tool at a flea market or yard sale cheap I get it. Many times you can go through one, put a new cord, new grease, and brushes if needed for ten bucks or less. I find way more that are fixable than not.
So if you do find one of these that the gears are ok and the windings are not burned you can probably rebuild it easy. The best finds are the ones where it looks like some wild animal chewed the cord. Most folks thinks it trash but all that is wrong most of the time the cord has dry rotted.
BobnCO
I saw one of those on Marketplace or CL a few months ago and was tempted.. I have a vintage Porter Cable 7 1/4” Cabinet Saw (and am a lifetime “master” trim carpenter)… but I’m trying to cut down. If I had already seen you post I could not have resisted. 😀 I think I’ve seen a few of them go by, often in great shape.
Squankum
Southeast
The Knipex scissors thread was a lesson in "shop around", when it turned out HF has the same thing for $11 less...
In this case, the HF equivalent to that old tool is this modern thing:
HF "Bauer" brand for corded, more money for the HF "Hercules" cordless.
I've never used it, so I have no clue. My gut reaction is "that's not like a normal circular saw, isn't that dangerous?!" But I have no idea.
But I have no idea. They used to sell something with two small counterrotating whirling blades of death that, IIRC, you could do plunge cuts without kickback. Couldn't find it on the website.
And the HF version talked about here
BreeStephany
Oregon
While the Porter Cable A4 is a beautiful panel saw, I personally prefer the Skil 67 'blue label' for ripping and 'fine tuning' anything 3/4" and under.
I definitely admire the A4 and if I ever find one in the wild for a 'reasonable' price, I probably wouldn't say no.
My favorite and most beautiful tool is definitely my Porter Cable 653 Versa Plane!
BreeStephany
Oregon
Still looks less terrifying than my flush-cut toe kick saw... one of those tools I bought for a single project before Fein multi oscillating tools, and all the other brands to follow, were a thing.
neophyte
Pennsylvannia
The Porter Cable 314 “Trim Saw” might essentially be the same type of saw, just in a slightly later updated version.
The 314 also has a worm drive and is also 4-1/2”.
The base plate is slightly different.
There was also the Rockwell 314, which was what the Porter Cable 314 became after Rockwell purchased Porter Cable, with Rockwell becoming Porter Cable again after bring sold off by Rockwell.
The later Rockwell and Porter Cable saws lack the polished housings, but otherwise should be similar.
I briefly worked with someone who used one of the Porter Cable 314 saws, purchased in the 1990s I think.
Carbide blades from decent brands should be available for the 314.
Mafell also makes a small track saw using a similar sized blade, that has a plunge feature, and can use the attachable miter guides, but it’s Mafrll, so the saw costs over $1000.
crguy
SW Washington
I had one of the little Porter Cable saws for years. There were a few times it was just what I needed for a job.
smokey0810
Canyon, Texas
just nice seeing how they actually put some effort into the design and looks of the tool….saw some guys on a diy show on hgtv using saws like these to cut thru slate. They sure don’t make em like they used to
neophyte
Pennsylvannia
No, they don’t make them like they used to, but even using the basic, likely inaccurately low Government inflation calculators, a basic 6” Porter Cable saw would have cost around $1,600 in todays money, and that is likely a low estimate.
The price list from 1936 on archive, lists a 6” saw at $75.
According to a quick google estimate, the average wage of an industrial worker in 1936 was around $0.57 an hour, so 131 hours of labor to buy a saw, or three weeks of total paychecks.
The closest equivalent nowadays in cost would be something made by Mafell, and even those are cheaper, although also not polished.
GrayFlattop
Chicago
I always wanted one of those, but like most tools, I have too many saws.
I do have a Craftsman "Commercial" 4-1/2" saw (not worm drive) that I have used rarely. Probably not more than 2 hours time on it since purchased around 1980.
tomsatx
San Antonio, TX
That's a classy saw, and has the plastic handle too. I do have the newer 314 Porter Cable saw and will not part with it. 314's great for smaller trim or up to 3/4 plywood @ 90 degrees.
I'm weary of the full metal tools but love the look. I currently have one, a Skil 100 power planer but this doesnt get used much.
willy3486
Middle Tennessee
I picked up a skilsaw 77 wormdrive last week. I got it online and the info was that it sparks by the bushings. I figured it was a deal if it was only the bushings so I got it. When it arrived it sparked and I started to replace the bushings. They looked almost new. I cleaned the armature contacts and soldered some of the windings that looked loose. It seemed to check good on the meter after that. Hopefully that will fix it. I plan to make a growler to test armatures so I may make one sooner than expected if it still has a issue. I had wanted one for years.
