2001ZR2
Kansas City
After having guests for week and beginning the process of getting the house back in order...
Broke out the file to fix a storm door that for some reason the frame was banana shaped with the largest part of the curve at the latch.
After fixing that and raising the sweep so the door would fully closed...I noticed the latch is installed with sloped side towards the swing of the door. I'll fix that tomorrow as it was dark and I needed to start getting ready for going back to work tomorrow. Just couldn't see until.all the other issues were addressed.
bugnut
Central Ohio
Have you tried braid on the Zebcos? On open face spinners braid is a common thing to avoid twisting tangles but I've never seen it used on closed faced. Just curious.
@Hooked I do not think I have used braid on a closed Zebco. Might try it on a 33, as I use braid on everything else, both salt and fresh water, open spinning reels. The smaller diameter and more limp line might really change up the feel. I probably have some leftover 3 or 4 lb from the ultralight reels....Hummmm.......
SMOKEYBEAR
Chased an issue on the boat trailer. Surge brakes locking up when in reverse, inspected the solenoid that locks it out, rewired it to eliminate the quick splice that was there, found the blown fuse on the truck, replaced it, blew another fuse. Inspected the blue/ back up light circuit....found the problem. 100% self inflicted error. Access is pretty challenging, inside the frame between the tandem axles. I'll fix it this evening after work.
Fixed this self inflicted error. It was everything I new it would be, the boat trailer is very low, hard to jack up, odd to find proper jack stand placing and be able to remove the tires ( tight fit with the dual axle/ fender design). ..hard to access, tight space, everything just out of reach, minimal slack in the harness.. but I have it complete, replaced the micro fuses on the truck and I'm back in business.
aka Larry
Eastern, NC
I helped a friend install a trailer hitch on his 2015 Ford Edge.
It wasn't brain surgery, but it wasn't exactly 'easy' either. The very limited access to the end of the frame rails to use the fish wires for the bolts, was at least 90% of the battle. I could just barely get my part of my hand in the space to get it done. The good news was all the pieces fit perfectly, and we didn't have to "make anything work", which is very unusual in my experience of late.
I'm not saying it's impossible to do alone, but it took the two of us about 3 hours using my lift. The instructions said "DIY Install Time = 1 Hour. Professional Install Time = 30 mins. I'd pay $500 to see anyone do this on this vehicle in one hour. I'd pay $1000 to see it done in 30 mins.
930dreamer
Amarillo,TX and Stinnett,TX
KRA 398A flat tire, I didn't think I'd have to remove the axle to get the wheel off!
Axle is 3/4" diameter and most replacements are 5/8".
gearhead1960
Inventoried my bayonets for my vintage military assault rifles...
First up are two for my Swedish Model 1896 Mauser....
...next are a pair for my M1 Garand....
...British No. 9, Mk. I pattern bayonet for my British Enfield rifle...
...and a pattern No 4, Mk. II bayonet also for the British Enfield..IMG_4015r.jpgKII spike
The No. 9, Mk. I pattern was the replacement for the No 4, Mk. II affectionately known as the "Pig Sticker"....when the ammo runs out, gotta have options...
manwithtools
Lebanon, TN
Beerhippie
Far NE Oregon
Did my usual work ****. Got started on the weekly round of mowing after three days of constant rain.
Made some plates to mount the shovel mounts I bought from Azon:
It's flimsy. Tomorrow, I'll start over again and make another set of plates to go this side of the wires on the basket sides to stiffen it up. Not 100% sure the mounts themselves meet my needs.
The ones I made for the Toy rack are much stiffer and stronger.
BigSteve63
SW Missouri
